Vwbuschris Samba Member
Posted: Fri Jul 12, 2019 2:57 pm Post subject: Which wire is for the fuel sending a unit? |
I have a 76 Westfalia and trying to figure out what wire is for the sending unit. Does anyone have any advice?
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jul 12, 2019 3:25 pm Post subject: Re: Which wire is for the fuel sending a unit? |
None of those, the tank sender wire is found inboard of the RR shock absorber on 72+ models, it goes up into the tank area through the floor on the angled area near the side. It's the brown one when you do locate it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jul 13, 2019 6:12 pm Post subject: Re: Which wire is for the fuel sending a unit? |
Thanks for the help |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Sun Jul 14, 2019 3:14 pm Post subject: Re: Which wire is for the fuel sending a unit? |
Funny, that... I just uploaded a photo of the fuel sending unit wire with its T-connector and grommet through the floor. It feeds into the wiring harness under there, near the starter.
Mind you, that is for a truck, and our fuel tanks are located forward, on the floor, as it were.
The fuel tank in a kombi would sit in the depression next to the T-connector. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
75 Westy FI noob Samba Member
Joined: November 04, 2022 Posts: 330 Location: MidWest
Posted: Thu Apr 13, 2023 12:40 pm Post subject: Re: Which wire is for the fuel sending a unit? |
I love this site so flippin' much. Thanks guys.
i verified my gauge works.. i can tell someone has replaced the sending unit before (the sheet metal above it is cut in H pattern).. hoping to find/fix a wiring problem. |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Sun Apr 16, 2023 12:13 pm Post subject: Re: Which wire is for the fuel sending a unit? |
busdaddy wrote: |
None of those, the tank sender wire is found inboard of the RR shock absorber on 72+ models, it goes up into the tank area through the floor on the angled area near the side. It's the brown one when you do locate it. |
Disliking the potential confusion with all other brown wires, being Earthing wires (i.e. Grounding wires in USA parlance!?!), I changed the colour-coding to green / brown, which is more consistent with the rest of my wiring loom for gauges and warning lights, which is green / tracer-colour for gauges and mostly blue / tracer-colours for warning or tell-tale lights. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
Posted: Fri Jun 02, 2023 11:17 am Post subject: Re: Which wire is for the fuel sending a unit? |
Moved on to the sending unit …
If I jump from battery to FSU ground wire.. i get 12.4 V
So ground is good.
If I jump FSU ground wire to FSU hot wire… Gauge goes to 1/1 Full.
So that implies the hot line is also good.
But, if i put a meter between the hot and ground in the FSU area (pictured) … the voltage dances all around between 2.5 and 4.5 V. I expected to see 12.
Is that normal or do I have a bad hot wire into the FSU after all ?
Running a line from battery to FSU hot input does not move the guage.
Btw, do you think i can squeeze a new one into that opening? Its hing style 1975.
Posted: Fri Jun 02, 2023 11:48 am Post subject: Re: Which wire is for the fuel sending a unit? |
Don't go putting 12v into any of those wires!
If grounding the sender wire gets a full tank the gauge and wire are good, the sender grounds that wire gradually as fuel level increases, if the tank is empty it should read ~90 ohms. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jun 02, 2023 11:52 am Post subject: Re: Which wire is for the fuel sending a unit? |
Thanks BD.. i thought every thing could handle 12. lol
Thanks for the word on the timing also.
I guess it’s a bad FSU. Wishful thinking that it would be wiring.
Hopefully i can shoehorn a new one in there.
I tried to order a new one yesterday but the vw man convinced me to test ground first. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Fri Jun 02, 2023 12:17 pm Post subject: Re: Which wire is for the fuel sending a unit? |
The voltage regulator on the fuel guage contains a bimetallic strip and heater. It pulses the 12 volts on and off a few times a second, heating up the strip when the output voltage is 12 volts, breaking the contact when the strip gets hot enough.
It produces a voltage which averages about 5 volts.
With a digital meter it presents values that dance about because the meter averages the voltage about 3 times a second, the regulator pulses a couple of times a second, the two beat together and produce junk.
If you connect an analog meter or an oscilloscope you would see the voltage swing to 12 volts and back again.
