bluebug66 Samba Member
Joined: June 28, 2005 Posts: 239 Location: Tennessean
Posted: Fri Jun 28, 2019 1:11 pm Post subject: I am now totally dripless |
For the past several months I have been totally dripless for the first time. I changed my strainer plate out to the later model solid plate with no drain plug and am using German strainer gaskets. I also am using Gasgacinch on my valve covers with German cork gaskets and these have been dripless. It is nice to not have to remember to put a piece of cardboard under the engine when it is parked in the garage or driveway. Not bad considering all of the places that a VW engine can drip oil. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Fri Jun 28, 2019 1:15 pm Post subject: Re: I am now totally dripless |
Check your oil level. You might out.
Good Job. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
bluebus86 Banned
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
FL-Frank Samba Member
Joined: August 08, 2015 Posts: 823 Location: Jupiter, Florida
Posted: Fri Jun 28, 2019 5:30 pm Post subject: Re: I am now totally dripless |
Congratulations, good for you!
I’ve had good luck with the silicone valve cover gaskets from WW. I also just replaced the leaking main oil seal last week...with no new evidence of leaks on the drip pan.
However, I still get one spot of oil on the drip pan under the breather tube, but only intermittently. I drive the car almost every day, but the breather tube drips a drop or two only about once a week. _________________ “Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD |
Posted: Fri Jun 28, 2019 5:54 pm Post subject: Re: I am now totally dripless |
EverettB wrote: |
bluebug66 wrote: |
I changed my strainer plate out to the later model solid plate with no drain plug |
Was the center plug leaking? I've never had that plug leak on any VW |
I think so. Hard to tell sometimes where it is leaking. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Fri Jun 28, 2019 5:56 pm Post subject: Re: I am now totally dripless |
67rustavenger wrote: |
Good Job. |
Good one. _________________ Glenn
Member #1009
#BlueSquare |
