mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Mon Jul 06, 2020 4:39 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
hundreds of old detail photos, and so many cool cars getting restored. _________________ regards
Uli
Undis Samba Member
Joined: October 24, 2006 Posts: 1396 Location: Riga, Latvia & Sydney, Australia
Posted: Sat Sep 12, 2020 10:08 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
Some long awaited updates from the René Große workshop. The guys have been busy welding up the roof section.
_________________ Check out my Facebook page: Volkswagen Prototypes. |
Undis Samba Member
Posted: Sat Sep 12, 2020 10:11 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
With the bulk of the roof in place they are continuing down to the lower rear end and sides. The first step on the sides of the body are the rear quarter panels.
olo Samba Member
Joined: February 09, 2008 Posts: 134 Location: australia
Posted: Sat Sep 12, 2020 10:15 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
Keep up the good work 👍 |
Undis Samba Member
Posted: Sat Sep 12, 2020 10:16 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
The flat metal pieces then shaped to flow with the body lines.
Undis Samba Member
Posted: Sat Sep 12, 2020 10:23 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
Time to dial in the lower rear bodywork. Interesting how they decided to use foam between the wooden ribs to give more precise detail in a section that needs it more. This area has a lot going on with compound curves of the lower rear end and the swooping lines of the W shape.
D-train Samba Member
Posted: Sat Sep 12, 2020 10:55 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
That is a masterpiece! _________________ shiny paint doesnt make it worth any more |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Sun Sep 13, 2020 7:14 am Post subject: Re: Reconstruction of the 1937 W30/26 |
fascinating to see this process _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1276 Location: australia
Posted: Tue Sep 15, 2020 3:31 am Post subject: Re: Reconstruction of the 1937 W30/26 |
WOW! |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 977 Location: Las Vegas, NV
Posted: Tue Sep 15, 2020 10:52 am Post subject: Re: Reconstruction of the 1937 W30/26 |
Amazing work. The HAZ looks huge, is that all torch welded? I love using the torch but I've always struggled with sheet metal, it's an incredible skill _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1631 Location: Anderson, SC
Posted: Tue Sep 15, 2020 6:28 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
petrol punk wrote: |
Amazing work. The HAZ looks huge, is that all torch welded? I love using the torch but I've always struggled with sheet metal, it's an incredible skill |
Earlier pics show panels being gas welded. A gas weld is very soft and workable so planishing stretches the metal back into shape to reverse the shrinking in the HAZ. Its soft enough that planishing can flatten the weld bead so little or no grinding is needed. _________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Posted: Tue Sep 15, 2020 7:19 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
i just hope somebody commissions another body made from aluminum, like the italian coach builders did, super leggera ala Zagato. a 1930s hotrod with VW guts and a real -ish VW body. The buck is already there...... am i weird? _________________ regards
Uli
Posted: Wed Sep 16, 2020 1:40 am Post subject: Re: Reconstruction of the 1937 W30/26 |
dont worry, you can get therapy for that Uli...
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9969 Location: Huntington Beach, CA
Posted: Wed Sep 16, 2020 7:45 am Post subject: Re: Reconstruction of the 1937 W30/26 |
Amazing work! Being a highly skilled woodworker and a amateur metal bender, it is amazing to see those two worlds interact so well together. The one compliments the other so perfectly!
Huge props to you! That has got to make you just sit back and stare at your craftsmanship. It would me. Heck, I would have gotten the jig made and sat back down for several months! Just staring in amazement!
This is really cool! How big is that English wheel I keep seeing in the back ground? Because those panels are not small. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Undis Samba Member
Posted: Fri Sep 18, 2020 4:20 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
They're welding it the old-school way. This is how the Daimler Benz workers at Sindelfingen would have done it. I'm amazed how they are able to keep the metal straight.
Undis Samba Member
Posted: Fri Sep 18, 2020 4:32 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
Another exciting update on the W30.
The guys are starting on the sills below the doors and rear quarter panels. On a regular Beetle this is where the heater channel is located but the W30 had no heater at all. The sill is also much thicker.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
How does that work over the foam?, it must get stinky. Unless you tack it and remove it to complete the weld, but how do you remove the entire shell and keep it aligned??
Just curious, great work there, just running some of the logistics of the job around in my mind. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Undis Samba Member
Posted: Fri Sep 18, 2020 4:36 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
The rear end is taking shape too. Note that the location of the engine lid has been sketched in by tape and the rear quarter window location drawn on the fresh metal.
Posted: Fri Sep 18, 2020 4:38 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
This is great wizardry!!! _________________ shiny paint doesnt make it worth any more |
Undis Samba Member
Posted: Fri Sep 18, 2020 4:41 pm Post subject: Re: Reconstruction of the 1937 W30/26 |
busdaddy wrote: |
Just curious, great work there, just running some of the logistics of the job around in my mind. |
I'm just guessing here - they probably remove the large panels to complete those welds. That may be the reason for all those tie-down straps so that the panels are easily removed and reinstalled as needed. We saw in the earlier photos how the roof panels were being welded and hammer-finished off he buck. _________________ Check out my Facebook page: Volkswagen Prototypes. |
