airkewledzook Samba Member
Posted: Fri Jul 12, 2019 4:52 pm Post subject: Magneto ignition for street use |
Just curious if anyone has any experience with using a magneto ignition on a volksie for a street driver. I've seen them used for racing, aircraft conversions and industrial applications on the upright engines but I've heard they don't work well on the street so I'd be interested in hearing from anyone with actual experience.
And please mention which kind it was.
Thanks for any help. |
Gearfinger Samba Member
Joined: August 04, 2015 Posts: 46 Location: Under the Bridge
Posted: Fri Jul 12, 2019 5:00 pm Post subject: Re: Magneto ignition for street use |
Put simply, a magneto is a long step back in time and has no up side in use in a car today. That's why you don't see any vendors selling new Chinese made VW Magnetos... |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sat Jul 13, 2019 3:12 am Post subject: Re: Magneto ignition for street use |
They are 'Hard' on the Brass drive gear for the street ,, _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
flatfour Samba Member
Posted: Sat Jul 13, 2019 8:52 am Post subject: Re: Magneto ignition for street use |
I had one on my old race car and then switched it over to MSD. Magneto sounds good in theory but there are better options for street or race. _________________ '68 Bug
'74 Ghia |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1171 Location: San Angelo, Texas
Posted: Sat Jul 13, 2019 9:45 am Post subject: Re: Magneto ignition for street use |
The obvious reason to use one is if you don't need or want a starter and a battery. Not practical for a street car, I would suppose. They use them on airplanes though. If you have ever been "hit" by one, you'll remember it. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Posted: Sat Jul 13, 2019 10:22 am Post subject: Re: Magneto ignition for street use |
Use on aircraft is by FAA requirement. The engine must have redundant self contained ignition systems seperate of the aircraft electrical system. |
atticus finch Samba Member
Posted: Sat Jul 13, 2019 10:51 am Post subject: Re: Magneto ignition for street use |
airkewledzook wrote: |
If you're basically driving on the street with a relatively stock engine or within relatively normal street driving rpm (idle to around 3500 rpm the majority of the time). A magneto really doesn't offer any big advantage over points ignition or electronic.
The advantage a mag offers on a racing application is: faster you turn it, the hotter the spark. The higher the RPM the dwell time on points gets essentially smaller, ie: a spark loses it's intensity. The exact opposite with a mag due to magnetic induction.
Racing, high performance street = higher rpm than normal street driving as a general rule.
Aircraft use them due to self-generating ability, a safety factor. Also aircraft engines run at a relatively stable rpm in most operation. Fixed timing on a mag works with that environment, not so well with the varying range a car engine operates in. |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3818 Location: Georgia
Posted: Sat Jul 13, 2019 1:31 pm Post subject: Re: Magneto ignition for street use |
It’s also my understanding that a magneto has no advance built in so it’s really an all or nothing type thing. Great for engines that run pretty much the same RPM the whole time. _________________ Volkswagen!
(Compression 8.7:1) |
gwal Samba Member
Joined: January 20, 2008 Posts: 24 Location: cambridge, england
Posted: Sun Jul 14, 2019 12:59 am Post subject: Re: Magneto ignition for street use |
I ran a mag on my 12 sec street car for 4 years with absolutely no issues what so ever, it ran like a champ!
and just to be clear some mags do have an advance mech, just like a dizzy,
cheers
andy |
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Sun Jul 14, 2019 5:31 am Post subject: Re: Magneto ignition for street use |
The FAA redundant requirement does not apply to homebuilt aircraft which is where converted VW engines are used. Weight savings is the big one there and I have never heard of a brass drive gear failure on that very critical application. It is true though that they run much more steady state. |
KROC Samba Member
Joined: February 20, 2006 Posts: 359 Location: Vancouver B.C.
Posted: Sun Jul 14, 2019 6:52 am Post subject: Re: Magneto ignition for street use |
Don Zig prepped Magneto in my 2275 Patina car. This Mag came out of a Swiss industrial engine, originally with no advance curve, Zig rebuild the guts and was able to get 18 degrees of advance out of it. the curve is from 900 rpm to all in at 2600 rpm, I wired in a 5 prong bosch relay to ground the unit when I turn off the key ( so no extra toggle switch to shut off engine )
Tons of spark energy engine revs cleanly to 7000 rpm plus.
I may purchase a rev limiter/ tach adapter from ECT rev limiters some day.
Will it wear out my Brass distributor drive gear? I could care less as I tear my engines apart every winter trying new combinations of cams heads etc... If it wears I will replace the silly thing 😜
Posted: Mon Jul 15, 2019 10:00 am Post subject: Re: Magneto ignition for street use |
Thank you for the replies. I was not aware of Don Zig.
FWIW my interest in a magneto is to have a self supporting ignition. |
tommiebsmith Samba Member
Posted: Tue Jul 14, 2020 6:53 am Post subject: Re: Magneto ignition for street use |
Does anyone know if Don Zig is OK? I have spoke with him about 5 times
At the end of 2019 waiting for him to get to my magnetos now in the last
4-5 months I can not get a hold of him ?? |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Tue Jul 14, 2020 7:38 am Post subject: Re: Magneto ignition for street use |
jeffrey8164 wrote: |
It’s also my understanding that a magneto has no advance built in so it’s really an all or nothing type thing. Great for engines that run pretty much the same RPM the whole time. |
Magnetos can have advance just like a normal distributor can.
VW made a steel dist drive gear for their industrial motors that use a Magneto. |
k@rlos Samba Member
Joined: October 04, 2012 Posts: 485 Location: Suffolk, England
Posted: Tue Jul 14, 2020 1:14 pm Post subject: Re: Magneto ignition for street use |
My mate who’s also my engine builder has been running a magneto on the fk89 & ida fed 2276 in his street/strip car for years. MSD & Mallory etc are gonna be better Overall but it suits his cars image and it runs consistent 11’s so must work alright |
oprn Samba Member
Posted: Tue Jul 14, 2020 1:38 pm Post subject: Re: Magneto ignition for street use |
Tough to get past that old mindset of "it works on the drag strip so it's gotta be right for the street" isn't it? |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Tue Jul 14, 2020 2:27 pm Post subject: Re: Magneto ignition for street use |
As far as gear wear, I just have this to say: that magneto was probably not just off an industrial engine, but off a military industrial engine. Those things are portable, have arms which swing out and lock into place for six, and compress air, generate electricity, or pump water, depending on the model (the generator is the coolest, it has a starter motor )
What I'm getting around to saying is this: it is critical that they be dead reliable, and dependable; those things are built to last. |
oprn Samba Member
Posted: Tue Jul 14, 2020 4:11 pm Post subject: Re: Magneto ignition for street use |
I would definitely consider a magneto for an off road Buggy that I was planning on doing long back country trips with. Carry a crank and you will be coming home no matter what happens electrically!
As for on the street, there are so many better options out there! |
