Gauche1968 Samba Member
Posted: Mon Jun 03, 2019 4:27 pm Post subject: Problems After Driving in Intense Rain? |
84 1.9L with Digijet. I drove it yesterday for about 45 mins through an intense rainstorm. No problems running it through that, but afterwards parked for a couple of hours, went back out to go somewhere and it didn't want to idle, 500 RPMs, sputter, etc. Have to rev it to get it going, ran after a few mins. Today, its the same symptoms--doesn't want to idle after start, will stall if throttle not pushed.
What's the chance the rainstorm led to water penetration into the gas tank? Van was running fine before the rain. Should I start there or look somewhere else? _________________ 1984 Vanagon GL
1984 Vanagon Westy |
Farf Samba Member
Posted: Mon Jun 03, 2019 4:35 pm Post subject: Re: Problems After Driving in Intense Rain? |
Take a look under the distributor cap, could be some moisture in there. |
E1 Samba Member
Joined: January 21, 2013 Posts: 6543 Location: Westfalia, Earth
Posted: Mon Jun 03, 2019 4:51 pm Post subject: Re: Problems After Driving in Intense Rain? |
Could be that and that's a good first check.
If not, I'd bet the farm you have either a hole in an evap tank, or a loose grommet or connection into/out of it.
That is, if I had a farm...
Drain a pint of fuel into a clear container, let sit a half-hour, see if water settled to the bottom.
Then try a tankload of fuel dryer, then a quarter to half tank with Lucas Injector Cleaner. If suck action still exists, test the injector spray pattern.
The above happened to us, fouled an injector or more within five minutes of flooded roads, and then took five mechanics and 16 months to figure out. In the end, we figured it out ourselves and swapped in four new injectors. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman
Posted: Mon Jun 03, 2019 4:53 pm Post subject: Re: Problems After Driving in Intense Rain? |
Thanks,
It was done dry under the cap. bad valve gasket at the evap tank seems possible. _________________ 1984 Vanagon GL
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon Jun 03, 2019 5:43 pm Post subject: Re: Problems After Driving in Intense Rain? |
Add to that list the 2 fuel expansion tanks.
I had a hole, don't know how it got there, and rain was being flung off the front tires and made its way into the gas tank. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
bobhill8 Samba Member
I had the exact problem after an hour of heavy rain on the drive home from BUYING my van 2 years ago. Drained the tank by the side of the highway and filled with new gas. Started right up and drove home. Good luck. |
