andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Wed May 29, 2019 4:58 pm Post subject: Metal sunroof crank only turns so many times? |
OK - somebody explain this to me. It seems like the sunroof crank is simply a geared shaft with a handle. Does it only turn so many times and stops? Did a sunroof repair and now they say it wont close the whole way. The Bently talks about turning the the handle a certain number of times when installing. I don't understand...Help _________________ D-Dubya Manx clone - 63 Short pan,1914.
Erik G Samba Member
Joined: October 16, 2002 Posts: 13283 Location: Tejas!
mukluk Samba Member
Posted: Wed May 29, 2019 5:15 pm Post subject: Re: Metal sunroof crank only turns so many times? |
The most common problem with the sliding metal sunroof is the rear vertical adjustment needs attention.
_________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Wed May 29, 2019 5:30 pm Post subject: Re: Metal sunroof crank only turns so many times? |
OK - I think that manual answered the question. The crank will only turn so many times and the it hits an internal stop. So, all I need to do is drop the gear drive, turn it a couple turns CCW and reinstall the gear drive and it will be good. I must have set it too close to the max turns.
Thanks! _________________ D-Dubya Manx clone - 63 Short pan,1914.
Sloop Samba Member
Joined: September 03, 2011 Posts: 90 Location: San Marcos, CA
Posted: Fri May 31, 2019 5:13 am Post subject: Re: Metal sunroof crank only turns so many times? |
The car should be dropped off Sunday so I can fix this and replaced the vent latch. I hate it when I send a car home and it's not perfect. _________________ D-Dubya Manx clone - 63 Short pan,1914.
