pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Wed Jul 10, 2019 6:22 am Post subject: Idle too high |
1979 stock 2.0 with fi. Ive done lots of reading here and replaced or checked almost everything associated with idle .
At stop light the bus idles too high but will drop to normal if I pop the clutch for a split second. What did i miss? _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jul 10, 2019 6:29 am Post subject: Re: Idle too high |
pioneer1 wrote: |
What did i miss? |
Oiling the felt pad down in the distributor shaft under the rotor?, the mechanical advance might be binding. The decel valve would also be on my list of suspects. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
whip618 Samba Member
Joined: October 16, 2002 Posts: 761 Location: Albuquerque
Posted: Wed Jul 10, 2019 7:20 am Post subject: Re: Idle too high |
also a worn throttle body can cause similar symptoms.
Phil _________________ Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307 |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5995 Location: Brooklyn
Posted: Wed Jul 10, 2019 8:41 am Post subject: Re: Idle too high |
Vacuum leak
Does the idle speed screw on the throttle body have any effect? _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Wed Jul 10, 2019 11:33 am Post subject: Re: Idle too high |
The screw is almost bottomed out so Im looking for other areas that affect idle. All vacuum lines new _________________ "Always waiting for tomorrow ruined everything"
Posted: Wed Jul 10, 2019 12:15 pm Post subject: Re: Idle too high |
The screw just goes into an air passage that bypasses the throttle plate, so if the screw is all the way in but it's still idling high, that would tend to indicate that air is bypassing the throttle plate in some other manner.
Perhaps the auxiliary air regulator is stuck open?
What's your fuel pressure?
When you replaced the vacuum lines did you replace the rubber seals around the tips of the injectors? _________________ 1965 Volkswagen 1500 Variant S
Posted: Wed Jul 10, 2019 1:59 pm Post subject: Re: Idle too high |
Key may be that it returns to normal if i let out the clutch for a split second? _________________ "Always waiting for tomorrow ruined everything"
Posted: Wed Jul 10, 2019 2:35 pm Post subject: Re: Idle too high |
That's why I'm thinking decel valve or distributor. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jul 14, 2019 10:22 am Post subject: Re: Idle too high fixed |
I clean, tested ,oiled all of the above and now the bus runs , drives and idles great. Thanks all _________________ "Always waiting for tomorrow ruined everything"
