jeremypbeasley Samba Member
Joined: September 18, 2018 Posts: 164 Location: Seattle, WA
Posted: Wed Jul 03, 2019 9:53 am Post subject: Grinding transmission after engine swap 😫 |
Dear internet,
I’ve just completed my first ever engine swap and rebuild of everything outside the heads and block. Put it all back together, set the timing, and it sounds great. Original transmission with no known issues and fresh oil.
Like a cold bucket of water over a hot shower curtain, when I went to shift into gear I realized my work wasn’t done.
When I press the clutch and shift into any gear, the transmission grinds just like I hadn’t pressed the clutch at all. I immediately assumed it was a bad slave cylinder or that the throwout bearing had come loose during install.
I took the transmission off and checked everything. Throwout bearing was clipped on fine. Slave was operating with the pedal as expected.
I put the transmission back on with the shift linkage connected (without the CVs connected and still on jack stands) and cranked it back up. Shifted in and out of gears just fine. Slave and pedal were operating just fine too.
A few minutes later, I attached the CVs, dropped the jack stands, and cranked it back up.
Grinding! Same as before. Anytime I try to put it in gear.
I’m at a loss.
My only current suspicion is that it has something to do with the shift linkage and somehow the shift lever on the transmission is not moving fully into gear. So I had my friend shift it with the engine off while I watched the shift linkage underneath. It appears to be working just fine, with only a little toughness shifting into second gear.
Any clue what could be wrong?
Thank you forever and ever. |
danfromsyr Samba Member
Posted: Wed Jul 03, 2019 10:14 am Post subject: Re: Grinding transmission after engine swap 😫 |
what swap did you do?
a VW inline 4cyl?
did you trim the input shaft on the transaxle. _________________
Abscate wrote: |
?Waldo? Samba Member
Posted: Wed Jul 03, 2019 10:18 am Post subject: Re: Grinding transmission after engine swap 😫 |
Have you tried bleeding the clutch? |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9936 Location: Orbiting San Diego
Posted: Wed Jul 03, 2019 10:24 am Post subject: Re: Grinding transmission after engine swap 😫 |
Did you put a new clutch pilot bearing in the end of the crankshaft?
Mark |
Posted: Wed Jul 03, 2019 10:54 am Post subject: Re: Grinding transmission after engine swap 😫 |
Haven't tried to bleed the lines. Total shadetree over here. Doing that this afternoon.
Replaced/swapped it with an '85, 1.9 4 cylinder just like it had before.
I've replaced a pilot bearing before but I didn't have one handy when I put the new engine on. With the existing pilot bearing new and spinning nice and easy, I just left it. Foolish, I suppose. Would that really prevent any shift? |
Destructo Samba Member
Joined: July 31, 2006 Posts: 405 Location: Westhampton, MA
Posted: Wed Jul 03, 2019 11:23 am Post subject: Re: Grinding transmission after engine swap 😫 |
You obviously understand the components you're working with but something must not be lining up correctly.
You say it shifted fine in and out of gears without the CVs on. Did you confirm the axle output flanges turned as well and you're sure you tested it with the engine running before the CVs were attached?
If that is correct, you may need to recheck your 4 bellhousing to engine studs after you lower the vehicle back down. That may be pushing things out of alignment especially if the studs aren't fully tightened. _________________ 1985 Wolfsburg Edition Westfalia Camper Bostig conversion
Dude, where's your van? |
Posted: Wed Jul 03, 2019 11:36 am Post subject: Re: Grinding transmission after engine swap 😫 |
Right on. I’m also gonna try lifting with the axles still on and see if it persists.
Here’s the slave in action. Does this look like the proper range of motion?
http://drp.mk/i/13w484Lt16 |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Posted: Wed Jul 03, 2019 1:08 pm Post subject: Re: Grinding transmission after engine swap 😫 |
I don't know that I would be able to tell visually between the range of motion of the clutch lever on a properly working one vs. one that does not quite give the proper range of motion for easy shifting.
It makes sense to me that it would shift without the CVs attached but not afterward. Without the CVs attached, the output side can adjust itself as the gears are meshing. I haven't ever tried to shift with the engine running without CVs attached, but imagine it might be doable without even using the clutch. The added inertia of just the driveshafts and wheels even if off the ground might be enough to prevent it from shifting if the clutch is not decoupling the engine and trans.
I would also mention that I did once have a clutch master cylinder fail in the way that is described. The clutch pedal still felt normal and the lever on the trans moved, but did not move far enough to decouple the engine and trans and allow smooth shifting.
If I were in the OPs situation I would bleed the system first to rule out air in the fluid as the culprit and then if it still will not shift and the slave does not leak, then I would replace the master. |
Posted: Wed Jul 03, 2019 1:47 pm Post subject: Re: Grinding transmission after engine swap 😫 |
Thanks Waldo!
