ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6361 Location: Honolulu,Hawaii and France
Posted: Thu Jun 27, 2019 12:44 pm Post subject: Re: Troubleshooting vanagon digital clock |
I had to troubleshoot one recently, I never figured out if the chip is good or not.
New screen got installed with a GW printed circuit by the owner, I thought it had been done incorrectly, I redid it. Nothing. I saw a partial screen real quick, that was it...
Following up, as I never saw one go bad besides the screen.
Some of them do run faster somehow, I wonder how to adjust the screw.. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Thu Jun 27, 2019 12:20 pm Post subject: Re: Troubleshooting vanagon digital clock |
I am not sure about the connector of the GW clock. The OEM on mine works perfectly out of the cluster, connected directly to a battery. Once on the cluster it's not working...
so.. it turns out that the 2 tiny push-in pins (in the white plastic case) are not connecting.. I took the pins out, squeeze them to make then tighter and they are working... |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Thu Jun 27, 2019 11:51 am Post subject: Re: Troubleshooting vanagon digital clock |
Follow the "wire" in the blue foil, it might be damaged somewhere. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
baltik Samba Member
Posted: Wed Jun 26, 2019 10:56 pm Post subject: Troubleshooting vanagon digital clock |
So I finally decided to replace my long deceased digital clock with a shiny new gowesty unit... to my unpleasant surprise the clock remains stubbornly dead. I tested it by connecting it to a 12v source directly and it lights right up. I am getting continuity to pins 5 (clock) and pin 3 (ground) on the 14 pin connector any ideas in where to look next? |
