busmania Samba Member
Posted: Fri Jul 19, 2019 7:53 am Post subject: About to give up...deluxe window trim |
What is the secret to installing these? I have been using lube in the slots. I bought the tool with the triangle tip on the end. What am I missing? I’m about to either forgo it or take it to a glass shop. It’s rare I give up! Help! |
69BahamaYellow Samba Member
Joined: April 22, 2011 Posts: 537 Location: Talbott, TN
Posted: Fri Jul 19, 2019 8:00 am Post subject: Re: About to give up...deluxe window trim |
Put the trim in the weather-stripping slot prior to installing the glass. It's nearly impossible to do after the glass is installed. I've seen a glass shop do it with lots of extra hands, heat guns and lube, but for the typical do it yourselfer, just take the glass out, install the trim, and reinstall will be much easier..... |
rsbadura Samba Member
Joined: November 30, 2009 Posts: 656 Location: Berlin, Germany
Posted: Fri Jul 19, 2019 8:17 am Post subject: Re: About to give up...deluxe window trim |
busmania wrote: |
What is the secret to installing these?! |
There are 2 different types of trim and also two different rubber for this - that need to fit together:
a) early C-shape with anodized aluminum trim (durable)
b) late T-shape with plastic (get blind by the years)
I did need a tool mounting it into the rubber...
Regards, _________________ Rolf-Stephan Badura
1970 VW Karmann-Ghia Coupe
1979 VW Bus L to camper conversion
1982 Eriba Pan travel trailer
2017 VW CrossPolo
HAZET classic tools
Posted: Fri Jul 19, 2019 8:24 am Post subject: Re: About to give up...deluxe window trim |
69BahamaYellow wrote: |
Yes, all glass is out. Rubber on glass. Still having issues!
Mine is the early C shape trim. |
SGKent Samba Member
Posted: Fri Jul 19, 2019 8:30 am Post subject: Re: About to give up...deluxe window trim |
is it new rubber or old rubber? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Jul 19, 2019 8:33 am Post subject: Re: About to give up...deluxe window trim |
SGKent wrote: |
is it new rubber or old rubber? |
New |
KTPhil Samba Member
Posted: Fri Jul 19, 2019 8:55 am Post subject: Re: About to give up...deluxe window trim |
Lots of blue painters tape helps when you need 8 hands. |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2922 Location: San Diego, CA
Posted: Fri Jul 19, 2019 10:08 am Post subject: Re: About to give up...deluxe window trim |
Windex and duct tape to get everything in place, then remove tape and install. If you use a lube that doesn't evaporate it works against you later and the trim slips out.
chimneyfish Samba Member
Joined: July 28, 2009 Posts: 881 Location: United Kingdom
Posted: Fri Jul 19, 2019 10:13 am Post subject: Re: About to give up...deluxe window trim |
Are your reproduction trim and seal of the same brand?
I use German VEWIB seals and trim on my cars rather than mix and match, as I think that can be a problem trying to get two slightly differently engineered products that haven't been proven to match up by the supplier first to match up.
A generous amount of silicon spray helps, although it sounds like you are doing that. Also, be careful where the trims meet and the chrome trim cover goes over the two ends, they can pop just as you get the glass installed if you get too over enthusiastic (or so I have been told...…….. )
EDIT: I like the sound of the Windex recommended by Anchovy above, maybe the silicon spray was the issue when I had my mishap! I need to do the rear window on my bug soon, so will follow that advice. _________________ 1965 Type 1 Deluxe (1200cc)
1976 Type 2 T2b Microbus L (1800cc Type 4)
Previously...
1972 T2 Camper (Devon), 1988 Golf, 1972 Type 1, 1984 Polo, 1972 T2 Camper (Danbury) |
Posted: Fri Jul 19, 2019 10:59 am Post subject: Re: About to give up...deluxe window trim |
Anchovy wrote: |
Thanks everyone. I’ll try this trick. Part of my issue is it popping out as I move down the window. |
Joined: January 01, 2007 Posts: 16882 Location: sticksville, ct.
Posted: Fri Jul 19, 2019 11:50 am Post subject: Re: About to give up...deluxe window trim |
busmania wrote: |
then it's not deep enough
I did mine dry. start at the seam (or gap) in the trim. 95% of the C shaped trim disappears into the seal. push the trim in with your thumb while gently folding the seal "open"
I did 2 windows a night till I was done. it's brutal on the thumbs _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Jul 19, 2019 12:08 pm Post subject: Re: About to give up...deluxe window trim |
skills@eurocarsplus wrote: |
busmania wrote: |
I did 2 windows a night till I was done. it's brutal on the thumbs |
I think the trim was in enough (it was pretty deep) but I think the lube I was using was too slippery. Boy did that statement sound awesome after I was done writing it!
Anyway I’ll give it another go. |
hperez71 Samba Member
Joined: March 12, 2017 Posts: 60 Location: Puerto Rico
Posted: Fri Jul 26, 2019 9:17 am Post subject: Re: About to give up...deluxe window trim |
I sprayed lots of WD-40 on the groove where the C trim goes after the seal was on the glass. Trim was just pushed in easily. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Fri Jul 26, 2019 9:22 am Post subject: Re: About to give up...deluxe window trim |
hperez71 wrote: |
Silicone spray only. Or boiled linseed oil. WD-40 and any other solvent based lube will eat the rubber. Be careful. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
raygreenwood Samba Member
Posted: Fri Jul 26, 2019 10:55 am Post subject: Re: About to give up...deluxe window trim |
notchboy wrote: |
hperez71 wrote: |
Silicone spray only. Or boiled linseed oil. WD-40 and any other solvent based lube will eat the rubber. Be careful. |
You beat me to it....for Gods sake...do not use WD-40 or any other spray lube that you do not know every single ingredient of.
Silicone spray with no solvents (like dry silicone spray) or silicone oil....
Linseed oil...list "fair" for EPDM chemical compatibility......so use it and then wash it off...but its should be ok. Ray |
