Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Jul 21, 2019 12:17 pm Post subject: Oct 61 Bus(62) 4 Pin Black Box Wiring |
I've done a pretty extensive search under black box and flasher relay for the early hazard light models and wiring diagrams and have not come up with an answer.
I have a four pin box which I believe is correct part # 211 953 215 C. The bus was converted to 12v and the blink-warnlicht Relais is marked 12v.
-31 Ground wire?
KBL Blue wire to speedo?
+49 ?
49a ?
I have two wires pigtailed together black and black green white going to the emergency flasher relay by the passenger headlight. The other wire is also black green white going up to the flasher light switch on the dash.
Do I have the ground and blue wires correct? Where do the others connect to on the emergency flasher relay +49 and 49a? _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14253 Location: Casa de Oro, California
Posted: Sun Jul 21, 2019 6:45 pm Post subject: Re: Oct 61 Bus(62) 4 Pin Black Box Wiring |
Which diagram are you referring to? |
Posted: Sun Jul 21, 2019 9:31 pm Post subject: Re: Oct 61 Bus(62) 4 Pin Black Box Wiring |
I'm using the diagrams from this site, both the 62-65 diagram and the 63 diagram USA with the highlights. _________________ Roads Scholar &
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51112 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jul 21, 2019 9:46 pm Post subject: Re: Oct 61 Bus(62) 4 Pin Black Box Wiring |
I can't recall the terminal numbers on the hazard relay, but on the flasher 49 is power in from the fuse box and 49a is flashed power out to the signal switch and/or hazard relay. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jul 22, 2019 5:15 am Post subject: Re: Oct 61 Bus(62) 4 Pin Black Box Wiring |
Yeee up, after several hours of testing last night, was able to confirm the above as correct. Those early flasher relays sure are persnickity.Thanks for the assist guys. _________________ Roads Scholar &
