LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5506 Location: 1st Coast
Posted: Fri Jul 05, 2019 7:04 am Post subject: Help getting the bloody vent window seal in my door frame |
The front door window frame weather strip was not as bad to install yesterday as I thought but the vent seal is another story. Seems I have mixed up my kit with some other vent seals from years ago. I reached out to Bustoration to figure which are Ronnie's the set labeled Wolfsburg West or West Coast Metric, I'll guess Ronnie's are the West Coast Metric. I have never had a problem with Ronnie's seals so I want to be sure I use them.
corner seems to flip over, I'm searching images and it appears to be normal
Not sure if the vent seal actually fits around this piece or I am supposed to cut some rubber?
took a while to figure which way this vent window flap seal goes in and I'm pretty sure this is correct.
Thank god for this WW exploded view but I have to search for videos.
My biggest challenge is the vent seal today, is this the best corner to start it?
I'll assume the felt seals can go in at anytime?
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Fri Jul 05, 2019 7:31 am Post subject: Re: Help getting the bloody vent window seal in my door frame |
It appears this image from Scandell's 2007 thread that there should be some kind of slice in the vent seal to allow for the metal tab? Heading out to look now as I'm installing the door window frame weatherstrip & vent window flap seal on the other frame this morning.
from thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 _________________ American Red Cross Safe And Well:
Maui Roadsters
Lind wrote: |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Fri Jul 05, 2019 8:19 am Post subject: Re: Help getting the bloody vent window seal in my door frame |
LAGrunthaner wrote: |
that amount of "flipping over" is not "normal", and a sign of the seal not relieved of "tension". the seal doesn't look fully/properly seated in the channel either.
you sure took the difficult way to install that seal. no lubrication, and not sliding it through? wow, you must like torture.
i can see the channel is rust pitted, but that is not an excuse for the seal being all bent over in the corners.
There will be a little "flipping over" but nowhere near what you are showing.
i just put this seal the other day. it's all lovely and floppy, not under 'tension', can slide it forward or backward, loading up or removing tension as necessary. i'll do the crimping of the channel after it's been in the bus a little while and any minor adjustments are made.
_________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Fri Jul 05, 2019 12:03 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
I recently did the internal vent wing seal and the door tops. Like mentioned about that isn't normal if you haven't relieved the tension on seal. You will need to cut a slit in the rubber for your vent wing tab. I used a bicycle lever made by park to help massage the seal into the groove. I'll see if I can find the pictures I took during my installation. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Fri Jul 05, 2019 1:19 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
Everything mentioned above plus Vaseline! Use it liberally. It works great and unlike some other lube options, it won't become lube again when it gets wet while driving in the rain one day. _________________ Brandon |
oakman Samba Member
Posted: Fri Jul 05, 2019 1:33 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
Like Hazetguy said, that outside rubber scraper should slide right into that channel from the end with plenty of lube and careful pulling.
Carefully check the profile of that rubber scraper, it is designed to only go one way for a proper seal against the body of the bus.
The way you're doing it in the pic would be a nightmare.
Also, if that channel has even a little bit of the old rubber in it it will prevent the new one from being "pulled through". _________________ Brandon
Posted: Fri Jul 05, 2019 1:55 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
I know why the rubber has bent so badly, I pulled the rubber so it could thin out a bit then pushed it in with my plastic orange tool in the image thinking it would eventually contract. I was clearly wrong. There is nothing in the slot but I couldn't imagine being able to slide it in. I think I'll remove this and try again.
oakman wrote: |
Like Hazetguy said, that outside rubber scraper should slide right into that channel from the end with plenty of Vaseline and careful pulling.
Also, if that channel has even a little bit of the old rubber in it it will prevent the new one from being "pulled through". |
Looking at the diagram #50 it looks the same on both sides. I'll take a better look and add a photo of mine.
So I am supposed to cut a slot out for this?
Maui Roadsters
Lind wrote: |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Fri Jul 05, 2019 2:04 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
Yes. Should have a “mark” as to where to do it. _________________ Some people are so busy being clever they don't have time enough to be wise. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Fri Jul 05, 2019 3:29 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
Yes. It might be hidden a bit
This is a 63 so slightly different than yours (no metal clip at the top of the sliding divider but the rest should be similar.
https://www.thesamba.com/vw/forum/viewtopic.php?p=8210143#8210143
Scroll down to the DOOR WINDOW FRAME REASSEMBLY section |
Posted: Sat Jul 06, 2019 7:18 am Post subject: Re: Help getting the bloody vent window seal in my door frame |
nlorntson, I don't see that hole on mine but very helpful image
Any clue last to which side I should start first the upper corner or the lower corner. Personally I think either corner will be a beast as I have been struggling with getting it to seat.
