What cam would you pick?
TinCanFab
TinCanFab is offline
PostPosted: Wed Jul 10, 2019 11:55 am    Post subject: What cam would you pick? Reply with quote
Hi guys, I think I'm going to run a CB "cheater cam" 2280. What do you think for this engine?
1285cc 40 hp (stroked 69mm crank), supercharged (low boost 7psi), 1965 square boss heads (stock size valves or bigger). I can build a header if I need to, would like to use a stock exhaust. Ill be doing a TBI Megasquirt with VW coilpack, distributorless...
I'm going for a 5500 RPM and lower driver that will get decent mileage that will pull a few adults and kids comfortably in my Bug. This needs to be something that is comfortable for my wife to drive by herself. I asked Pat at CB a few years ago, and IIRC, he agreed with me.
Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092
Danwvw
Danwvw is offline
PostPosted: Wed Jul 10, 2019 12:15 pm    Post subject: Re: What cam would you pick? Reply with quote
Well I doubt the early small oil relief 40 horse case will hold up to it. Maybe if it's fully inserted etc... Just as well go with more cam as the low end torque is going to exceed the cases abilities maybe not too much though since it's a small displacement engine. The best thing to do would be to get a late model 40 horse D series dual oil pressure relief case for this Idea of an engine.
1971 VW Bus Sundial Camper, 1960 VW Beetle, 1988 Porsche 924s
Building a 74 mm Stroke by 88 mm bore with 042 or 044 heads? And 1960 Beetle Original 36 Horse And Porsche 924s.
FreeBug
FreeBug is offline
PostPosted: Wed Jul 10, 2019 2:23 pm    Post subject: Re: What cam would you pick? Reply with quote
Even supercharged, the 2280 is not going to make power to 5500 rpm.
I'd be looking at durations in the 230-240 degrees @ 0.05" range. Then maybe work with lobe separation to manage overlap?
Yeah, a late 1200 case would be stronger, but I think if you work at balancing, clearances, good choice of parts, maybe enlarging some oil passages, etc...you could pull this off.
The issue that would worry me most is where to find an old case that hasn't been through a zillion heat cycles. And will crack as a result.
TinCanFab
PostPosted: Wed Jul 10, 2019 2:54 pm    Post subject: Re: What cam would you pick? Reply with quote
I'm not looking for a radical engine combo. Putting a mild supercharger setup on 36hp and 40hp engines has been done for decades. Those engines just had a stock camshaft. I'll have the ability to control ignition and fuel with efi, so I can put any cam I want. If driving 40hp engine scares people because of case issues, then that's ok. I'm just putting an engine back together that was fresh, but broke the crankshaft. Case savers being done, full balance, spark plug holes getting welded for 12mm, etc.
FreeBug
FreeBug is offline
PostPosted: Wed Jul 10, 2019 9:55 pm    Post subject: Re: What cam would you pick? Reply with quote
Last (only) time I broke a crank, the engine case was toast. Measure twice before you start putting too much money into that case.
TinCanFab
PostPosted: Thu Jul 11, 2019 8:52 am    Post subject: Re: What cam would you pick? Reply with quote
I'm using a different case, although the first one barely boogered up a bearing dowel hole. I was told it can be machined for a stepped dowel. None of that has anything to do with cam choices.
Danwvw
Danwvw is offline
PostPosted: Thu Jul 11, 2019 12:25 pm    Post subject: Re: What cam would you pick? Reply with quote
Since you don't want too much power consider a cam without much lift. The Engle-2280 Has mild lift at about .400" at the valve but near stock duration. I installed a Webcam 118 that is similar on lift at .402" but it has 245' duration @ .050" however I run it normally aspirated with 1.25 Ratio rockers which brought the lift up to make it even more cam than the Webcam 218 John at ACN may have some ideas for you. With the 118 you could run 1:1 Ratio Rockers or 1.1:1 Ratio Rockers or 1.25:1 ratio rockers or even mix them.
Alstrup
Alstrup is offline
PostPosted: Thu Jul 11, 2019 1:51 pm    Post subject: Re: What cam would you pick? Reply with quote
The 2280 is fine for what you want to do.
Bump static CR to 8-1.
If you use the older single relief D case, or even an F case, drill the main supply gallery to 10,5 mm. I like to enlarge the passage to the cooler with 1 mm and the return to the main gallery from the cooler with 2 mm to reduce back pressure from the cooler. When that is done you can also increase oil pump size to 25/26 mm. for better supply.
T
TinCanFab
PostPosted: Fri Jul 12, 2019 12:13 pm    Post subject: Re: What cam would you pick? Reply with quote
Cool, I've never done a cam swap on a single port engine. I am going to do the oil cooler mods. I'll be using an external oil cooler/fan and stock dummy oil cooler to keep the heat out of the shroud too.
She didn't want a scary 2 liter turbo engine like the car had. I didn't want to drive a car with a boring stock engine. So, this is my compromise Very Happy
Here's why I don't want a doghouse shroud setup.
How many people have put a supercharger under a stock early decklid car, that isn't a rare vintage kit?
