Throttle Shaft Clearance With Carburettor Body
Meiang Premium Member
Meiang is offline
PostPosted: Sun Jul 21, 2019 5:50 pm    Post subject: Throttle Shaft Clearance With Carburettor Body Reply with quote
Can anybody tell me what the standard throttle shaft clearance is of a standard Solex 28 PICT carburettor. I would like to measure the deflection on a Solex 28 PICT to see whether it is within specification.
kreemoweet
kreemoweet is online now
PostPosted: Sun Jul 21, 2019 6:02 pm    Post subject: Re: Throttle Shaft Clearance With Carburettor Body Reply with quote
There is no such specification, that has been publicly disclosed.
'67 bug: seized by the authorities
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sun Jul 21, 2019 8:15 pm    Post subject: Re: Throttle Shaft Clearance With Carburettor Body Reply with quote
Yeah, I've never seen a spec on this, I'm thinking it's because VW never issued instructions on fixing it. Fixes were all done in the aftermarket.
I've always just grabbed the throttle arm and tried to rock the throttle shaft back and forth, both at idle and mid-throttle, as the play can vary a little between the two.
Andy T.
-Volunteer Post-Production Sound Editor for Starship Excelsior - A Star Trek Fan Production.
Meiang is offline
PostPosted: Sun Jul 21, 2019 9:22 pm    Post subject: Re: Throttle Shaft Clearance With Carburettor Body Reply with quote
The reason I ask is because I have two NOS Solex 28 PICT carburettors which I believe have excessive throttle shaft clearances (just by feel). Other Solex 28 and Solex 30 carburettors seem to have much tigher tolerances.
I don't believe these carburettors would have been machined incorrectly by the manufacturer.
The modification state numbers are:
721 1779
722 2985
What is unusual about these carburettors is the old tags which were attached to them. They are made of cardboard covered metal with writing in German (I think).
I believe it translates to:
Meister - master
fette seite - fat side
magre seite - lean side
The Android
PostPosted: Sun Jul 21, 2019 9:48 pm    Post subject: Re: Throttle Shaft Clearance With Carburettor Body Reply with quote
Modification State Numbers start with VW. 28PICT don't have them, that didn't start until 28PICT-1, I think you are seeing some form of serial number.
Andy T.
