Reverse / backup lights not working with Subaru transmission
Crooked Designer
Crooked Designer is offline
PostPosted: Wed May 08, 2019 12:18 pm    Post subject: Reverse / backup lights not working with Subaru transmission Reply with quote
Anyone solved this problem before? Everything is hooked up properly but back up lights donít go on when shifted into reverse. Does signal from nee Subaru 5 speed trans work the same as oem 4 speed?
Just installed transmission and new Led bulb on all exterior lights. All other bulbs work great. Cleaned all wire connections at tail lights.
'85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit
MarkWard
MarkWard is offline
PostPosted: Wed May 08, 2019 12:41 pm    Post subject: Re: Reverse / backup lights not working with Subaru transmission Reply with quote
First step would be to unplug the switch and bridge the connectors on the harness and see if the backup lights work. My syncro conversion had inop backup lights, but I was switching from an automatic to a syncro transaxle. Figured I must have miss wired something. In the end, both bulbs were burnt out. Easy fix.
If jumping the harness connectors works the backup lights, you have a problem with the Subaru switch. The vanagon switch completes the connection through the harness. The Subaru would need to do the same. Sorry on Subaru experience.
1982 Vanagon Camper with ALH TDI.
1990 Vanagon Camper Syncro.
In Car https://youtu.be/5hbfdUJR88Q
Crooked Designer
PostPosted: Wed May 08, 2019 4:45 pm    Post subject: Re: Reverse / backup lights not working with Subaru transmission Reply with quote
Thanks Mark,
Odd thing is that after more tinkering in certain config, you can get the lights to light up, but only when NOT in reverse (so I know the bulbs are good, as is the wiring) I guess you're right and this is probably more of a subaru question. I'll do some research there.
Anyone else with a Subigears 5spd transmission solved this problem?
Boxer Rebellion
Boxer Rebellion is offline
PostPosted: Wed May 08, 2019 7:38 pm    Post subject: Re: Reverse / backup lights not working with Subaru transmission Reply with quote
I have subi 2.5 conversion, and have the same problem. I cannot figure out why rear back up light is not working. So will be following your post.
MarkWard
MarkWard is offline
PostPosted: Thu May 09, 2019 5:31 am    Post subject: Re: Reverse / backup lights not working with Subaru transmission Reply with quote
An ohm meter should confirm how the switch is working. How many terminals does the switch have? How about a picture?
danfromsyr
danfromsyr is offline
PostPosted: Thu May 09, 2019 7:34 am    Post subject: Re: Reverse / backup lights not working with Subaru transmission Reply with quote
on standards VW grabbed the supply power for the Reverse lights from the engine compartment. this connection may have been dropped by the 'professional' who did your conversion.
on Automatics the Reverse is triggered up at the shift console. I presume it gets it's power from up front and shouldn't be impacted by a engine swap.
peteguenther
peteguenther is offline
PostPosted: Sat Jun 29, 2019 5:11 pm    Post subject: Re: Reverse / backup lights not working with Subaru transmission Reply with quote
well here's a thing that happened to me just now- noticed rapid blinker action, and no backups and that tail and blinker lighting was reversed. I had just painted the vanagon and turns out it's possible to install tail assemblies upside down and on wrong sides! I assumed the one way plug prevents this but it doesn't if the assemblies are on wrong sides and upside down w backups on the bottom.
Binolardo
Binolardo is offline
PostPosted: Sun Jun 30, 2019 10:05 am    Post subject: Re: Reverse / backup lights not working with Subaru transmission Reply with quote
My transmission came from a 2005 legacy donor. Since the reverse switch are electrically similar, I juste connected the same two wire. I know it doesnít help much, but on the transmission side, it should be the same for both transmission. To the best of my knowledge.
