Do you have a fan belt guard on your exposed engine buggy? |
Yes |
55% |
[ 19 ] |
No |
44% |
[ 15 ] |
Total Votes : 34 |
YDBD Samba Member
Joined: February 25, 2017 Posts: 890 Location: Bavaria, Germany
Posted: Mon Jul 22, 2019 6:35 am Post subject: Re: Fan Belt Guard or not? |
Only running one because it's the same one my dad ran on the buggy '69. I like the look of them, but the rubbing and being able to check belt deflection and adjusting valves with one on is another thing in the way.
_________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
EVfun Samba Member
Posted: Sun May 31, 2020 2:01 pm Post subject: Re: Fan Belt Guard or not? |
Hot Air wrote: |
I like the vintage style |
While working to fit the lower deflector tins that bolt to the bottom of the cylinder tins I noticed something. My fit problem is the ends that go under the exhaust ports. It seems clear the cylinder tins end a little too high. I noticed those ends are cut on your rear cylinder deflectors. So I'm wondering, did you find that same fit problem? Did you have to make a similar modification to your sled tins? Is your engine aftermarket tin, like mine? Thanks! _________________
Wildthings wrote: |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4026 Location: NW Washington
Posted: Sun May 31, 2020 6:31 pm Post subject: Re: Fan Belt Guard or not? |
Put a nice baja style bumper on it....it will serve many purposes.
I prefer using a turbo to hide the belt....... :lol
Here is just the bumper....I have a hitch, oil filter and the license plate mounted to it.
You would have to purposely reach in in order to get caught in the belt.
CIP1 carries the bumper......
It also protects the back of your buggy.....I got rearended on my trip to Cali this past summer and it saved my turbo and engine from damage.....we were able to continue on instead of getting it loaded on a trailer and hauled home.
Here you can see how far it got bent up......it was straight when I installed it....
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
