W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Sun Jul 21, 2019 7:54 pm Post subject: 1904cc maybe bigger? |
Existing motor is a 1904cc , built for my 65 squareback. Originally we went 1904cc to keep the heat exchangers and run the stock solex carbs, that didn’t last, I ended with 36 dells, and the vintage speed sport muffler.
I’m thinking of bumping the cylinders up to thick wall 92’s and new heads.
It’s a daily driver , 5000rpm is fine, more hp , more fun
I have a pair of 45 dells as well that need a rebuild if we are exceeding the capacity of the 36’s
What I have now:
Web Cam Type 1 Camshaft, Grind 163, 105 lobe center
5.5" CB unitech rods, and 90.5mm B pistons
AS41 block, full flowed, decked, bored for 90.5.
DRD L3 heads stock valves cnc ported with 53cc chambers, single high rev springs, 90.5 bore
CB Performance Super Stock Rockers, 1.1:1 Ratio (Rocker Arms)
DPR DELUXE Type 1 Stroker Crankshaft, Type 1 Rod Journals 74mm
Chome Vanadium 12V 200mm Lightened Flywheel - 13lb Flywheel
Schadek 26mm Oil Pump
36 DRLA Dellortos
Vintage speed type 3 sports 1.1/2” good for 125hp _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3818 Location: Georgia
Posted: Sun Jul 21, 2019 8:06 pm Post subject: Re: 1904cc maybe bigger? |
If you’re asking me, I’d go with 94’s for a 2054.
I doubt anyone would notice 54 more cc’s.
I would add more stroke too, but that’s just me. _________________ Volkswagen!
(Compression 8.7:1) |
W1K1 Samba Member
Posted: Mon Jul 22, 2019 8:06 am Post subject: Re: 1904cc maybe bigger? |
94's are not a good choice for a T3 though, thats why i was leaning towards the 92 thick walls, and the L3 heads need to be freshened up, so I was wondering if there was an upgrade, without spoiling the wide powerband the web 163 is giving right now.
I would still like to be able to use the VS muffler with 1.1/2" pipes, since exhaust choices on T3's is limited too. I do have a mocal fan/cooler already hooked up to the current engine as well. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
W1K1 Samba Member
Posted: Tue Jul 23, 2019 10:37 am Post subject: Re: 1904cc maybe bigger? |
Looks like John at aircooled.net has basically what I am looking at with the 2054cc engine parts list:
2054cc Engine Parts List, for Convertible Beetles and Ghias, THINGs, Busses, and Type 3s!
This one has mild heads, a stroker crank, and super reliable THICK WALL 92mm P&Cs, which will hold up under the extra heat from Convertibles, THINGs, Busses, and Type 3s!
At the minimum you will need dual 1bbl carbs, but optimally it will have dual 2bbls (Dual 36 or 40mm DRLAs, or 40 IDFs). Also, know that the exhaust system you are going to use will determine the best heads to select! For example, if you are going to run 1 3/8″ exhaust, you are limited to stock dual port heads, or L3 dual port heads. If you bump up to heads like our Panchitos Cylinder Heads, you can run 1 1/2 or 1 5/8″ exhaust.
With this engine you don’t want to go crazy with the camshaft, since the vehicle is heavier.
76mm 4340 chromoly crankshaft w/VW journals
5.500″ H-beam connecting rods or 5.500″ I-beam connecting rods
Web Cam 163 Camshaft (If you have dual 2bbl carbs)
L3 Cylinder Heads if you are restricted to 1 3/8″ exhaust OR Panchitos Cylinder Heads if you can go 1 1/2 or 1 5/8″ exhaust
3.5qt Deep Sump
92x82mm piston and cylinder kit be sure to bore the case and heads to the 94mm size, since these P&Cs use the super thick cylinder at the top and bottom!
1.1:1 Ratio rocker arms or 1.25 Rocker Arms
Dual 40 Weber IDF carb kit _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Tue Jul 23, 2019 11:44 am Post subject: Re: 1904cc maybe bigger? |
I had a 69 Fastback with a 69X94 motor, and it ran beautifully. No overheating issues at all. As well as a 68 Camper Bus with a 82X94 motor that ran just fine as well. _________________ If you`re going to do something, do it right. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Tue Jul 23, 2019 1:42 pm Post subject: Re: 1904cc maybe bigger? |
It depends very much on which " generation" L3's you have. The earlier versions especially the ones that was sold directly from drd wohnt support anything larger than 1776 in a decent manner. The later from John which are based on the Aa 500 cast are much better. I would consider 2 l displacement absolutely max for even those heads |
W1K1 Samba Member
Posted: Tue Jul 23, 2019 2:40 pm Post subject: Re: 1904cc maybe bigger? |
I bought them from DRD back in 2011, everything else came from John
So if we went with the 92 thick walls and the panchito heads+ 1:1.25 rocker arms?
would I stay with the 36 dells, or rebuild the 45 dells?
also like to stay with the vintage speed 1.1/2 Type 3 exhaust
L3 heads
1973 super
Posted: Tue Jul 23, 2019 3:26 pm Post subject: Re: 1904cc maybe bigger? |
Ok. Those are the later version from him. They need a proper valve and seat job along with some better guides. Then they can work well. With some good detailing of the ports they can support up to about 130 hp
Especially if you chose the Panchito's you should rebuild the 45's and install 34 mm venturies in them |
ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Tue Jul 23, 2019 3:32 pm Post subject: Re: 1904cc maybe bigger? |
I built a 2007 with L3s (the ones on the 043 casting) and used a web 163 and it was a nice all around motor.
