Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Tue Jun 11, 2019 8:19 am Post subject: Replacing rotted lower left rear structure on 67 Fasty |
So my 67 Fastback has damage (rot and PO hackage) in the lower left rear structure. There is nothing left to connect the fender to. Also the PO welded in a mustache bar support.
So I'm looking for repair strategies. I do have the hulk of my old 68 squareback which is intact in this area but there appear to be some differences. I don't know if the differences are 67-68 differences or fasty - squareback differences. The rear fenders from the two cars appear to be the same.
Here is the 68 structure:
So ... do I need to be looking for a 67 Fastback section or will a 67 Squareback section be the same?
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Yabbadubbadoo Samba Member
Posted: Tue Jun 11, 2019 6:47 pm Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
I imagine there's no real shortcuts due to all the layers of metal in there that are welded together.
You have to peel it back like an onion skin probably starting at the rear valance then the inside of the rear valance (inner air duct structure) then work your way to the sides (inner fenders) where the rot is. Maybe section the rot off the inner fenders and replace the lower portions to minimise the work then spot weld it all back together replacing the inner ductwork and rear valance if necessary. On that note, familiarize yourself with the spot welds and get some spot weld drill bits. It's a massive job to do right . Honestly I would hate to be you mate. I've just spent a week under my engine bay for some work that is only a fraction of the work involved in your repair. _________________ Sydney, Australia.
66 Type 3 Fastback |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Tue Jun 11, 2019 9:40 pm Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
Lucky you to have the parts you need.
Time to start chemically stripping undercoating,
Drilling spot-welds,
Sandblasting,
Etc.
Square and Fastback are the same through all of that area.
IRS rear mount hangers aren't correct for '67.
Those are factory 69-up rear IRS hangers cut from a later car,
And shortened to fit up under an early swing 68-down body.
You can see they chopped the tops off of them to make them fit..
(Not that there's anything wrong with doing so, unless you are a purist of course).
Many like to use both the IRS hangers/bar in conjunction with the early sub w/horns in performance applications.
I like the call it the "150% mount", because it uses 50% more than either early or late.
The added bonus is it's full factory parts, and full rubber mount.
So, if you're building the car for power, you're already ahead. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Wed Jun 12, 2019 7:29 am Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
Clatter wrote: |
So, if you're building the car for power, you're already ahead. |
Not just yet. The 1776 from my old 68 will go in for now. The car as I got it had a stock-looking PDSIT 1600 TP. Who knows what's been in there in the past. Or how it was driven.
Yeah ... the IRS hangers. The stock anti-torque tube mount is broken. The PO didn't fix it when the hangers were added.
https://youtu.be/mgC17TLFmtk
And holy crap this undercoating is tough stuff. It laughed at a wire-wheel on my die-grinder. The paint-stripper wheel did only a little better. The heat gun did nothing. You mentioned chemical stripping. I see a variety of products available. What do you use?
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Wed Jun 12, 2019 8:45 am Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
Looks sorta like a money trying to whistle... |
Posted: Wed Jun 12, 2019 9:02 am Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
Clatter wrote: |
Sandblasting,
Etc.
Yup, that was my thought too (that area is the same on both Fastback and Squares). I don't think the IRS part makes that much of a difference in that area either., as the mounts are above it.
I've repaired that area on a couple of cars, and it's basically hollow, mostly providing a place to mount the bumper mounts. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KTPhil Samba Member
Posted: Wed Jun 12, 2019 11:04 am Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
GOOD LUCK! |
Posted: Wed Jun 12, 2019 11:09 am Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
I have had decent luck removing undercoating with your typical 'Aircraft Stripper' FWIW.
It takes a few passes..
If you're going to restore to 100% OG,
Then that rear hanger mount will need repaired/replaced, obviously.
But,
If you're going to the later rear hanger, then that thing becomes redundant.
It's really just kind of a 'locater' because early cars have hours and a cradle like a bug.
Seems like you already have all of the parts you would want.
Straightening that mount and welding the crack would be easier than finding and installing a replacement, at least it seems from here.
My plan might be to take your Sawzall and remove sections from that Square;
Making sure to cut pieces that are for-surely bigger-enough to replace even surprises you find dissecting the Fasty.
Having the sections up on the bench for stripping and dis-assembly would make things easier no doubt.
