hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Sun Jun 16, 2019 8:31 am Post subject: Engine Rattle driving me nuts (and bolts) VIDEO |
Over the last couple of weeks I've developed an engine Rattle,
I can't seem to pinpoint where it's coming from,
Also it goes away under load.
Things I've checked :
Took the fan belt off.
Checked for loose tins
Set valves
Checked rocker side play on the left side.
(I have a csp python which makes checking the right side a nightmare)
https://youtu.be/MvH2wrCuBcI
_________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Jun 16, 2019 8:45 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
Check for the pulley tin rubbing on the back of the pulley.
I have a rattle driving me nuts too and I think I narrowed it down to that.
I was just out in the garage loosening the engine tin bolts to push that piece back a little more.
I do have Mario's Crank Trigger in back and that is what would rub first on my aluminum pulley.
I will be out testing it this afternoon. It would drive me nuts if I have to listen to that all the way to California and back in 18 more days..... _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Sun Jun 16, 2019 9:09 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
I hear ya, the sound is making me want to build a new engine 😂 _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Sun Jun 16, 2019 9:28 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
Pinion drive/fuel pump rod someting. Impossible toi say which, but that would be my guess. |
Posted: Sun Jun 16, 2019 9:42 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
Alstrup wrote: |
Thanx, will check that. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
vamram Samba Member
Posted: Sun Jun 16, 2019 10:18 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
If it was the pulley rubbing the engine tin you'd probably have metal filings/dust around the engine bay. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Sun Jun 16, 2019 10:26 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
vamram wrote: |
If it was the pulley rubbing the engine tin you'd probably have metal filings/dust around the engine bay. |
I've checked the pulley and it's not rubbing the tin _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
scubaseas Samba Member
Joined: May 24, 2013 Posts: 442 Location: ME & Texas, in a Bus or on a boat somewhere
Posted: Sun Jun 16, 2019 10:36 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
Missing spring in distributor drive gear?
Does it change noise when you push in the clutch?
Try to locate noise using mechanic's stethoscope or a long screw driver to your ear? _________________ Al
08/1970 T2a Westphalia owned since 1980
ASE Master certification. 50 years pushing a wrench
Retired |
Posted: Sun Jun 16, 2019 10:47 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
Noise stays the same wit clutch depressed or otherwise.
I should also note there is no loss of power what so ever, no shaking, no obvious problems, its pretty quick _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Sun Jun 16, 2019 11:33 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
It doesn't really sound like fan or shroud, but... Can you get a hand around to the back side of fan shroud? (i.e. Front of car.) Not while engine is running, of course, but feel around the fan and check for anything caught between it and shroud or rubbing on shroud? Also, with engine idelling and hands at top or either side of shroud, is rattle affected by putting push/pull force on shroud? |
Posted: Sun Jun 16, 2019 11:39 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
MrGoodtunes wrote: |
I've already checked for a loose shroud, also ran it without the fan belt, also checked the oil cooler doghouse tin on the front of the shroud. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
weasel_ugs Samba Member
Joined: March 16, 2012 Posts: 721 Location: Prescott Valley,Az.
Posted: Sun Jun 16, 2019 11:46 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
Exhaust rattling against the body? |
Posted: Sun Jun 16, 2019 11:48 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
weasel_ugs wrote: |
I've thought about that, it does hit a little, but is more of a thud every once in a while, the Rattle goes away under load _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
jfdestree Samba Member
Posted: Sun Jun 16, 2019 1:15 pm Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
Cam gear failure?
I had it on my engine, new cam gear that was out of round. It was eaten by the steel gear on the crank and start to make some noise on idle only after 300km. |
Posted: Sun Jun 16, 2019 1:32 pm Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
Thanx it's worth checking, I've got about 10.000 km on this cam now.
I will pull the oil pump if it's not the dist drive or fuel pump. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sun Jun 16, 2019 6:53 pm Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
Fn wierd!
It sounds like you have possibly two things going on there.
Have you checked the rocker side play? I have that going on on my engine ATM.
It's a high metallic ticking sound.
I'm gonna fix that while the engine is our for a trans change.
Like you said. The sound persists with the fan belt removed.
Victor mentioned the crank pulley rubbing on the tins. I have that too. When the(aluminum) pulley rubs it makes dust. I have never had a stocker rub on the tin. But I imagine it would make a similar kinda screeching sound. Like in the video.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Mon Jun 17, 2019 5:12 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
I've just been out checking the distributer and fuel pump,
I checked the timing first, I have it set to 7.5 - 28-30 ish
I then removed the dist, no play on dist shaft, spring is in the drive gear, couldn't really feel any play on the drive gear(not sure how to check it's kinda tight in there) checked the fuel pump mounting nuts, they where not very tight, so I tightened them, I reset my timing and LBI on the carbs, I kicked up the idle speed to 900 from 800 and it seems a little bit less rattely, it still rattles though, I guess I'm pulling the oil pump next. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
allamaabroad Samba Member
Joined: September 22, 2016 Posts: 560 Location: South Jordan, Utah
Posted: Mon Jun 17, 2019 8:58 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
Unless you're particularly fond of pulling your oil pump and resealing it, I'd get a mechanics stethoscope or even just a piece of hose and try to find where its coming from. Yeah it sounds bad, but everyone here is just going to be throwing out guesses since we don't know where it's coming from. Have you checked the 1/2 side valve train yet? Idk about you but I'd rather pull a muffler off than pull an oil pump. _________________ Dennis - 1973 Super Beetle ('16-'21)
Debbie- 1970 Baywindow Bus ('21 - Present)
Tin top camper/adventure bus
2180 TW: CNC Panchitos, Beehives Done Right, Web 163, Ultralight Lifters, 1.3 Rockers, CSP Python, Custom Speeduino EFI Conversion with 40mm Throttle Bodies
Distributors are lame
I have a really hard time leaving things alone...
Innovative and affordable engine management systems and EFI conversions for your Vintage VW
Visit https://debbiesaircooled.com/ |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2742 Location: Hamble, Hampshire, UK
Posted: Mon Jun 17, 2019 9:20 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
Look under the pulley down by the drain hole at the bottom ... - something shiny down there ?
Looks like in the video.
In my case it would be a screwdriver or a 10mm socket. _________________ Ancient vehicles and vessels
Posted: Mon Jun 17, 2019 9:34 am Post subject: Re: Engine Rattle driving me nuts (and bolts) VIDEO |
mikedjames wrote: |
In my case it would be a screwdriver or a 10mm socket. |
Nothing there, must be reflection _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
