VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Mon Nov 15, 2021 8:58 pm Post subject: Re: Jimmy V’s 54 Oval Project |
Busstom wrote: |
Hell yeah Jimbo, beach, babe, and Bug! Lovin' it |
Thanks! I love my life! No complaints. No regrets! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sun Nov 21, 2021 12:14 pm Post subject: Re: Jimmy V’s 54 Oval Project |
David wrote: |
MeeferMadness wrote: |
Jim: There is a place here in Eugene OR that does full body chemical dipping. |
Is this the place you're talking about?
http://metaldipping.com/
I ran into them when I was searching for a dipper/electroplating shop.
Buggeee wrote: |
There is a place here in Ohio where you can dip a whole body into a vat of some kind of chemical bath that etches everything to clean metal inside and out. I saw someone on a build thread here had that done and also the place then dipped it in something else to seal it up before primer. It very dark gray afterwards. Probably you've already looked into it.
Excellent to reach this stage. Wishing you continued health. |
This sounds like e-coating. I found a place in Lousiana that does the dipping and the e-coating.
https://selectmotors.net/automotive-chemical-stripping-and-e-coating/ |
Sorry for the long pause in my response. I had to find the time, to go back through my notes and then respond. No, that is a different business. I was thinking of Strip Clean Company. After a lot of research, they closed shop some where around 2011. Too bad for me. They were only 20 minutes away. Missed it by that much. _________________ Jimbo
TDCTDI wrote: |
Posted: Sun Nov 21, 2021 9:25 pm Post subject: Re: Jimmy V’s 54 Oval Project |
Another 4 hours grinding and welding! It all adds up and it is getting closer to going out for blasting or dipping.
But I don’t want to get ahead of myself. Let’s just focus at the task at hand. Pulled the Bug out and rotated it onto its side, so that I could grind some of the luggage shelf goobers down.
Started here and primed it.
Then rotated it to the bottom again and finished up the heater channel to lower luggage crossover.
After that, I dove into the front bulkhead wall’s lower corners. They were badly rusted on the interior side. Had to remove a chunk and weld in new steel, on both ends! Started on the driver’s side.
Close up. Can you believe this has held up for a year, plus some!
Drew a cut line.
Drilled out a hole to relieve any stresses later in life. Pilot hole. Followed by a bigger hole.
Then a cut across the line.
Cut it as close as I could to the side panel. But ended up needing to snip the last little bit.
Here it comes!
Had to wiggle it with some pliers.
Finally!!!
Now I need to fill this spot.
All welded up and ground down. Stronger than before I started.
Will still need to weld the bottom to the channel.
But let’s do the other side while the process is fresh!
And that is the dinner bell!
Hope all of you spend some time with those you love and enjoy a good meal! Have a happy Ham (Turkey) day! I hate Turkey! _________________ Jimbo
TDCTDI wrote: |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2009 Location: Texas
Posted: Mon Nov 22, 2021 6:14 am Post subject: Re: Jimmy V’s 54 Oval Project |
Love seeing the detailed progress pics and detailed progress. Keep it up - looking great! _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Posted: Mon Nov 22, 2021 9:27 am Post subject: Re: Jimmy V’s 54 Oval Project |
sportin-wood wrote: |
Love seeing the detailed progress pics and detailed progress. Keep it up - looking great! |
Thanks! I love seeing them as well! It means some type of forward progression was achieved. I am looking forward to having a few days off, this weekend. Maybe, just maybe, I can get a full day in on the Bug. It has been a long time since I have had a chunk of free time off.
Thanks for checking in! _________________ Jimbo
TDCTDI wrote: |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
Posted: Mon Nov 22, 2021 7:53 pm Post subject: Re: Jimmy V’s 54 Oval Project |
Buggeee wrote: |
Look here before you... behold Geoge Washington's axe! (Mind you, the handle has been replaced five times and the head twice).
This Oval could not have found a better home. |
Could not agree more! Makes me think of this song by Johnny Cash!
