shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3794 Location: VA/TN
Posted: Thu Jul 18, 2019 8:42 pm Post subject: Getting ground from pop top hinges, will it work? |
I'm running power to the pop top for lightning (perimeter and led strips).
I'm using marine 14/3 triplex. Long story short I just need ground up there.
On a pop top, do you think the rear hinges would be a good place to get ground? Does anyone know what the hinges are made of? Or does anyone have any other recommendations?
I may have to run a separate cable. _________________ Brandon
Instagram @joannthevan |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
Posted: Thu Jul 18, 2019 8:55 pm Post subject: Re: Getting ground from pop top hinges, will it work? |
shagginwagon83 wrote: |
lightning |
I think you meant to say "lighting", not "lightning"? I certainly hope you don't routinely camp in places which require lightning rods ...
In any case, I would certainly run a continuity test between the hinges and a known good ground. It's possible they can provide a suitable ground, but perhaps the plating and body paint prevent a good connection? _________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6243 Location: Portland OR
Posted: Thu Jul 18, 2019 9:01 pm Post subject: Re: Getting ground from pop top hinges, will it work? |
All you need is a multi meter to test for continuity and a good ground. Surely you have one of those. _________________ 89 Westy 2.1 Auto |
Posted: Thu Jul 18, 2019 9:08 pm Post subject: Re: Getting ground from pop top hinges, will it work? |
Lighting! I'm on my phone and it auto corrected. It is raining outside and I can't pop my top right now. I'll get the multimeter out and give it a shot.
I found some marine 14awg wire so worst case scenario I'll just run it from inside the van. _________________ Brandon
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Fri Jul 19, 2019 4:14 am Post subject: Re: Getting ground from pop top hinges, will it work? |
Don't see why not |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17112 Location: Retired South Florida
Posted: Fri Jul 19, 2019 6:16 am Post subject: Re: Getting ground from pop top hinges, will it work? |
Ideally you’d use on of the bolts that secures the hinge to the sheetmetal
roof skin. The factory used some sealer where the bolts attached, so you’d probably want to clean the threads bolt and hole to ensure good connections. _________________ ☮️ |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
Posted: Fri Jul 19, 2019 6:23 am Post subject: Re: Getting ground from pop top hinges, will it work? |
MarkWard wrote: |
roof skin. The factory used some sealer where the bolts attached, so you’d probably want to clean the threads bolt and hole to ensure good connections. |
Are there rubber washers between the hinge and rook skin from the factory? I know the Mosaik kits had them and I copied that over to my conversion . _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
E1 Samba Member
Joined: January 21, 2013 Posts: 6529 Location: Westfalia, Earth
Posted: Fri Jul 19, 2019 6:28 am Post subject: Re: Getting ground from pop top hinges, will it work? |
Brandon, IIRC correctly you have Jack Bombay lifters. I'd think a good ground could be found on a Bombay mounting arm/plate.
Rubber washers unknown... on our '84, the factory mounting bolts used some black silicone to seal them but I don't think there's any other rubber involved. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
RawUmber Samba Member
Posted: Fri Jul 19, 2019 7:09 am Post subject: Re: Getting ground from pop top hinges, will it work? |
If your lighting is isolated from any other circuits (ie, only connected to the +/- leads) and your 'hinge ground' provides enough current, the 'hinge ground' doesn't need to perfectly match battery ground so long as the voltage differential is enough to power your lighting (eg: given 12v lighting, a 13v +supply and 1v ground still yields 12v).
That said, if you have a perfect ground option, use it. It will have a greater voltage differential as your battery drains. |
Posted: Fri Jul 19, 2019 7:24 am Post subject: Re: Getting ground from pop top hinges, will it work? |
Thank you all for the suggestions. I have the GoWesty lifters. I could use that but I want it to be towards the rear/hidden.
Yes ideally remove one of the bolts on the bottom pop top hinge and get ground there.
It's crunch time. Like I said I've been taking pictures as I go but I can't wait to show you guys what I've done. However It won't be until after High County bus festival before I can post photos _________________ Brandon
Posted: Fri Jul 19, 2019 9:31 am Post subject: Re: Getting ground from pop top hinges, will it work? |
I don’t recall any rubber washers on the two tops I have removed. Only some sealer. _________________ ☮️ |
Dampcamper Samba Member
Joined: October 07, 2013 Posts: 788 Location: Rainy Portland, Oregon
Posted: Sat Jul 20, 2019 12:05 am Post subject: Re: Getting ground from pop top hinges, will it work? |
If you wanted to be sure and have a good ground you could make a flexible jumper from top to bottom of the hinge. Maybe a little braid from a piece of coaxial cable (like CB antenna coax, not the stuff used for cable TV) with crimp lugs at each end. Dress it so it has a gentle flex when the roof opens.
Same idea as the transmission ground strap but a lot smaller. |