If the fuel gauge is working, and you have a pulsing voltage at the sender end of the wire, the sender may just have partly burnt out.
They all burn out eventually, cheap reproduction senders are worse than cheap reproductions made 10 years ago which are worse than originals.
They all read tank level and produce different values for different amounts of fuel, just the calibration of the newer senders is very poor.
On my current sender, the tank goes into the red sector after 100 miles.
After another 100 miles, it sits a needle's width off empty. After another 50 miles it sits at empty and it is empty.
If you hunt around you may find a sender with approximately the correct construction (the winding of the resistance wire is bunched with tighter turns up at one end) - these will cost more. _________________ Ancient vehicles and vessels
Posted: Fri Jun 02, 2023 5:08 pm Post subject: Re: Which wire is for the fuel sending a unit? |
I would cut off most of your flap and make a decent air tight cover for it. Leave enough of the flap so that it gets up onto the flat and then increase the size of the hole towards the rear of the body a bit. It didn't take me too long to make the fitted cover I have, but you could also use a flat cover and some fire stop caulk.
This is the cover I made for my 77, but I would move the entire hole rearward 3/4-1" if I was doing it again, so I didn't have to deal with the bend in the deck.
Posted: Sun Jun 04, 2023 11:05 am Post subject: Re: Which wire is for the fuel sending a unit? |
mikedjames wrote: |
That must be exciting on remote mountain roads…. |
Posted: Sun Jun 04, 2023 11:10 am Post subject: Re: Which wire is for the fuel sending a unit? |
Wildthings wrote: |
I .. and some fire stop caulk.
PO cut mine just past the bend.. so it will not crease nicely. may cut it off as you mentioned. Fire proof caulk…. Need some !
Last edited by 75 Westy FI noob on Sun Jun 04, 2023 11:18 am; edited 1 time in total |
Posted: Sun Jun 04, 2023 11:15 am Post subject: Re: Which wire is for the fuel sending a unit? |
Wildthings wrote: |
This is the cover I made for my 77...
Where can I find some patch/hatch material ? |
Posted: Mon Jun 05, 2023 6:51 pm Post subject: Re: Which wire is for the fuel sending a unit? |
I put my new FSU in today. Old one looked very rough, i think it has barnacles!
May still try to clean it. Lol
Wondering if there’s a trick to tightening the new one. Tapped it h a punch but still needs 1/8 turn to finish. |
Posted: Mon Jun 05, 2023 7:02 pm Post subject: Re: Which wire is for the fuel sending a unit? |
Grease the O ring as well as the bayonet tabs. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jun 05, 2023 7:06 pm Post subject: Re: Which wire is for the fuel sending a unit? |
Nevemind.. got it sorted out!
Pliers are from an electrical pinch kit. Worked great
Posted: Mon Jun 05, 2023 8:47 pm Post subject: Re: Which wire is for the fuel sending a unit? |
If the rest of the inside of your tank looks anything close to that you have much bigger issues in your future than just not being able to tell how much gas you have. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Jun 06, 2023 5:25 am Post subject: Re: Which wire is for the fuel sending a unit? |
75 Westy FI noob wrote: |
That fuel-gauge sender is in a horribly rusty mess!
What sort of horrible, sub-standard petrol (i.e. gasoline in USA parlance!?!) or petrol / ethanol blend having you been putting in your fuel tank!?! _________________ Regards.
Nigel A. Skeet
Posted: Tue Jun 06, 2023 7:11 am Post subject: Re: Which wire is for the fuel sending a unit? |
I always ran 'real gas' in there ... but I left the bus with some family for a few years. They put new gas in it.. then parked it and it sat for about 8 years.
I assumed that was a newish FSU... but obviously it isnt very new at all.
exterior of the tank looks good. I didn't shine a light into the tank. maybe i should have a look in there. i was trying to switch them quickly and didn't think to look in there.
I am afraid I may have over tightened the FSU ...it seemed to need another 1/8 turn.. and I used those pliers and put torque on it.. it didn't move, then suddenly popped forward into hopefully the lock position. so it's good, or i broke it.
guage on the dash is working now tho!
Last edited by 75 Westy FI noob on Tue Jun 06, 2023 5:57 pm; edited 1 time in total |
