sb001 Samba Member
Posted: Sun Jul 28, 2019 1:06 pm Post subject: Re: still having idle problems... |
One quick question, on the 8mm-to-8mm hole using the green adapter seal, should the 10mm side be facing up (against the oil cooler) or downward (against the case?) _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
JonRich55 Samba Member
Joined: April 06, 2018 Posts: 378 Location: Leesburg, VA USA
Posted: Sun Jul 28, 2019 1:08 pm Post subject: Re: still having idle problems... |
Ok - for the heck of it I went and checked my AS case for a Dog House, and it also has the 10 on one side and 8 on the other. I use Red seals as I have the 10mm doghouse cooler.
I would think you using the two green seals and washers would be correct for what you have. The Red should not be used as you dont have a 10mm cooler. |
Posted: Sun Jul 28, 2019 1:09 pm Post subject: Re: still having idle problems... |
The 10mm should face the case, and the 8mm should face the cooler. |
sb001 Samba Member
Posted: Sun Jul 28, 2019 1:15 pm Post subject: Re: still having idle problems... |
Thanks very much Jon!
I will switch to the green adapter seals when I get the Elring kit in.
And to Q-dog's point it appears my cooler does not have the raised bosses around the mounting studs so I do need to be using the spacers. _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Sun Jul 28, 2019 1:24 pm Post subject: Re: still having idle problems... |
Glad to help when I can! When installing, be very careful to tighten them slowly and evenly, jumping from one to the other every 1/4 turn. That way they will compress evenly and straight across all 3. |
SwagWagen Samba Member
Posted: Sun Jul 28, 2019 5:17 pm Post subject: Re: still having idle problems... |
Check that #3 plug hole for cracks. I had a plug get black like that, turned out the head was cracked and the plug would loosen.
Zundfolge1432 Samba Member
Posted: Sun Jul 28, 2019 5:22 pm Post subject: Re: still having idle problems... |
Why would you use an early cooler with smaller passages on a late case? Yes they make adapter seals but why do you think VW went with the bigger offset cooler? 1970 a one year only cooler would match you case if you just had to look original but I cannot stress enough the benefits of running the better aluminum cooler along with the offset, the bigger fan, the Hoover bit and associated sheet metal pieces, we got the flaps and cross bar linkage and it will fit the thermostat rod and bracket you have however there will be no provision for air cleaner cable. That’s a small trade off.
Per our earlier conversation I was unable to make that 700+ mile drive and I’ve been a bit under the weather lately but I’d be willing to help you obtain these pieces. Bughaus is closed on Monday. If there isn’t a rush to put this car back together we might be able to blast the metal parts and prime. You could do a mini detail and freshen up the engine room. |
sb001 Samba Member
Posted: Sun Jul 28, 2019 6:59 pm Post subject: Re: still having idle problems... |
Zundfolge1432 wrote: |
Why would you use an early cooler with smaller passages on a late case? Yes they make adapter seals but why do you think VW went with the bigger offset cooler? 1970 a one year only cooler would match you case if you just had to look original but I cannot stress enough the benefits of running the better aluminum cooler along with the offset, the bigger fan, the Hoover bit and associated sheet metal pieces, we got the flaps and cross bar linkage and it will fit the thermostat rod and bracket you have however there will be no provision for air cleaner cable. That’s a small trade off. |
Actually I have absolutely no problem switching to the later doghouse style. I suppose I had reverted back to thinking about going with what I already have when I was told the reason for the #3 plug being black was not due to #3 cylinder running hot.
Speaking of which there is a guy over here in Bella Vista selling a doghouse shroud and the oil bath cleaner with the thermostatic flaps:
https://www.facebook.com/marketplace/item/450209005760600/?ref=messenger_banner
He wants $20 for the shroud and $10 for the air cleaner, shroud looks a bit worse for wear but would probably clean up OK. How does that sound?
