bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Thu Jul 18, 2019 8:20 am Post subject: Re: Breather box-Berg, CSP, CB?? |
Where's the opening on those Berg alternator stand breathers? It looks sealed. Does it face the shroud? _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
jason Samba Member
Posted: Thu Jul 18, 2019 8:55 am Post subject: Re: Breather box-Berg, CSP, CB?? |
If it has the regular cap it is sealed, goes nowhere. You have to use one or more of the hoses as vents.
The vented cap is one like on old v8’s. It has some kind of fiber or filter media. The baffles inside the tower are supposed to remove the oil from the air. |
gravee Samba Member
Joined: May 01, 2009 Posts: 165 Location: Waterbury, Vermont
Posted: Mon Oct 26, 2020 10:45 am Post subject: Re: Breather box-Berg, CSP, CB?? |
I recently purchased a CB breather. This might be a stupid question, but how are people tightening the filler nut on these. I have a socket (sort of) that I put on an extension on my socket wrench. It works great for the original fillers, but I couldn't really get things tight because the baffled part of the CB breather got in the way of the wrench.
I also had to grind down some of the outside of the box to stop it from butting against my generator stand. _________________ 1967 Westy |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7221 Location: Videbaek Denmark
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Mon Oct 26, 2020 11:56 am Post subject: Re: Breather box-Berg, CSP, CB?? |
I've just fitted a CSP breather box , I used the standard VW screw fitting for use with the original tower. The screw fitting.... i modified it using a 1mm cutting disc to cut a notch across the face of it where those 2 little notches are, then i used a grinding disc removal spanner that fits into the notches on the screw and used that to tighten it down, The O ring squashes down a lot.. so it needs retightening several times till its fully seated |
k@rlos Samba Member
Joined: October 04, 2012 Posts: 485 Location: Suffolk, England
Posted: Mon Oct 26, 2020 2:03 pm Post subject: Re: Breather box-Berg, CSP, CB?? |
Got a fast fab breather box on the firewall in my bus. Works well and cleanable too. |