Ruined it when I went with big valve 042s. WAY less snappy. Reved higher but was pretty lame down low. The 042s even had more compression with the 54cc chambers. FWIW |
W1K1 Samba Member
Posted: Wed Jul 24, 2019 12:11 pm Post subject: Re: 1904cc maybe bigger? |
so I guess I have a plan then:
Web Cam 163, 105 lobe center
92mm thick wall pistons/cylinders, cut for 90.5 case
panchito heads bored for 94mm, 56cc
CB Performance Super Stock Rockers, 1.25:1 Ratio (Rocker Arms)
45 DRLA Dellortos
the 56cc combustion chamber puts us in the right range with .040" (8.8 ) or .050" (8.6) for the web 163 _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3291 Location: Rapid City, SD
Posted: Wed Jul 24, 2019 12:55 pm Post subject: Re: 1904cc maybe bigger? |
If you are buying a crank, the 76mm, 5.5 rods, and B height pistons is a pretty easy combo. The case doesn't need much more clearance work, and the deck height is usually right close to a perfect .045". Lighter pistons also.
A 92x76 2021cc will make better use of the bigger heads and carbs also. The 163, 1.25 and Panchito's will work really good with the larger displacement.
When you order the Panchito's make sure you get the CNC chamber option.
Brian _________________ www.type-emotorsports.com |
W1K1 Samba Member
Posted: Wed Jul 24, 2019 1:24 pm Post subject: Re: 1904cc maybe bigger? |
I have the 74 crank from my 1904cc
the only thing I need to order is the panchito heads and 92 P&Cs. and have my 45 dells rebuilt
otherwise we are on that slippery slope of ... well if I replace the crank it's gonna be an 82........... _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
Posted: Wed Jul 24, 2019 5:52 pm Post subject: Re: 1904cc maybe bigger? |
And maybe get the ported manifolds to match the heads. _________________ If you`re going to do something, do it right. |
sled Samba Member
Posted: Wed Jul 24, 2019 6:15 pm Post subject: Re: 1904cc maybe bigger? |
Bryan67 wrote: |
And maybe get the ported manifolds to match the heads. |
this should be an absolute. I'm surprised the manifolds are not included with the heads with the option to DELETE them when ordering. _________________ drive your split. |
W1K1 Samba Member
Posted: Wed Jul 24, 2019 8:40 pm Post subject: Re: 1904cc maybe bigger? |
sled wrote: |
Bryan67 wrote: |
this should be an absolute. I'm surprised the manifolds are not included with the heads with the option to DELETE them when ordering. |
Except we are talking a type 3 and don’t get that option from CB, I’ll check my type 3 manifolds when the heads come.
The CNC chamber option bumps them to 61cc which with a deck height of .040” would drop the compression to 8.3
Maybe I’m looking at it from the wrong way, if we went to 82 stroke and stay with the 90.5 P&C I’m back to the old familiar 2110cc _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
W1K1 Samba Member
Posted: Thu Jul 25, 2019 11:34 am Post subject: Re: 1904cc to 2110cc |
I guess the other way to look at it is a 90.5 x 82 2110cc, which we have done before a couple times for beetles
90.5 mm pistons/cylinders
panchito heads bored for 90.5mm, 61cc CNC chamber
DPR DELUXE Type 1 Stroker Crankshaft, 82mm
45 DRLA Dellortos
the big question is when do you exceed the exhaust? , and is the cam still a viable cam?
or do we go back to the beginning and start from scratch.
Remembering it's a heavy type 3, daily driver, 5500rpm, lots of bottom end torque. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
Posted: Thu Jul 25, 2019 11:55 am Post subject: Re: 1904cc maybe bigger? |
I think the super short curvy intake manifolds might be the limit of the whole engine. With the 2110cc, I am pretty sure you will be past the 125hp limit on the exhaust.
Your Panchito/163/1.25 combo will make awesome torque in a 2000cc+, and it will be perfect for a type 3.
Don't forget you will need new B pistons if you bump it too a 82mm crank.
I would just run turned down 94's on the crank you have now. 2054cc No case machining, no new crank, etc. Lots of people run 94's in buses and have no problems. Myself included.
74 Thing Samba Member
Posted: Thu Jul 25, 2019 12:18 pm Post subject: Re: 1904cc maybe bigger? |
Get the CNC heads and have them flycut to the cc's you want. |
sled Samba Member
Posted: Thu Jul 25, 2019 6:56 pm Post subject: Re: 1904cc maybe bigger? |
74 Thing wrote: |
yes, this
if you're willing to go 82 stroke but do not want to bore the case, then you should throw in some thick wall 92's
but if you're going to clearance/machine the case for an 82, then you could also open it up for 94s? a 2276 would be just fine (very fun) in a type 3.
you'll need to correctly port your own manifolds to work with the heads.
snowball effect... _________________ drive your split. |
rodgersbadassbus64 Samba Member
Joined: January 24, 2009 Posts: 418 Location: Ortonville, Minnesota
Posted: Thu Jul 25, 2019 8:41 pm Post subject: Re: 1904cc maybe bigger? |
I really dig 74 x 90.5 in my bus. I have a big motor too but I like the 74 it's not nervous and fun on the road:) |
