BFB Samba Member
Posted: Fri Jul 12, 2019 5:09 pm Post subject: whats the highest compression engine youve built?? |
seems like we need some more actual performance posts, so... whats the highest compression engine youve built? and maybe throw some specs in, and what fuel you run.
mine was just 8.8:1 1641, but most of mine are turbo. most ive boost so far though is 20lbs through stock 1600 on 91octane.
currently running 2276 8:1 cr , 12lbs of boost on 91
id kinda like to build a high compression n/a though and have read ppl have trouble going past 9:1 on pump gas |
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Fri Jul 12, 2019 5:54 pm Post subject: Re: whats the highest compression engine youve built?? |
2783cc Autocraft case with 910 heads 10.8cr. I use 91 with torco octane boost. 600 street miles on engine so far, still working out the "Bugs" |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Fri Jul 12, 2019 5:58 pm Post subject: Re: whats the highest compression engine youve built?? |
2180
Webcam 86b
Tim's stage II heads
9.4:1 cr
45 DLRA's
Low octane pump gas. Normally.
The car did 14.413 @ 91.7mph June 1st. Used High Octane for this run. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Fri Jul 12, 2019 8:03 pm Post subject: Re: whats the highest compression engine youve built?? |
1737 cc water pumper, 9.5 CR 15+ psi boost on propane (120 octane equivalent). 10* pressure retard. Started to ping at 12 psi at 70*F ambient. 18 psi no ping at -30 ambient.
Presently running 1911 type 4, 8.4 CR N/A on 87 octane. No ping found anywhere. Regret not taking CR to 9.5! |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3464 Location: Paradise, Ca
Posted: Fri Jul 12, 2019 8:11 pm Post subject: Re: whats the highest compression engine youve built?? |
10.5:1 is easy when the cam is bleeding off a little. No pinging on 91 pump gas _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
slalombuggy Samba Member
Posted: Fri Jul 12, 2019 8:28 pm Post subject: Re: whats the highest compression engine youve built?? |
Brutus:
12:1
2332cc
Ultra Wedge Ports
Web 251
51mm EPCs
CB Aluminum case
VP C-12
Little Brutus:
10:1
2332
Wedge Ports
Eagle 2290
48 IDFs
Another CB aluminum case
Shell Gold 91 with octane boost.
Baby Brutus
9:1
1904
Revmaster 049s
Engle 110
40mm HPMX
AS-41
Shell Gold 91
brad |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Fri Jul 12, 2019 9:23 pm Post subject: Re: whats the highest compression engine youve built?? |
2276, AC.net Super Squish pistons, Pauter vn119 cam, 12:1 CR, 93 octane. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Fri Jul 12, 2019 9:35 pm Post subject: Re: whats the highest compression engine youve built?? |
2276
Comp eliminators 48/40
FK-98
12.7:1 _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Fri Jul 12, 2019 9:51 pm Post subject: Re: whats the highest compression engine youve built?? |
21-1
Do diesels count? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15307 Location: Deep in the 405
Posted: Fri Jul 12, 2019 9:57 pm Post subject: Re: whats the highest compression engine youve built?? |
2165cc
Street Eliminator heads
FK-10
11.2 CR
Mix 1 1/2 gallons 110 race fuel with 3 1/2 gallons 91
1425 Lb W/driver Dunebuggy ran 12.20's _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Howard 111 Samba Member
Posted: Fri Jul 12, 2019 10:46 pm Post subject: Re: whats the highest compression engine youve built?? |
13:1, but it was a drag only Ghia. 7.57 at 90mph in the 1/8 mile. Fun car, especially against the V-8s. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Sat Jul 13, 2019 10:19 am Post subject: Re: whats the highest compression engine youve built?? |
You asking about static compression, so 10.5:1 on a W130 on 91 octane at sea level. But I’ve built engines with more actual running compression than that. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
BFB Samba Member
Posted: Sat Jul 13, 2019 12:11 pm Post subject: Re: whats the highest compression engine youve built?? |
thread is going great , lotta good replies. lets not ruin with going down the static vs dynamic road |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Sat Jul 13, 2019 1:27 pm Post subject: Re: whats the highest compression engine youve built?? |
2276
8.7:1
With no additional work my parts config gave me 9.5 static. I thought that was a little high so I added 6cc to my chamber volume.