Mine a closeup:
nlorntson wrote: |
Maui Roadsters
Lind wrote: |
pyrOman Fire Master
Posted: Sat Jul 06, 2019 7:28 am Post subject: Re: Help getting the bloody vent window seal in my door frame |
You MUST use all three of these:
Patience
Force
Determination
Without any one of them you’ll eventually give up on the job. I’ve done a few buses now and by far the vent window rubber is the absolute worst to deal with, including the removal of the old caked up one! The pop out windows are a very close second. Anyway, good luck on them. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Sat Jul 06, 2019 7:37 am Post subject: Re: Help getting the bloody vent window seal in my door frame |
Linda, get yourself a tool like the white one in the picture. I've found them on Amazon. It makes all the difference!
Posted: Sat Jul 06, 2019 10:44 am Post subject: Re: Help getting the bloody vent window seal in my door frame |
"Linda, get yourself a tool like the white one in the picture."
looks like she has something equivalent (orange in her pic). you can also use blunt tipped plastic bicycle tire levers.
for what it's worth:
i have always installed the vertical vent widow seal (#37 on the WW diagram) after installing the larger seal (#36).
it's very easy to slide/push it (#37) into the ends past the larger seal (#36) after the larger seal has been installed.
and that way it (#37) doesn't interfere with proper seating of the larger seal (#36) when trying to install that.
installing the large seal (#36), i start at the bottom, working around to the top, leaving that little section that fits over the upper vent window pivot tab until last and the seal is adjusted for a good fit. then i cut the slot where the tab actually is, and then lip the rubber over the tab.
i'm assembling two window frames at this time too. use talc powder to aid with installation. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
Posted: Sun Jul 07, 2019 2:43 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
hazetguy, thanks for the tips #36 first and starting at the bottom then the vertical #37. Using talc is different, I may try it. Wish I had "man hands" for this job.
hazetguy wrote: |
i'm assembling two window frames at this time too. use talc powder to aid with installation. |
Maui Roadsters
Lind wrote: |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Sun Jul 07, 2019 3:56 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
Hysterical episode. |
Posted: Sun Jul 07, 2019 5:30 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
apply liberally. you're not going to hurt anything, it makes installation and moving the seal(s) a bit easier, and it cleans up fast.
hazetguy: invested?
Posted: Sun Jul 07, 2019 5:40 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
when you get to this point and everything is installed and the frame is bolted to the door, take note of this:
the upper seal will want to curve and tuck in against the body. you'll want to run something like the plastic tool you used to install seals, or perhaps a wooden dowel or popsicle stick along / behind the upper seal, to make it "flip" outward. it will really want to tuck in along the front part of the window frame.
once you get the seal facing "outward", and there are no gaps (which is why it is important that the corners don't curl under so dramatically), you will want to leave the door closed for several days (the longer the better!) so the seal will take shape. this will take some time, and you will probably need to correct it for a while, but it does make a long term difference in the way the seal takes shape and seals, so it's worth the effort. again, use talc in the opening and on the seal to help it "form".
these are "after" shots of how the seal should conform to the body, after it has been "untucked" from curling inward.
looks like there is a gap, but there really isn't.
hazetguy: invested?
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Sun Jul 07, 2019 8:14 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
I use cornstarch instead of talc. I like the way it slides better than talc. Don't get either of them wet, at all! _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Tue Jul 09, 2019 1:49 am Post subject: Re: Help getting the bloody vent window seal in my door frame |
Thanks so much hazetguy for this advice, funny thing because I have purchased 2 sets one from Ronnie of Bustoration and the other from Wolfsburg West I emailed WW asking for tips also and they replied with my own thread LOL way too funny. Your images are super helpful and now that I'm back to work I'll have to move quickly as I need them hot in the sun. I'm surprised you didn't chip your paint installing and I have decided not to allow any of my chipping slow me down as it has for years.
hazetguy wrote: |
j.pickens, I will pick up some cornstarch today and update tonight, I like your tip about the slide factor.
j.pickens wrote: |
I use cornstarch instead of talc. I like the way it slides better than talc. Don't get either of them wet, at all! |
Maui Roadsters
Lind wrote: |
Posted: Tue Jul 09, 2019 4:45 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
Hazletguy and others who have soldiered through the vent seal from hell, any other tips it appears when I get what I think installed on one side I go to the other side and I'm not in the track. Any tips on getting both sides together at the same time or am I not thinking this through properly?
j.pickens I tried the cornstarch and it seems better than greasy products.
Hazletguy I pulled out the end of the other seal #37 although not all of it so I could get #36 in.
Looks almost right on this side.
After I get this side I flip to the other side and it's as though I did nothing. Should I make something to get both sides in simultaneously? Or am I just not approaching this correctly?
Maui Roadsters
Lind wrote: |