AAh thanks for letting me know about Bughaus being closed Monday, I was all set to head over there. There's no rush, I want to do some other stuff while the car is down anyway (like replacing the dash pad, possbily fixing up the interior etc.) Just let me know what works for you--thanks once again for the help!! _________________ I'm the humblest guy on this board.
1600 SP engine
sb001 Samba Member
Posted: Thu Aug 01, 2019 6:19 pm Post subject: Re: still having idle problems... |
OK here are a couple pictures of my #3 and #4 cylinder head spark plug holes- #3 was the one with the sooty plug so that is where most of my attention is focused.
#3:
#4:
Looks like a crack between the valves on #3, but I don't really see any cracks between the plug hole and either valve. _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Thu Aug 01, 2019 6:28 pm Post subject: Re: still having idle problems... |
Besides the potential crack you see, the rest looks ok from the photos. The plug could be bad, the wire has too much resistance or a loose plug are still on the table. |
sb001 Samba Member
Posted: Sun Aug 04, 2019 2:31 pm Post subject: Re: still having idle problems... |
Here are my other two cylinder head spark plug holes-- anything incriminating or OK?
1600 SP engine
sb001 Samba Member
Posted: Fri Aug 09, 2019 9:30 pm Post subject: Re: still having idle problems... |
New question:
If, after I have completely drained the oil, and the engine has been sitting for about a week, it is still dripping oil from the seam on the bottom of the case between the two halves, is this normal?
I ask because I need to know whether this is indicative of a "sealing" issue with my case or normal. (With all the old folks on here saying these engines when properly assembled are not supposed to leak a drop of oil, it has me wondering.)
Thanks for your time. _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Sat Aug 10, 2019 6:00 am Post subject: Re: still having idle problems... |
From my experience, once I drain the oil it always finds a way to continue to "seep" until I install all new gaskets and really clean the areas around the oil drain and seam. |
sb001 Samba Member
Posted: Sat Aug 10, 2019 11:47 am Post subject: Re: still having idle problems... |
JonRich55 wrote: |
Thanks Jon- is this only after draiining the oil? (i.e. when the engine is in operation this doesn't happen for some reason?)
here are a couple of pics:
From the "wetness" on the front of the engine case I'm thinking shot front main seal... but I also think it's leaking through the case seam as the pictures seem to show. I guess since I've gone this far I might as well crack the case. _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Sat Aug 10, 2019 11:51 am Post subject: Re: still having idle problems... |
Looks normal to me. You have the sump cover off and even the slightest of tilt backwards and you have exactly that. It takes a very long time for all the oil to travel down.... |
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1605 Location: Central Pennsylvania
sb001 Samba Member
Posted: Sat Aug 10, 2019 6:08 pm Post subject: Re: still having idle problems... |
Thanks guys- I really appreciate the help. I'm kind of on my own here-- some folks who are regular posters on here about this kind of stuff won't post in my threads any longer because I call it like it is. _________________ I'm the humblest guy on this board.
1600 SP engine
Tom K. Samba Member
sb001 Samba Member
Posted: Sat Aug 10, 2019 8:03 pm Post subject: Re: still having idle problems... |
Tom K. wrote: |
Maybe start a new engine rebuild thread? The original topic - idle speed - doesn't really relate to your oil leak. I know that I stop reading some threads when the conversation goes off topic. Maybe others will chime in if you start a fresh thread devoted to oil leaks. |
That's a good idea, in fact it will probably be an entire car refresh thread, engine included. There are lots of other things I've wanted to do to this car for a good while now (mostly cosmetic), now is the chance to do it while it is out of commission.
That said, it won't make any difference with respect to the posters I'm referring to. Trust me they read through every thread and post in most all of them. They know the score.
Tom K. wrote: |
With the engine out, have you checked your end play? |
Actually yes (just by hand, not with a micrometer.) It seems fine. The absolute tiniest bit of movement. _________________ I'm the humblest guy on this board.
1600 SP engine
