pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Tue Jul 02, 2019 12:14 pm Post subject: Next stroker... Not! |
Finally got around to taking the “shakalaka” apart. So far there’s no clear tell tale sign as to why it was shakalaking but maybe as I get to tear it apart more, I might find something. Anyway, the original idea for this motor was to rebuild it and pass it on but now I’m more inclined to keep it. This “mystery” motor had run good even with the banging noise. Now upon close inspection of the case, it has bushed lifter bores and aside from a bent pushrod tube it didn’t leak! So I’ll be building me yet another 1800 stroker using it as a good base!
The heads look okay.
Had a dished cam.
The pistons are dished too and had shims on the cylinders.
The bearings showed some serious wear though.
_________________ Some people are so busy being clever they don't have time enough to be wise.
turbo_g Father of Samba Cookie Lover
Joined: October 30, 2002 Posts: 717 Location: Laguna Hills, Ca
Posted: Tue Jul 02, 2019 1:23 pm Post subject: Re: Next stroker... |
That motor got The Hatch all the way to BBB (Havasu) and all the way to Twin Lakes (Bridgeport CA) from Orange County.
Noisy as hell, but did not leak, and ran pretty strong. That's AFTER it sat on the side of my house, for 5+ years under a picnic table cloth.
These little motors are amazing.
Those bearings look terrible. _________________ Turbo_g
66 TinTop Westy SO42
63 Sub-hatch Westy SO33
SV2s Member #425
"Three out of four voices in my head say 'Go for it'." |
srfndoc Samba Member
Posted: Tue Jul 02, 2019 4:47 pm Post subject: Re: Next stroker... |
Sometimes those mystery motors just keep on chugging.... _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
pyrOman Fire Master
Posted: Thu Jul 04, 2019 4:04 pm Post subject: Re: Next stroker... |
After cleaning it up, I found the “source” of the shakalaka noise...
Apparently this motor had similar issues before it’s last rebuild.
The rebuild was based on a universal case or a type 3 one. Here’s a riveted tag from whatever place did it...
Anybody familiar with this kind of stuff done by a rebuilder?
Brass inserts and only on the bottom studs?
Also, notice the case half differing numbers!?!
The heads have obviously gotten some work done. But at least weren’t leaking and are not cracked!
I think the heads were shaved some and that’s why the motor required shims on the cylinders. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Thu Jul 04, 2019 4:54 pm Post subject: Re: Next stroker... |
The left and right side casting numbers dont always match, should be a hand stamped number on both halves by the bellhousing that are supposed to match though _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Danwvw Samba Member
Posted: Thu Jul 04, 2019 5:36 pm Post subject: Re: Next stroker... |
Your engine looks almost like you could just clean it up and put new bearings and seals in and put it back together for more miles. How does the crank look sometimes they can just be hand polished.
I have not seen brass cylinder stud inserts. I would think steel inserts would be better.
Generally bronze lifter bores are a good Idea to repair worn lifter bores. Check them that the lifters don't have any wobble.
Case looks pretty good. If the thrust bearing the #1 main at the flywheel bearing fits tight then it likely won't need an align bore. Check the case for fretting where it's main journals meet. You can plastigauge to check that it will hold the main bearings tight still. I would just grind out that bad spot above that cylinder opening inside.
Heads will clean up nice if soaked in (super clean) overnight. Then wire brush in a drill to remove the remaining carbon in the combustion chambers. Then if there are cracks in the heads at the spark plug or valves or if the spark plug threads are questionable I would replace the heads. You will need to remove the valves to see how much play they have in the guides. A good vw machinist has a tool that can knurl valve guides for another life if need be but if too worn they should be replaced. Keep the lifters matched to the cam lobes otherwise replace the lifters with new ones
Figure out for sure what was banging. I would think this would have quit banging after a while.
But This Piston would not quit bangging if it was hitting the head there. Stock lifters are inexpensive.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
pyrOman Fire Master
Posted: Thu Jul 04, 2019 8:59 pm Post subject: Re: Next stroker... |
Thanks!
Heads are looking really good for a “questionable” engine. I do have a new stroker crank that will go in it as well as a special grind cam. So next is an order for stroker pistons, connecting rods, lifters and bearings.
On that note, though I did measure the case already, what do you make out of the markings on the existing bearings?
Braukuche Samba Member
Posted: Thu Jul 04, 2019 11:11 pm Post subject: Re: Next stroker... |
So the rods were hitting the case?? What was causing the noise? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
pyrOman Fire Master
Posted: Fri Jul 05, 2019 7:14 am Post subject: Re: Next stroker... |
Braukuche wrote: |
So the rods were hitting the case?? What was causing the noise? |
Just the #2 and a tiny bit as you can see. I can’t see any marks on the rod bolt though. It’s truly amazing that this motor had been knocking for as long as it did and still kept running strong!
I’ve yet to pull the rods off the crank or the rest of the bearings but the thrust bearing looks okay compared with the center split one which looks way beyond wore out. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Fri Jul 05, 2019 7:35 am Post subject: Re: Next stroker... |
pyrOman wrote: |
Thanks!
First over or .010". Interesting that is has lifter bore inserts. Check the stamp at the top of the case on the flywheel end to see if the case halves match. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Fri Jul 05, 2019 8:23 am Post subject: Re: Next stroker... |
Bulli Klinik wrote: |
pyrOman wrote: |
Thanks!
First over or .010". Interesting that is has lifter bore inserts. Check the stamp at the top of the case on the flywheel end to see if the case halves match. |
and also: no elephants were harmed in the making of this bearing _________________ regards
Uli
pyrOman Fire Master
Posted: Fri Jul 05, 2019 10:42 am Post subject: Re: Next stroker... |
Now I am really interested in finding out exactly who rebuilt this motor!
Not to claim anything since I’m sure is way past any kind of warranty, but I keep finding stuff done to it that seems very odd but has run so damn good!
So, this morning in measuring the case and crank to order a set of bearings I found this!?!
Bearings come in a specific set of dimensions for standard (stock or not machined) and machined to set cuts. Well, the case has been cut for the thrust journal to ONLY 0.75mm instead of the normal 1.00mm underside cut. So the rebuilder slapped a 0.75mm shim on a bearing with a standard size of 22.00mm! Who does that? _________________ Some people are so busy being clever they don't have time enough to be wise. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
pyrOman Fire Master
Posted: Fri Jul 05, 2019 1:57 pm Post subject: Re: Next stroker... |
But wait, there’s more! Found this bit of debris right in the oil hole of the small bearing!
Here’s the markings on the crank...
pyrOman Fire Master
Posted: Fri Jul 05, 2019 2:01 pm Post subject: Re: Next stroker... |
Close but no ceegar! _________________ Some people are so busy being clever they don't have time enough to be wise. |
