Emergency Brake Cable on 55
tehillah1
tehillah1 is offline
PostPosted: Mon Jul 01, 2019 7:19 am    Post subject: Re: Emergency Brake Cable on 55 Reply with quote
I appreciate you guys with experience and patience sharing your work-arounds and builds here...keeps us less experienced folks plugging along...gotta love the Samba
ConcreteAce
ConcreteAce is offline
PostPosted: Sun Jun 30, 2019 10:06 pm    Post subject: Re: Emergency Brake Cable on 55 Reply with quote
I think the issue was due to the later backing plates. What I did to fix it was to remove the end that has the grease fitting I then cut a one inch section out of the rubber wrapped steel tubing then re clamped the end back on. That gave ne plenty of extra up front to adjust the e brake properly. It was a PITA to cut the tubing away without cutting through the cable.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build
tehillah1
PostPosted: Sun Jun 30, 2019 5:58 pm    Post subject: Re: Emergency Brake Cable on 55 Reply with quote
Don't know about the bent tube but if the cable moves good in the tube you can have a longer one made up at an aviation place that does this kind of work for private airplanes...I had to get both of mine remade on my '55. I got them made up with threaded adjusters on both ends, to exact length to work with the disc brakes on the rear...
ConcreteAce
PostPosted: Sun Jun 30, 2019 12:43 pm    Post subject: Emergency Brake Cable on 55 Reply with quote
Ran in to an issue with the E brake cables that run to the front on a 55. The passenger side the e brake cable sticks out far enough to get the hardware on. The driver side cable is only sticking out about 1/4 if that , you can barely get a nut on it much less the brackets. I thought maybe one cable was shorter than the other so I pulled both out, both measure the same. I then stuck the passenger cable into the driver side and it still only sticks out about 1/4 inch. Could the tube inside of the tunnel be bent down causing the cable to be shorter, acting kind of like a bowden tube acts? Does anyone have an idea what my issue might be?
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
