LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Wed Jul 29, 2020 2:40 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
This is the trouble area, has anyone cut the seal down to get it to fit in that slot between the latch tab?
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1658 Location: Budapest, Hungary
Posted: Wed Jul 29, 2020 8:54 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
The trouble is not the seal, look at the frame itself. It appears that it has been "fixed" with bubble gum.
LAGrunthaner wrote: |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Thu Jul 30, 2020 6:25 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
This is the trouble area, has anyone cut the seal down to get it to fit in that slot between the latch tab? |
It doesn't go in a slot there. It just lays outside the flap. |
Posted: Wed Aug 26, 2020 5:42 am Post subject: Re: Help getting the bloody vent window seal in my door frame |
BarryL, sorry I missed this comment, and I don't understand what you mean by "It doesn't go in a slot there. It just lays outside the flap" as the rubber seal which fits into this slot appears to not sit down into the latch area as that is where the latch won't meet the metal tab. Should I sand down the seal where it slides to the 2 rivets are so it sits properly?
BarryL wrote: |
Maui Roadsters
Lind wrote: |
BarryL Samba Member
Posted: Wed Aug 26, 2020 2:41 pm Post subject: Re: Help getting the bloody vent window seal in my door frame |
You have so many situations going on with those that I'll try to break it down.
Forget what I said about, "It doesn't go in a slot there. It just lays outside the flap".
Let's label some things:
Driver side wing is the one in your last post and has a Nike Swoosh and the frame is not bent.
Passenger side wing is missing the Nike Swoosh and the bottom of the frame is bent down as shown in previous posts.
Driver side door window frame is the one in your last post and has a blob of weld or something in the corner of the aft part of the wing catch part as npbusguy called "bubblegum".
Passenger side window frame shown in previous will never shut right until you bend the wing's bottom up.
Ok, so, looking at the driver's side frame you either need to remove the goober and then try to get the rubber to seat all the way back to the vertical piece or cut the rubber off complimentary to the goober. You will have to cut the vertical seal as well as the surround seal's lower rear to accommodate the goober.
The vertical seal goes outside the bottom seal not inside as you have it in previous photos. |
