ElChucoDoka Samba Member
Posted: Thu Jun 06, 2019 8:45 am Post subject: Doka Transporter Question |
My family has recently come into possession of a 1986 (I think) Doka. Auto transmission and 2wd I believe. Admittedly, I dont know anything about these. Seems to be in decent shape from what I can tell. Runs well and stops well. A little rust but seems common for what I believe is its age.
Can anyone here tell anything more about this vehicle by looking at the pics below? TIA for the help.
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Thu Jun 06, 2019 10:05 am Post subject: Re: Doka Transporter Question |
Definitely a 2wd.
It has rear side markers so it is probably Canadian. |
Posted: Thu Jun 06, 2019 10:38 am Post subject: Re: Doka Transporter Question |
syncrodoka wrote: |
Definitely a 2wd.
Good call. it does have a "Nordest Audi Montreal" decal |
SyncroButter Samba Member
Joined: February 02, 2016 Posts: 383 Location: Seattle
Posted: Thu Jun 06, 2019 12:51 pm Post subject: Re: Doka Transporter Question |
First automatic I've ever seen in a Doka FWIW.
Was originally white, but not a Tristar
Engine is a stock Vanagon engine (not an engine swap), if the little sticker next to your gas door says something about 98 octane then you may have a DJ engine.
We can tell you far more if you can get a picture of the paper sticker that is located underneath the dash near the fuse box, close to where your left knee would be if you were driving. _________________ Grant
In the stable: 1986 Syncro Westfalia/Bostig, 1989 Doka Tristar, 1974 Vespa Rally 200, 1973 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special
Gone but not forgotten: 1989 Porsche 944, 1973 Standard Beetle |
Posted: Thu Jun 06, 2019 1:06 pm Post subject: Re: Doka Transporter Question |
SyncroButter wrote: |
We can tell you far more if you can get a picture of the paper sticker that is located underneath the dash near the fuse box, close to where your left knee would be if you were driving. |
Does the VIN help? |
Posted: Thu Jun 06, 2019 1:11 pm Post subject: Re: Doka Transporter Question |
First automatic I've ever seen in a Doka FWIW. |
I know of a few, not my cup-o-tea. |
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1732 Location: Maine
Posted: Thu Jun 06, 2019 1:22 pm Post subject: Re: Doka Transporter Question |
First auto I’ve ever seen as well. Weird. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
Posted: Thu Jun 06, 2019 1:36 pm Post subject: Re: Doka Transporter Question |
ElChucoDoka wrote: |
VIN will only confirm manufacture year, not much info there beyond what is apparent in the pictures. The paper sticker under the dash will list the manufacture info from the factory including all of your options and configuration, where the vehicle was originally delivered, paint code, etc. _________________ Grant
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
pdxleaf Samba Member
Joined: January 14, 2014 Posts: 43 Location: Portland, Oregon
Posted: Thu Jun 06, 2019 2:07 pm Post subject: Re: Doka Transporter Question |
The vin could help determine if it was Canadian or European. I have a Canadian 2wd Doka originally sold in BC. If the middle of the vin has ZZZ's then it was European. If not, likely North American. Yours has the federal sticker in the read lid, which mine has. Do you have shoulder belts in the rear? Canadian's likely all had those and not all Europeans. not 100% certain.
If you have power steering, that is also an unusual option. mine has it, it's nice but not really necessary. non power drives easily too.
Rust is not good, dings are great. Dings mean you can drive it and use it without worrying about going to the lumber yard or dump. Be careful though, the guy at the compost yard is always trying to buy mine. Don't be tricked into selling it.
There is a little plastic tab covering a hole at the bottom of the chassis near the rear on both sides of the cab. debris can fill up the drip hole, which collects and can cause rust. you should clean that out if it's clogged.
if you are new to vanagons, check out the faq file. there's a lot of info on things to check on new vehicles. Once you get the maintenance up to date, it should be a good driver. Check your tires to make sure they are rated for a truck. If not, it won't handle as well and could be dangerous if loaded. |
