spacebiscuit Samba Member
Posted: Mon Jul 01, 2019 2:04 pm Post subject: Intertia Seat Belt Mount |
I have purchased some aftermarket inertia seat belts, unfortunately they do not seem to fit the official VW seat belt mounts which were made for the american market: 211-809-257
https://www.justkampers.com/vw-t2-bay-window-parts...-1979.html
There are two small holes to mount the seat belt housing too - see my picture below which shows they do not match up.
I was thinking perhaps I could drill a single hole (same size as the hole which bolts to the bus) to attach the housing. Is this safe and/or advisable? _________________ 1972 Type 2 1600cc
1990 MKII Golf 1.6 CL |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jul 01, 2019 3:05 pm Post subject: Re: Intertia Seat Belt Mount |
I don't see why not, make sure the new hole is located at least 1.5 times the hole diameter away from an edge or another hole. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Mon Jul 01, 2019 8:06 pm Post subject: Re: Intertia Seat Belt Mount |
Look around this website
https://www.seatbeltsplus.com/
I’ve bought many 3point belts with the separate mounting hardware and installed in buses. Keep in mind that you need extra long belts or extensions to work. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2922 Location: San Diego, CA
Posted: Tue Jul 02, 2019 12:13 pm Post subject: Re: Intertia Seat Belt Mount |
I recently purchased and installed these belts in my '68. They come with a simple L shaped mounting bracket when you pick the bus option. These are not extra long and do not require extensions. The stalks are longer than the stock setup and fit well.
https://www2.cip1.com/ProductDetails.asp?ProductCode=C45%2DRBT%2D3PTEU%2DBLK%2DKT |
