BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Tue Jun 18, 2019 8:35 pm Post subject: Stripped transmission pan bolt fix? |
Hello,
Just did a transmission fluid flush and filter replacement on my 2000 EVC. When tightening the last bolt on the pan it kept spinning with the torque wrench set to 12nm. Backed out the bolt and sure enough aluminum threads came out with it.
Any wisdom for fixing this particular issue? Don’t want to do any further damage to the case. Thinking heli-coil, or I’ve read of others using a longer bolt with a lock-nut (honestly not 100% sure how that helps). Are the holes much deeper than the stock bolt?
Thanks! _________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
Posted: Wed Jun 19, 2019 7:11 pm Post subject: Re: Stripped transmission pan bolt fix? |
For anyone in the same boat. I measured and the holes are tapped deeper than the 20mm of the stock bolt. Replaced with an M6x25 and it was able to torque it down okay. _________________ Cream Puff
Earl Grey
Marsha Mellow
subdewd Samba Member
Posted: Thu Jun 20, 2019 4:01 am Post subject: Re: Stripped transmission pan bolt fix? |
Great idea, |