My checklist for tonight:
- Bleed any air out of the slave cylinder (simple bottle/tube method)
- Top off brake fluid if needed (Dot4)
- Recheck 4 bellhousing to engine studs and bolts, torque to spec
If nothing else prevails....
- Replace pilot bearing
- Replace master cylinder |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Wed Jul 03, 2019 2:15 pm Post subject: Re: Grinding transmission after engine swap 😫 |
I would start it in gear with the clutch pedal depressed. If the van starts and idles, that might indicate that the clutch is working. If something other than that happens, the clutch might have a problem.
If you do pull the transmission make sure the clutch disc slides freely on the input shaft. I will use a “film” of grease so the splines are not dry. _________________ ☮️ |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9613 Location: Western WA
Posted: Wed Jul 03, 2019 3:25 pm Post subject: Re: Grinding transmission after engine swap 😫 |
Agreed on the attempt to spin the engine with trans in (4th) gear. If the starter can turn the engine at all then the clutch is releasing, but not enough.
Is the engine 100% mated to the tranny?
No gap between the engine & bellhousing? Look for a gap near all four engine studs. _________________
....KTMs, GasGas, SPOT mtb |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4791 Location: Bemidji, MN
Posted: Wed Jul 03, 2019 6:33 pm Post subject: Re: Grinding transmission after engine swap 😫 |
MarkWard wrote: |
If you do pull the transmission make sure the clutch disc slides freely on the input shaft. I will use a “film” of grease so the splines are not dry. |
just to build on this for those doing clutches, old BMW motorcycles used a dry car type clutch but the splines were subject to corrosion and subsequent wear. many magic formulas have been persued as a 'spline lube' that would be persistent, rust resistant, lubricitous, and not fling off. typically, this would be a moly lube like "Honda Moly 60" applied very thinly to the input shaft splines with a toothbrush. for a short period there was an independent blender that made 'Guard Dog' lubes for splines and it is/was excellent stuff. In short, lubing the shaft can make a dramatic difference in clutch ease and feel, it did on my airhead as well as my 091/1.
this isn't likely the OP's major problem BUT it is something to do while in there. _________________ -dan
www.thefixitworkshop.com
jberger Samba Member
Posted: Wed Jul 03, 2019 7:41 pm Post subject: Re: Grinding transmission after engine swap 😫 |
shift lever bracket installed on the correct side of the transaxle boss?
J |
Posted: Tue Jul 09, 2019 3:33 pm Post subject: Re: Grinding transmission after engine swap 😫 |
Back at it.
Back bled the slave line, no air in the lines. Bolts from engine to bell housing were still torqued to spec. Fluid was and still is just above max in the reservoir.
Starts in gear with the wheels off the ground just fine.
I have no reason to believe that the slave or master are malfunctioning.
My only conclusion is that my pressure plate or clutch disc are damaged from only five miles of driving on my old engine that I ditched for what was ultimately excessive end play on the flywheel. Eternally bummed.
Guess the transmission is coming off again. Any other bright ideas? |
Posted: Tue Jul 09, 2019 3:51 pm Post subject: Re: Grinding transmission after engine swap 😫 |
Why do you assume it is the clutch/pressure plate as opposed to the clutch master cylinder? It seems to me that the clutch master is more likely to fail than the pressure plate. I don't see how excessive end play would damage the pressure plate and certainly not in 5 miles. I've had a clutch master fail simply from the vehicle sitting. I've never had a pressure plate do so. As a final point of logic, changing the clutch master cylinder is both less expensive and a whole lot less labor than replacing the pressure plate/clutch disc. I'm not saying it IS the clutch master cylinder, but it makes more sense to me to replace the cheaper and easier to change part than to start with the more expensive and harder to change part. I'd rather change the master and find out it was an issue with the clutch pressure plate/disc then find out it was the master cylinder after putting in the labor and expense of changing the pressure plate and disc. |
Posted: Tue Jul 09, 2019 3:55 pm Post subject: Re: Grinding transmission after engine swap 😫 |
The test I described was with the wheels on the ground not in the air. Did you install the clutch disc backwards? _________________ ☮️ |
Posted: Tue Jul 09, 2019 3:57 pm Post subject: Re: Grinding transmission after engine swap 😫 |
Fair points. I suppose my logic is that I assume anything I touched (clutch kit) is more likely to be the source of the problem than something I didn’t (master cylinder).
I’ll see if I can find someone with the part locally and give it a shot. |
Posted: Tue Jul 09, 2019 3:59 pm Post subject: Re: Grinding transmission after engine swap 😫 |
MarkWard wrote: |
Did you install the clutch disc backwards? |
That's an interesting thought. |
Posted: Tue Jul 09, 2019 4:04 pm Post subject: Re: Grinding transmission after engine swap 😫 |
?Waldo? wrote: |
MarkWard wrote: |
That's not really feasible. The disc hub protrudes too much on the front side to allow the pressure plate bolts to start if turned around.
J |
