gt1953 Samba Member
Joined: May 08, 2002 Posts: 13842 Location: White Mountains Arizona
Posted: Wed Jun 12, 2019 4:09 pm Post subject: Windows down, exhaust fume smell |
Now that it is summer you drive with the windows down. Well when I do I get exhaust fumes in the front of the car. Squareback here.
New correct muffler, new seals around the engine cover, rear hatch, door seals as well.
Not sure how they are getting into the front of the vehicle. So what should I look for. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33875 Location: Conejo Valley, CA
Posted: Wed Jun 12, 2019 4:27 pm Post subject: Re: Windows down, exhaust fume smell |
At what speeds do you notice this? |
Dfasty Samba Member
Joined: November 22, 2005 Posts: 528 Location: north bay,ca.
Posted: Wed Jun 12, 2019 8:25 pm Post subject: Re: Windows down, exhaust fume smell |
It was explained that the most important seal in the hatch area was the small tube seal between the load floor and the dip stick. _________________ 70 fastback automatic 06 invader |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5360 Location: Lefty, CA
Posted: Wed Jun 12, 2019 8:33 pm Post subject: Re: Windows down, exhaust fume smell |
How quite is the exhaust system, and what condition are the heater boxes in? The on / off flapper on the heater boxes are not a positive seal. On type 1s, I have seen the exhaust tube portion of the heater box get a hole in it from rust. If the hole is larger, you get excessive exhaust noise. However, I have also seen them just have a pin hole, so no real increase in the noise level, but you would have an excess of Carbon Monoxide in the air flow (very bad). This pic is when I was doing a leak check on the first custom heater box I had made.
It was about 15 years old, and the tubing size, was 1-5/8". After all of that time and multiple valve adjustments, the box itself had an oil and dirt buildup, which stank with the heater on. With the box split open, I also wanted to check the integrity of the exhaust tubing itself. You could actually do this test without splitting the heater box apart. You could make a flange with a valve stem on the head connection flange. Then shove a cork in the other end, and use a combination of duct tape and bailing wire to hold it in. Then put in 5-10psi of air in it, submerge it in water and look for bubbles. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
gt1953 Samba Member
Posted: Thu Jun 13, 2019 6:30 am Post subject: Re: Windows down, exhaust fume smell |
KTPhill At what speeds do you notice this? slow street driving as well as on the highway. If just vent wing is open seems to be stronger.
In the cold winter months windows up and heater on there was no fume odor at all.
Dfasty It was explained that the most important seal in the hatch area was the small tube seal between the load floor and the dip stick. Not sure what small tube seal you are referring to.
I have ruled out the heater boxes as in the winter months it is just heat and no fumes. Would like to figure this out. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Dfasty Samba Member
KylanC Samba Member
Joined: April 19, 2017 Posts: 67 Location: Long Beach, Ca
Posted: Thu Jun 13, 2019 8:42 am Post subject: Re: Windows down, exhaust fume smell |
I had a problem with this with my squareback. I was leaking oil onto my heater boxes. the smell wouldn't be so bad with the windows up but if I opened or cracked any ventilation it reeked! I fixed my oil leak problem and cleaned my heater boxes and no more smell _________________ 1964 safari beige (L563) notchback 1500 S
1966 Blue Squareback (sold) |
KTPhil Samba Member
Posted: Thu Jun 13, 2019 8:44 am Post subject: Re: Windows down, exhaust fume smell |
One thing to keep in mind is that at moderate speeds and above, there is negative pressure in the car that will draw in fumes. Opening the vent window actually increases this. So all your window, hatch, and body deals have to be in goof shape or you will get various fumes sucked into the car. |
KTPhil Samba Member
Posted: Thu Jun 13, 2019 9:30 am Post subject: Re: Windows down, exhaust fume smell |
A few more ideas from older threads...
Check if the source us the rear hatch by temporarily sealing the hatch perimeter with blue painter's tape.
Check your muffler connections. It is possible for a leak at the "donuts" for #2 and #4 to "inject" exhaust into the heater boxes.
Check the heater fresh air bleed system... those thermostat housings on the body, the 1" hoses and pipes, and their connections.
The heaters do not totally seal when shut off, so pressurized exhaust might make its way inside even if the cables are set to off.
Check your frunk for gas leaks. A slight gas leak can resemble an exhaust leak. The large fill hose, vent lines, and gauge seals are all suspect.
Your hatch seals could be in good shape but still leak if the hatch itself is out of adjustment or bent.
You can check how well your seals work by laying a strip of thin paper across the opening where the seal fits, and close the hatch. Then try pulling the paper out. If it slides easily, it's not sealing. Try it all around the perimeter of the hatch.
A poor engine lid seal will let in fumes, too.
What muffler do you have? The stock outlet was designed to get sucked away from the car. Aftermarkets often get sucked back into the hatch. |
gt1953 Samba Member
Posted: Thu Jun 13, 2019 3:23 pm Post subject: Re: Windows down, exhaust fume smell |
Yep it is the stock muffler. I will try the painters tape around the rear hatch, but feel it is sealed.
When I replaced the muffler, made sure the all of the connection points were sealed up. Gosh I do not like those leaks. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
chrismsnt Samba Member
Joined: March 06, 2018 Posts: 247 Location: Cumming, GA
Posted: Sat Jun 29, 2019 6:15 am Post subject: Re: Windows down, exhaust fume smell |
I'm running this down as well. What I'm currently working on is the fuel pump. Not only does it have a leak but I think it's pushing too much pressure. Thus, gas is ALWAYS in the carbs... dripping when it's shut off. Something to check into on yours...
Chris |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22356 Location: Kimball, Mi
Posted: Sat Jun 29, 2019 9:30 am Post subject: Re: Windows down, exhaust fume smell |
chrismsnt wrote: |
Chris |
In your case, you might want to try a different electric fuel pump. I've been using the Mr.Gasket brand 042S pump available from most everybody (the Zone, O'Reilly's, Advance, Napa), and it's been working just fine without a pressure regulator. I've installed that pump into at least 5 other VW's in the last 10 years. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
gt1953 Samba Member
Posted: Sat Sep 14, 2019 5:56 pm Post subject: Re: Windows down, exhaust fume smell Solved>>>> |
This is what actually works and no more fumes. Minor extension and turn down into more of the air flow. You'll never guess what I used that was laying around, like most of us have.
72 type 1
72 Squareback
