zenith jet diagram
consvws
consvws is offline
PostPosted: Thu Jun 20, 2019 9:58 am    Post subject: zenith jet diagram Reply with quote
I found this pic in the gallery of the screw/jet in question & i'm trying to find out if this goes under the plunger (vertically) or if it goes in the other side under the emulsion tube (horizontally)? I mixed the two up & all i can find are grainy pics of little unidentifiable screws... This is a Zenith 32 NDIX
Danwvw
Danwvw is offline
PostPosted: Sat Feb 08, 2020 3:34 pm    Post subject: Re: zenith jet diagram Reply with quote
Yes the diagram is pretty bad isn't it. It looks like the part shown above is labeled 101 in the diagram below. It's clearly a check valve.
The enrichment circuit emulsion tube jet is labeled 75 below and has no ball, it's a jet. Note: (The Enrichment Circuit Emulsion Tube was not peasant on Porsche Dual Zeniths) however the jet was used.
I have an old NDIX-32 carb here and tried screwing the jet into the valve hole but it starts to bottom out before it's tight. Probably care should be taken to not do that.
I'm pretty sure the part you show above is 101, the accelerator pump inlet check valve.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
wdfifteen
wdfifteen is offline
PostPosted: Sun Feb 09, 2020 6:47 am    Post subject: Re: zenith jet diagram Reply with quote
That's the accelerator pump check valve. It screws up into the carb body near the throttle stop.
