elpres Samba Member
Posted: Tue Mar 21, 2023 11:57 am Post subject: Split pickup 63 |
I need to know How Long This shift rod is for my 63 pickup.
I know i Can buy a new one, but I’ll rather repair the original. Thanks _________________ Jakob |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Tue Mar 21, 2023 5:59 pm Post subject: Re: Split pickup 63 |
Problem is even if you get the length just right, the next hurdle is getting the front and rear of that rod clocked correctly. A little off and you will only be able to get the bus into only 1, 2, & reverse, or 3, &4 only. _________________ In Stereo, Where Available! |
Posted: Tue Mar 21, 2023 6:03 pm Post subject: Re: Split pickup 63 |
Probably best to find someone local to you that has same front shift rod to loan you. Then build a quick jig off the loaner to fix yours. _________________ In Stereo, Where Available! |
elpres Samba Member
Posted: Wed Mar 22, 2023 10:33 pm Post subject: Re: Split pickup 63 |
Eric&Barb wrote: |
Probably best to find someone local to you that has same front shift rod to loan you. Then build a quick jig off the loaner to fix yours. |
Yes I think your right. Thank you for posting.
I wonder if the “clock direction ” part of the Rod is similar on all the rods made for split busses. _________________ Jakob |
Posted: Thu Mar 23, 2023 10:59 am Post subject: Re: Split pickup 63 |
elpres wrote: |
I wonder if the “clock direction ” part of the Rod is similar on all the rods made for split busses. |
Not sure I am following you... Main thing is that there have been plenty of new reproduction rear shift couplers that turn out to have the front and rear ends not aligned causing shifting problems. _________________ In Stereo, Where Available! |
Clara Samba Member
Posted: Fri Mar 24, 2023 8:40 am Post subject: Re: Split pickup 63 |
elpres wrote: |
Eric&Barb wrote: |
Front shift rod for early buses, before vin 835 xxx, is different than late busses _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
70bus Samba Member
Posted: Fri Mar 24, 2023 3:34 pm Post subject: Re: Split pickup 63 |
Any companies alleged to be better (or worse) than others on the 'clock' accuracy? I need one for the 65, and no used ones are availabe locally so will need to order a repro... _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
"If Von Dutch was alive, he'd walk in there with a pistol and shoot these people."
-Robert Williams |
Mauidude Samba Member
Joined: June 23, 2022 Posts: 32 Location: Haiku Hawaii
Posted: Sun Mar 26, 2023 7:44 pm Post subject: Re: Split pickup 63 |
My truck is same year 1963, just switched to CSP rod with extra long bend for my adjustable beam clearance.
I get 32 and 3/8”
Good luck |
elpres Samba Member
Posted: Mon Mar 27, 2023 6:47 am Post subject: Re: Split pickup 63 |
Mauidude wrote: |
I get 32 and 3/8”
Good luck |
Thanks a lot.. i really apreciate it. I was very reluctant to buy a reproduction rod. Now I don’t need to. Since mine is already cut in half I will make the “clocked” part of it adjustable. Thanks again, I owe you one 👍
What’s this??
Posted: Mon Mar 27, 2023 11:04 am Post subject: Re: Split pickup 63 |
Elpres, next time I’m in Denmark you can buy me a beer🤣
That is part of the Bear shifter lock mechanism. https://theftstop.co.uk/bear-lock/ |
