VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9954 Location: Huntington Beach, CA
Posted: Sun Feb 28, 2021 11:19 am Post subject: Re: Jimmy V’s 54 Oval Project |
Thank you, to both of you.
Don, just the control arms will be used. I am not going to change the beam. The OG steering box will get rebuilt. Plus I have already rebuilt the king and links from the OG one, so those are going onto the new arms. I am just happy to have found arms! That was a hard to find part!
Down side is that the later beam has needle bearings in the tubes. Way better that the Mylar ones in the earlier tubes. And as mentioned the steering dampener. But, I do not plan on making this a daily commuter. It will be for cruising up and down PCH every sunny weekend. I do this now in the 70 Bug and love it! But I bet the 54 will be a better experience! Well maybe, it’s been fun blowing people’s minds when I pull off the line and fly down the street! This Bug will not be so fast, maybe 114 less horse power!
Here is the new to me arms in the tubes, with the rebuilt axle assemble on those. I did not push the Link Pin in all the way. Still need to clean things up!
Looks like it ought to work!
Any experience or thoughts? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Volksvr6gti Samba Member
Joined: July 22, 2019 Posts: 298 Location: Jacksonville
Posted: Sun Feb 28, 2021 11:43 am Post subject: Re: Jimmy V’s 54 Oval Project |
looks nice. As for those trailing arms I believe SoCal imports sells them. They are supposed to be refinished ones for about 40$ each. |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1772 Location: Winnipeg
Posted: Sun Feb 28, 2021 3:07 pm Post subject: Re: Jimmy V’s 54 Oval Project |
I don't know... We will all find out together!
Don _________________ Better and better mistakes! |
Posted: Sun Feb 28, 2021 5:00 pm Post subject: Re: Jimmy V’s 54 Oval Project |
So, called a few buddies that have worked on Bugs longer than myself. Good times remembering back to when we wrenched together!!! Anyways, long to short. 54 is the cut off year for the change in the front trailing arms. VW started to machine an lubrication channel for longer arm life into the ends of the arms. I can see it on the faces of the arms. From top to bottom. Late, late, early.
Looks like my Bug already had a change of arms at some point! Go figure! Can you see how flat the original arm face was where it rides against the link pin shim stack? Pretty cool to see and now, know!
Not going to spend anymore time searching for earlier arms. Anything below mid 55 is really hard to find. Plus I am unwilling to shell out another grand on the car on a part. If a used beam pops up, sure I will grab it and install those arms, but I am no longer looking. Later arms are going to the blasters, along with a shit load of parts! _________________ Jimbo
TDCTDI wrote: |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sun Feb 28, 2021 9:30 pm Post subject: Re: Jimmy V’s 54 Oval Project |
Another later mod was the pinched in end where the leaves sit, stops the leaves walking if anything loosens _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3841 Location: San Jose, CA
Posted: Mon Mar 01, 2021 9:36 am Post subject: Re: Jimmy V’s 54 Oval Project |
66brm wrote: |
Another later mod was the pinched in end where the leaves sit, stops the leaves walking if anything loosens |
I had noticed those two punch marks and was wondering what they were for. Thanks for the great info! Learn something every day! Even after 40 plus years! _________________ Jimbo
TDCTDI wrote: |
Posted: Mon Mar 01, 2021 9:42 am Post subject: Re: Jimmy V’s 54 Oval Project |
Wow! I have never stopped to think about what the dished shim or the MIA oring did before. It would help to keep the grease in. Pretty cool how you can see the evolution taking place within these cars! It is one of those cool things about them.
