Zundfolge1432 Samba Member
Posted: Thu May 30, 2019 1:41 pm Post subject: Starter top bolt helper |
Working alone you’ll encounter this problem some day. You try to install top bolt but as you try to thread the nut bolt pushes back through, what to do?
Ck this out.
Using plumbers putty roll up a small piece
Install around the head like this
Install and smash it down
Now you can thread it as the putty will hold the bolt in place. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Thu May 30, 2019 1:46 pm Post subject: Re: Starter top bolt helper |
I've used "Gorilla Snot" otherwise known as weatherstrip adhesive. _________________ Glenn
Member #1009
#BlueSquare |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9960 Location: Huntington Beach, CA
Posted: Thu May 30, 2019 2:18 pm Post subject: Re: Starter top bolt helper |
I use exterior double sided tape. Stick it to the back side of the bolt, like Zund is doing with the putty. Slide it in and go put the nut on!
However, the surface has to be clean for that to work. The putty would work on oil or dirt. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Thu May 30, 2019 3:03 pm Post subject: Re: Starter top bolt helper |
I use the putty, like Zund does. When you tighten the bolt, the putty just squeezes out. No harm.
It’s another of those cool tricks that make life a lot easier when working on a VW when you’re alone. Although, the last time I installed an engine, it was my friend’s Karmann Ghia. He just got under the car and held the bolt stationary.
Any other time, I’ve had to go it alone—except for my trusty snake .
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
gt1953 Samba Member
Posted: Thu May 30, 2019 5:43 pm Post subject: Re: Starter top bolt helper |
That is a great idea. I used this stuff called duck seal, sorta the same consistency as plumber putty. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
rosevillain Samba Member
Joined: December 28, 2005 Posts: 1290 Location: roseville, ca
Posted: Thu May 30, 2019 7:13 pm Post subject: Re: Starter top bolt helper |
Just for sorta related information, the last new Bosch 'automatic' style starter that I used, didn't have the locking boss for the top bolt. So this job just got harder. |
Glenn Mr. 010
Posted: Thu May 30, 2019 7:21 pm Post subject: Re: Starter top bolt helper |
rosevillain wrote: |
I have a IMI starter and it doesn't have any nubs... so i use this:
Member #1009
#BlueSquare |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6597 Location: Houston, Texas
Posted: Thu May 30, 2019 7:37 pm Post subject: Re: Starter top bolt helper |
I've always asked my wife to help. This is a nice alternative. _________________ www.vwnos.com [email protected]
Posted: Thu May 30, 2019 7:47 pm Post subject: Re: Starter top bolt helper |
Glenn wrote: |
Dope! |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5600 Location: 37.5N 77.1W
Posted: Fri May 31, 2019 6:21 am Post subject: Re: Starter top bolt helper |
after wire brushing the bolt's threads, I just use a piece of duct tape to hold the bolt head in place. Might try some of these other suggestions. Now if I only had a double jointed elbow to get back there to the nut. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Fri May 31, 2019 8:17 am Post subject: Re: Starter top bolt helper |
These are some good ideas.
Funny, because I've never done anything special to hold such bolt in place. I just apply a little side pressure to the bolt end as I thread on the nut a turn, then I pull the nut slightly rearward as I turn it. I guess this helps to have a bolt and nut that thread together easily. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri May 31, 2019 8:30 am Post subject: Re: Starter top bolt helper |
Cusser wrote: |
Funny, because I've never done anything special to hold such bolt in place. I just apply a little side pressure to the bolt end as I thread on the nut a turn, then I pull the nut slightly rearward as I turn it. I guess this helps to have a bolt and nut that thread together easily. |
When I was younger I could get my forearm past the fan shroud and in far enough to reach the nut. That allowed me to do exactly as you have written.
But now, my forearms are to wide to slip in behind the shouts. That is no longer an option. So, I had to find another way. I get it started by tightening the bottom 2 nuts. Go underneath and slide the starter bolt in. On my way back out, I loosen the bottom two nuts about four turns on the lower studs. The engine then leans forward enough for me to get my hands and arms in back of the shouts. I then install the nut as far as it will go. Reinsert the engine to the tranny. And with a long open ended wrench turn the nut about 1/16 each time.Takes forever but better than removing the decklid and fan shouts. Although on the 2127 that is how I tackle that one! _________________ Jimbo
TDCTDI wrote: |
Posted: Fri May 31, 2019 12:00 pm Post subject: Re: Starter top bolt helper |
A ratcheting box end might be easier, price is way down on them now I got gear wrench brand with fine tooth and it speeds things up |