-Also-
If those bar hanger brackets were hacked in like it looks they were,
You might just be cutting BIG sections of the rear of your Fasty away.
Funny how so much of your car was missing,
You thought there had to be some kind of difference! _________________ Bus Motor Build
Posted: Wed Jun 12, 2019 11:11 am Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
Also,
Have you tried a twisted-knot Mackage Attacker on that undercoating?
FWIW,
There's detailed pics of all those parts buried somewhere within the fetid bowels of my build thread.. _________________ Bus Motor Build
Posted: Wed Jun 12, 2019 11:33 am Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
Max Welton wrote: |
Clatter wrote: |
FWIW,
There's detailed pics of all those parts buried somewhere within the fetid bowels of my build thread.. |
Holy crap. 115 pages?
Max |
Only 115 for a little while no doubt... _________________ Bus Motor Build
Posted: Thu Jun 13, 2019 10:48 am Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
Max Welton wrote: |
Yeah, amazing what can hide under a pretty exterior.
I am in communication with a guy selling a 67 rear clip from a squareback which should have everything I need. That bracket is just spot-welded on.
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1917347
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1917346
I am not going for a full correct reconstruction. If I can clean it up a bit I may keep the hangers, replace the bracket and use both systems. I will need to source a mustache bar and the assemblies that tie it to those side brackets. The 1776's case is a universal.
The 1776 going in is certainly no pavement-ripping torque monster, but I have an idea for adding a blower to it sometime in the future. A small one. You know, enough to counter the altitude.
Max |
I don't know how many "pretty" cars I've seen with hidden rust. Especially on repainted cars. A prime example is that T-34 I got from Russ. I knew it had some rust in it, but a whole lot more was hidden in areas I've never seen rust before, and that's saying a lot. My 71 Notch I got from Neil, had a lot of unusual rust. Yeah, the common areas were rusty, but it was very rusty. I'm glad we cut up a Square to rebuild with, as even the beam and it's support was rusted heavily thru in places. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Jun 13, 2019 2:14 pm Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
I drilled out all of those spot-welds and removed that bracket on my car.
(Of course you saw that in my build thread already. )
For all the work it will take to replace that bracket,
You could leave it in place, weld that crack up and grind it smooth 5 times,
IMHO.
Are you worried that it got bent out of shape, and you won't be able to figure out where it's supposed to be, or what shape it was originally?
The donut that goes in that bracket isn't exactly a precision fixture..
Most of the time they are wallered out pretty good,
And they aren't available new.
So much misalignment comes from sub-to-pan bushings, and the bellhousing pad mounts at the cradle,
That the rear donut gets all smashed crooked anyways.
Dunno if you read where Gene Berg wrote about the issue in his Blue Bible,
But this misalignment was common enough that fitting dual-carb kits often required adjustments to get the motor in the right location, even way back in the day. _________________ Bus Motor Build
Posted: Thu Jun 13, 2019 4:24 pm Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
When I ran Berg Special DCNFs on the square I needed more space for the filters, even with the shorty GB manifolds. Part of what I did was to add thickness to the subframe donuts to make the body stand a little higher. Performance carbs are just a tough fit in a type-3 as you know. I really hate cutting the deck / lid or just leaving the cover off entirely.
FI is the way to go.
Replacing that anti-torque bracket looks pretty simple. Drill out the spot welds and pop in a fresh bracket. I think Alex can get me one while he's looking for a lower left section that is solid.
I had to sleep last night so, no, I haven't read your build thread.
Posted: Thu Jun 13, 2019 4:30 pm Post subject: Re: Replacing rotted lower left rear structure on 67 Fasty |
Bobnotch wrote: |
I don't know how many "pretty" cars I've seen with hidden rust. Especially on repainted cars. A prime example is that T-34 I got from Russ. I knew it had some rust in it, but a whole lot more was hidden in areas I've never seen rust before, and that's saying a lot. My 71 Notch I got from Neil, had a lot of unusual rust. Yeah, the common areas were rusty, but it was very rusty. I'm glad we cut up a Square to rebuild with, as even the beam and it's support was rusted heavily thru in places. |
I'm not even going to try to reuse this fasty's beam. Not when I have the one I rebushed for the 68. I'll just switch them.
