Main bearing issues-crap!
67 Sunroof
67 Sunroof is offline
PostPosted: Mon Jul 22, 2019 8:12 am    Post subject: Main bearing issues-crap! Reply with quote
Ok so I was able to get my camshaft in and set the cam and thrust. I measured the thrust and there is a good clearance and the cam spins freely! Yeahhh!
The main bearings fit in the case great without any wobbles.
The crank is a cb 69mm. I went to put the bearings on the crank and they donít fit. Too small.
They say a picture is worth a thousand words so Iíll just post my measurements in the picture.
The top measurements are obviously the main bearings I.D.
The bottom measurements are the crank O.D.
So Iím guessing my bearings are the wrong size? Iím confused.
Sorry for the newbie question again!
More pics:
mcmscott
mcmscott is offline
PostPosted: Mon Jul 22, 2019 8:39 am    Post subject: Re: Main bearing issues-crap! Reply with quote
.020 crank/ .020 case. your crank is standard.
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
67 Sunroof
PostPosted: Mon Jul 22, 2019 9:41 am    Post subject: Re: Main bearing issues-crap! Reply with quote
Could you clarify? I know the case was align bored .020 and I ordered bearings without any thrust and .020 size.
The bearing are too small for the crank or the crank is too big for the bearings. Iím guessing my bearings ID are too small. Weird.
TheViking
TheViking is offline
PostPosted: Mon Jul 22, 2019 9:48 am    Post subject: Re: Main bearing issues-crap! Reply with quote
He says that you have bearings that is made for cranks that is gorunded down .020
AlteWagen
Troll
AlteWagen is offline
PostPosted: Mon Jul 22, 2019 11:11 am    Post subject: Re: Main bearing issues-crap! Reply with quote
The entire bearing part number list is at the end of the blueprinting sheet
Looks like you need 111198471
Crank Case Thrust
111 198 471 STD .020 STD
https://www.thesamba.com/vw/archives/info/blueprinting_worksheet.php
Official Dual Carb Thread
turboblue
turboblue is offline
PostPosted: Mon Jul 22, 2019 12:35 pm    Post subject: Re: Main bearing issues-crap! Reply with quote
https://www.davis-motorsports.com/guide-vw-type-1-engine-bearings/
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
My Website
Shop Facebook Page
mark tucker
mark tucker is offline
PostPosted: Mon Jul 22, 2019 1:45 pm    Post subject: Re: Main bearing issues-crap! Reply with quote
thats eazy, those are the rong bearings. Shocked
fl59bug
fl59bug is offline
PostPosted: Mon Jul 22, 2019 2:01 pm    Post subject: Re: Main bearing issues-crap! Reply with quote
https://www2.cip1.com/ProductDetails.asp?ProductCode=C24%2D111%2D198%2D471%2DSL
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Jul 22, 2019 2:07 pm    Post subject: Re: Main bearing issues-crap! Reply with quote
Bearings have 3 measurements.
Case / Crank / Thrust
Your case is .020", the crank is STD and the thrust is STD.
You got .020"/.020"/STD
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
67 Sunroof
PostPosted: Mon Jul 22, 2019 9:23 pm    Post subject: Re: Main bearing issues-crap! Reply with quote
Thanks for the link fl59bug. Thatís the ones I need.
Now that itís been explained (and I ruined the set I have) Iíll know for my next motor I build. Haha. (I had already notched the bearings)
Thank you for clarifying for me. Iím actually not afraid to ask stupid questions. I would rather ask now than not ask later and have problems....
Embarassed
Howard 111
Howard 111 is offline
PostPosted: Mon Jul 22, 2019 9:59 pm    Post subject: Re: Main bearing issues-crap! Reply with quote
We ALL had to learn the fine points of building an engine. Now you know what you need to proceed. Good luck with it, and ask before you modify a part that still doesn't fit.
1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270
67 Sunroof
PostPosted: Mon Jul 22, 2019 10:32 pm    Post subject: Re: Main bearing issues-crap! Reply with quote
I didnít modify a part to MAKE it fit.
I tried the bearings in the journals and they fit great. Then decided to notch the bearings.....THEN tried to slip the bearings onto the crank and uh! oh!
Lesson learned. Should have test fitted them BEFORE notching them.
