Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Nikon-User Samba Member
Joined: September 13, 2017 Posts: 33 Location: Switzerland
Posted: Fri Jun 14, 2019 2:12 am Post subject: Re: Where did you mount your amplifier? |
Below the seats, there is plenty of space. And you don't need an additional fan...
For the current sound setup, I have an active Pioneer Subwoofer under the seat as well.
The next step will be a 5Ch Amplifier PDX-V9 incl. DSP... This will be hidden under the left rear seat... Due to the fact, that this Alpine Amplifier is a digital one - I don't expect any issue with too much heat. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Sat Jun 15, 2019 10:09 am Post subject: Re: Where did you mount your amplifier? |
Multi69s wrote: |
Occasionally I do have passengers in the back seat. Any issues with them kicking your amp? |
Or stepping on it with their feet under the front seats? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Sat Jun 15, 2019 3:28 pm Post subject: Re: Where did you mount your amplifier? |
Will it fit under the glove box fitted to the strap or maybe under the right front foot plate? I know you can remove the right foot plate although there is not much room under there.
I don't have an amp just the old alpine AM/FM Cassette deck 35 watts per speaker. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13271 Location: Tejas!
Posted: Tue Jun 18, 2019 9:03 am Post subject: Re: Where did you mount your amplifier? |
the new digital amps are awesome, can be mounted upside down, hidden behind door panels, and are really down in size compared to the old class a high current models I used 20 years ago. For amps that I didn't want to display (little ones, not the big coffee table sized amps) I would try to hide them under the front seats, but yes, they would be kicked, stepped on, wires pulled out, so I try to keep my passengers to a minimum. If I had cheap amps I really didn't care about, I think they would last a few years under the back seat. My expensive stuff, probably not _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
bluebullseye Samba Member
Joined: November 30, 2009 Posts: 64 Location: Chantilly, VA
Posted: Tue Jun 18, 2019 9:54 am Post subject: Re: Where did you mount your amplifier? |
I just got my Square on the road and audio is a next step. I'm thinking about a Bluetooth head unit but am not sure what to do for speakers. Would like 4-channel. What are people doing for front and rear speaks? _________________ -------------------------------------------------------
2018 VW Tiguan SE | Black with Golden Oak seats
1972 VW Type III Squareback | Kasan Red
Writer and Independent Publishing Consultant in the DC suburbs: www.johnhmatthews.com |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Absoluteyeti Samba Member
Posted: Wed Jun 19, 2019 7:59 am Post subject: Re: Where did you mount your amplifier? |
I went with a Kenwood KAC-M1824BT 400W 4 Ch mounted under the back seat of my fastback. it's a marine ATV amp so it doesn't require a headunit and it's bluetooth enabled. I'm also planning on installing one in my 68 beetle as well to do away with the headunit in the glove box. |
Posted: Tue Jun 25, 2019 12:05 am Post subject: Re: Where did you mount your amplifier? |
I've been out of the high end audio equipment for a few years, just too much other toys robbing my bank account. One of the head units I was looking at is a JVC (don't have model number handy). It has a blue tooth feature that has an external mic, and a setting that will answer your phone, after a given time that you select. I thought that feature was pretty cool. Half of the time I miss calls, and I just don't feel comfortable trying to find the answer button in certain traffic situations. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
