dubsteez79 Samba Member
Joined: November 22, 2017 Posts: 194 Location: star nc
Posted: Mon Jul 22, 2019 7:24 am Post subject: Reflective heat tape under engine tins |
Has anyone added the gold heat tape that you can get from auto parts stores underneath the engine tins where the header/exhaust is? Ive used it before with good results to protect a fuel tank from muffler heat but this will be much hotter than that. Link is below. Im thinking about adding it to mine since the extractor header is getting the tins extremely hot and I feel like that could be contributing to my hot start(fuel boiling) problems. I know my EMPI EPC manifolds are probably the main culprit but the CB ones wont be here until the weekend. Plus, i dont see how it would negatively effect anything to have this tape under the tins. If anyone is interested, I will take readings of engine bay temps with and without it, just for general information. Let me know your experiences.
https://designengineering.com/reflect-a-gold-heat-reflective-sheet/ |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13846 Location: White Mountains Arizona
Posted: Mon Jul 22, 2019 9:31 am Post subject: Re: Reflective heat tape under engine tins |
My take on that is the German engineers may have tried that and found that black tin works fine. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Joined: August 31, 2013 Posts: 12846 Location: North Carolina
Posted: Mon Jul 22, 2019 9:39 am Post subject: Re: Reflective heat tape under engine tins |
Get a section of 2" exhaust pipe, cut it in half & make a heat shield to attach to the top of the header pipe between the pipe & the head. The header pipe is not only heating up the head, but it is also heating up the pushrod tubes which will also heat up the oil returning to the engine. Reflective tape may make the push rod tubes even hotter. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
bluebus86 Banned
Posted: Mon Jul 22, 2019 10:35 am Post subject: Re: Reflective heat tape under engine tins |
I bent some aluminum sheet metal, perhaps .03 inch thick to fit between the header pipe and the head/cylinder areas as a heat shield. They attached to modified sled tin to do the job.
With header pipes in place of stock heat exchanger boxes, you need to fabricate some sheet metal heat shielding to do the job that the exchanger boxes did, ie keeping metal stand off between the header and the engine. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Mon Jul 22, 2019 11:18 am Post subject: Re: Reflective heat tape under engine tins |
Thanks for the input!
To be clear, im running heater boxes and an extractor style header. My whole exhaust is ceramic coated as well. I also have the large diameter aluminum pushrod tubes from SCAT. They are a similar color to this tape. Just trying to knock down the engine bay temps as much as possible without running a standoff. I figured someone on here would have at least tried this at some point as I have used it on builds, as well as some of my car buddies. Especially in turbo applications. I want to run an experiment with different configurations and record temperatures at different spots in the bay and on the underside of the engine. Ill update once i begin the experiment. Any input on specific places to measure temp would be appreciated. Ill be measuring with a IR gun. |