Thanks man! I have always just repaired them. Never did much thinking about the engineering. Really cool! I knew some front ends had solid faces, some grooves faces, some thicker carrier bolt holder area and some thinner. It really was always getting better, as a car! Very cool! _________________ Jimbo
TDCTDI wrote: |
Posted: Mon Mar 01, 2021 10:42 am Post subject: Re: Jimmy V’s 54 Oval Project |
Jimbo, I just got to pulling apart my stock beam on my 56. I just got the trailing arms off and they look just like your early ones that you were saying stopped at 54. Mine do not have that pinched end where the torsion bars stop, they are a perfect square like your early ones. Mine also do not have the step down where the link pins go, they are flat and smooth like yours. I wonder if those dates are correct or not. Anyone else with a 56 or later might be able to comment about theirs |
Posted: Tue Mar 02, 2021 12:04 am Post subject: Re: Jimmy V’s 54 Oval Project |
Volksvr6gti wrote: |
The body number is stamped on the drivers side bump stop post. Take a look at it to determine the year. Not saying you did not, but just to make sure. I have seen many Bugs with a different beam in them! _________________ Jimbo
TDCTDI wrote: |
66brm Samba Member
Posted: Tue Mar 02, 2021 12:15 am Post subject: Re: Jimmy V’s 54 Oval Project |
The trailing arms changed in 1960 along with the shim number to accommodate the change to orings.pre 60 uses 10 shims each link pin after 60 uses 8 _________________ Aust. RHD 66 Type 1
modok wrote: |
Posted: Wed Mar 03, 2021 7:18 pm Post subject: Re: Jimmy V’s 54 Oval Project |
You are indeed correct on my beam Jimbo. The number on the bump stop and the number on the body stamp do not match. Must have swapped at some point. |
Dan22 Samba Member
Joined: August 30, 2019 Posts: 465 Location: Battle Ground, WA
Posted: Wed Mar 03, 2021 9:15 pm Post subject: Re: Jimmy V’s 54 Oval Project |
The beam number and the body number do not match ever. They are a unique series. You can see the beam numbers vs body and VIN in the technical section. _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
Posted: Thu Mar 04, 2021 5:37 am Post subject: Re: Jimmy V’s 54 Oval Project |
Dan22 wrote: |
The beam number and the body number do not match ever. They are a unique series. You can see the beam numbers vs body and VIN in the technical section. |
Well in that case my beam number is spot on for an April 56 and matches my body and chassis. So maybe these trailing arms didn’t change until a little later. |
Posted: Wed Mar 24, 2021 8:36 am Post subject: Re: Jimmy V’s 54 Oval Project |
Looks like I am getting shut down. My fucking home owners association finally is telling me to “stop”. The neighbors in back of me are complete assholes, so I get why. It is what it is. Right?
On the up side. The HOA did not say I had to stop having a hobby! So, there is that. So, my new hobby will be rebuilding parts to old cars. Going to go out and buy a sand blast cabinet. Then run the shit out of it. Figure that will get me through the next several months. Maybe by then I will have a plan for the body work that still needs to be done. I am so close! Or maybe I will plan to take “a vacation” and work 24-7 for 1 month, at home, working on the Bug. They could levy their “penalty fee” for the month against my disobedience. Probably be cheaper than securing a new work sight location, setting it up and moving into it! Heck, I would also need to purchase insurance. Yep, going to push the boundaries!
So, finally got a new direction! I can stop pushing emails and get back to the Bug! Hopefully I can land a sand blast cabinet this weekend and get it set up! _________________ Jimbo
TDCTDI wrote: |
1958ghia Samba Member
Posted: Wed Mar 24, 2021 9:55 am Post subject: Re: Jimmy V’s 54 Oval Project |
That is ridiculous! There should be posted "quiet hours" in your HOA paperwork, and as long as you are working on your bodywork/car outside of those quiet hours, they can't say shit! It is no different from a construction site across the street that operates during normal business hours building a house exactly like the one your neighbors are living in.... |
Posted: Wed Mar 24, 2021 1:24 pm Post subject: Re: Jimmy V’s 54 Oval Project |
This is the first I have ever heard of a HOA. Don't know if we have such a thing in socialist Kanada. I am amazed that in the Land of the Free a HOA could even exist.
nshaddox Samba Member
Joined: January 18, 2005 Posts: 612 Location: Hammatramma, MI
Posted: Wed Mar 24, 2021 6:17 pm Post subject: Re: Jimmy V’s 54 Oval Project |
Total bummer dude. Was just thinking it’d been a while since we’d seen an update. I’m sure you will find a work around. |
Posted: Wed Mar 24, 2021 11:10 pm Post subject: Re: Jimmy V’s 54 Oval Project |
1958ghia wrote: |
Yep! Total bullshit! I will give it to them, they are persistent. Been 5 years of back and forth. And me always finding a loop hole or a issue with their boiler plate. Not this time. Think they got me. _________________ Jimbo
TDCTDI wrote: |
Posted: Wed Mar 24, 2021 11:17 pm Post subject: Re: Jimmy V’s 54 Oval Project |
sunroof wrote: |
Don |
Me and you both! And to live in a delusion of”...and the pursuit of happiness.”, as an inalienable right. I do not get how or why. But I am thinking I would have to pony up some serious cash to seek an answer. Money is to hard to come by and keep. So, that ain’t happening.
Instead, I will be a thorn. Quiet one month. Loud and chaotic the next. Pay a fine for my issues. Then back to quiet for a month. Then noisy again. Pay. Rinse, repeat!
Bastards are not going to stop me. But they are, finally going to slow me down, a little bit. _________________ Jimbo
TDCTDI wrote: |