Not he highest obviously but I don’t want to have to find or carry race gas when I just want to cruise the mountain roads.
There are two different CRs so if you only want one you should be more specific in your questioning. _________________ Volkswagen!
(Compression 8.7:1) |
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Sun Jul 14, 2019 6:01 am Post subject: Re: whats the highest compression engine youve built?? |
The last engine I had in my split was a 2275 that I tried to follow the Pro Gas class rules. (PG legal heads). Few exceptions, I ran a 82 crank and 51s because it’s what I had. Rules allow for 84mm and only 48s). I also had more welding on the manifolds (let’s call that SS/VX legal )
The teams of JackS and Klink set the bar for 44mm intake performance, so you pretty much know what the engine platform is capable of. If your going to chase someone, chase the best.
I built it with 38cc in the heads and valve reliefs and .040” deck with a static CR of 13.6:1. I ran it on VP110.
At bandimere the car would run 11.9s and 12.0s. (Track is 5800’ asl, and DA on a good day is 7000’ and always getting worse). It ran 11.71@114 in SLC, so even a small change in elevation, 4200’ asl, makes a serious difference. I’d guess it would have been a 11.5 or better car at your typical west coast track. Still a long way from the bar set by the best.
Power difference is obvious. Maybe 25hp. The other component is the driver and how hard they will push the car. I’d leave the line at 6800, but I’m pretty sure those guys are 8k+.
Compression is your friend. It makes for a nasty, raspy throttle and you know it’s alive back there. _________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Sun Jul 14, 2019 1:15 pm Post subject: Re: whats the highest compression engine youve built?? |
What causes the higher compression? Not to derail the thread but was curious.
Is it a tighter piston to head clearances resulting in a tighter “squish” area?
So the higher cr would result in faster detonation as opposed to a lower cr?
My other car ran a high cr but we used an msd retard box at first and then a J&S retard box to eliminate the detonation. The J&S was fantastic. It had a small “microphone” that plugged into the block and would only retard when it “heard” pinging. Very slick.
Posted: Sun Jul 14, 2019 4:58 pm Post subject: Re: whats the highest compression engine youve built?? |
67 Sunroof wrote: |
My other car ran a high car but we used an msd retard box at first and then a J&S retard box to eliminate the detonation. The J&S was fantastic. It had a small “microphone” that plugged into the block and would only retard when it “heard” pinging. Very slick. |
The total swept volume, based on the stroke length and piston diameter and the combustion space volume, which includes any space between the crown at tdc and the quench pad area.
A smaller piston crown to quench area distance will “squish” or agitate the mixture more than a looser quench distance.
Not necessarily. Detonation happens after ignition when the pressure rise in the cylinder causes small areas of mixture to combust uncontrollably. It causes pressure spikes that can (in mild situations) push through the boundary layer and leave tiny specks on crowns and chambers, or in severe situations destroy parts. Ignition timing is one of the main culprits. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Mon Jul 15, 2019 2:36 pm Post subject: Re: whats the highest compression engine youve built?? |
My 91 pump octane 2275 is at 12.2:1 right now. I ran 12.8:1 for a while with a bigger cam. Super squish pistons (set #1 been in it for like 15 years). 86A webcam. It has TONS of cranking compression. _________________ Steve
Steve's 87 Syncro project |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Tue Jul 16, 2019 7:14 am Post subject: Re: whats the highest compression engine youve built?? |
1584cc 13.5:1 class 11 race engine. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
mark tucker Samba Member
Posted: Tue Jul 16, 2019 7:23 am Post subject: Re: whats the highest compression engine youve built?? |
for vw 11.5, for small block mopar 14.3. |
