Handbrake question
Drtrash
Drtrash is offline
PostPosted: Tue Jun 11, 2019 5:49 pm    Post subject: Handbrake question Reply with quote
My handbrake looks like 2 tv anenna, stick up a couple of inches and boot hovers over tunnel, it looks like it is adjusted all the way i think or do i need a new cable. Brake seems to work fine but this sucker is dangerous pocking up like it is
carsdlt
carsdlt is offline
PostPosted: Tue Jun 11, 2019 10:15 pm    Post subject: Re: Handbrake question Reply with quote
Sounds like it may be at the end of its adjustment. If you can't tighten it any more then it's probably due for replacement. Their are 2 cables by the way 😜
Thanx, DLT
'73 181 stock 1600 - "Dr. Bombay"
"If it works, don't fix it....let it break on its own."
Drtrash
Drtrash is offline
PostPosted: Wed Jun 12, 2019 6:02 am    Post subject: Re: Handbrake question Reply with quote
Are you saying cables are stetched and need replacement or brakes need adjustment? Assumong rear brakes then hand brake. Adjutment nut is way down but is it normal to have the spikes of ends of cable so far away from brake mechanism? Will post pic
hylomatt Premium Member
hylomatt is offline
PostPosted: Wed Jun 12, 2019 10:57 am    Post subject: Re: Handbrake question Reply with quote
@Drtrash - 1) adjust your rear brake shoes and then see if the emergency brake handle travel has improved. 2) make sure the brake cable sheath clips are in place and not allowing the brake cable sheaths to move around when you pull the hanel, and 3) that any adjustment available on the cables is adjusted
see photos below. if none of that helps then new cables. compare the new cables to the old ones to make sure they are shorter.
adjust brake shoes from the back of the backing plate:
make sure these sheath clips are there and attached:
brake cable adjustment:
Drtrash
Drtrash is offline
PostPosted: Wed Jun 12, 2019 6:43 pm    Post subject: Re: Handbrake question Reply with quote
Looks familiar but my bolts are 2" long wont let boot sit close to flush with tunnel
hylomatt is offline
PostPosted: Thu Jun 13, 2019 9:29 am    Post subject: Re: Handbrake question Reply with quote
well if you can get more adjustment out of them, then do so. it might be new cables time.
carsdlt
carsdlt is offline
PostPosted: Thu Jun 13, 2019 9:20 pm    Post subject: Re: Handbrake question Reply with quote
Hylomatt is right. Make sure your rear shoes are adjusted correctly - then you should have about 4 "clicks" on the handle pull to have the brake set. If you're not able to get close to this, it might be time for a new set. Good luck.
Thanx, DLT