TDCTDI wrote: |
MACJELLY58 Samba Member
Joined: September 26, 2014 Posts: 400 Location: HONOLULU, HAWAII
Posted: Wed Nov 24, 2021 12:29 am Post subject: Re: Jimmy V’s 54 Oval Project |
That Rotisserie sure is a back saver! I can hear your back saying "thank you" from here. Nice work and have a great Holiday! |
Posted: Wed Nov 24, 2021 3:15 pm Post subject: Re: Jimmy V’s 54 Oval Project |
MACJELLY58 wrote: |
Thanks brother! My back is super happy!
You have a great holiday as well! _________________ Jimbo
TDCTDI wrote: |
Posted: Wed Nov 24, 2021 3:31 pm Post subject: Re: Jimmy V’s 54 Oval Project |
The front windshield from Kaefer Nostalgie came in yesterday. I had heard through some buddies that front glass was going to be, “ hard to get” in the upcoming several months, so I ordered one hoping to get it in a few months.
Yesterday when I got home, out on the front porch was a big box.
Picked it up, took it out to the Kitchen. Laid it on the island and opened it up. I got a sideways look from the wifey. But she was happy for me!
It was less than well wrapped. I was really scared that it may have been damaged during its journey. As you can see, the box was less than stellar!
I was so excited that it was not damaged, after opening it, that I took it out to the car and sat it in place.
Nice fit! And it has a logo on it!
Until next time! _________________ Jimbo
TDCTDI wrote: |
scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
Posted: Wed Nov 24, 2021 4:48 pm Post subject: Re: Jimmy V’s 54 Oval Project |
scotty timmerman wrote: |
I had gotten one of those windshields too. Then I discovered it was not laminated safety glass. If a rock or something hits it, it will explode into pieces. So I decided to get a laminated windshield cut to be safer. Just hope you know that. I did however like the sekurit logo. |
Thanks man! That sucks! I was Uber excited! That is the second strike against that company. I now know better. They sell shit! Guess I will return it and get a better one.
Thank you!
Where did you get one from? _________________ Jimbo
TDCTDI wrote: |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Nov 24, 2021 6:04 pm Post subject: Re: Jimmy V’s 54 Oval Project |
I saw the same thing, and decided to wait till I could get one cut also. I may make a "Sekurit" stencil on the water jet and try etching the glass myself with a sandblaster. _________________ modok wrote:
Posted: Wed Nov 24, 2021 6:20 pm Post subject: Re: Jimmy V’s 54 Oval Project |
VW_Jimbo wrote: |
Thank you!
Where did you get one from? |
They do say it in their add "5mm tempered glass". I missed it because I was too focused on the logo. It is how the original one was though. I took the one I bought to my local speedy glass and they cut one for me. |
I just assumed that they would need to meet current laws regarding glass for automobiles. As a contractor, we are always having to meet current standards due to government policies. Figured imported items like AUTOMOTIVE PARTS, would be under the same parameters, due to public safety!
I will be sending this back and getting one made. One more thing to do! _________________ Jimbo
TDCTDI wrote: |
Posted: Wed Nov 24, 2021 6:23 pm Post subject: Re: Jimmy V’s 54 Oval Project |
esde wrote: |
I saw the same thing, and decided to wait till I could get one cut also. I may make a "Sekurit" stencil on the water jet and try etching the glass myself with a sandblaster. |
Keep me updated on the stenciling! I was thinking sand blaster. I have a small one for spark plugs. If I knew I could seal the lettering 100%, I would go for it. But I do not know a good method. Maybe silicon sealant! Maybe, IN MY SPARE TIME, I will try it on a piece of glass. Don’t hold your breathe! _________________ Jimbo
TDCTDI wrote: |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3333 Location: 802 The Pointless Forrest
Posted: Thu Nov 25, 2021 6:54 am Post subject: Re: Jimmy V’s 54 Oval Project |
Acetate ? _________________ "Albatross"! |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1774 Location: Winnipeg
Posted: Thu Nov 25, 2021 8:00 am Post subject: Re: Jimmy V’s 54 Oval Project |
I took my old broken windshield to an autoglass place and they cut me a new one with the correct glass for $150. Cheap. Something that few people know is that glass is a viscous fluid not a solid and so it changes over time, it gets more brittle as it ages. For windshields, new is better.
Don _________________ Better and better mistakes! |
Posted: Thu Nov 25, 2021 11:08 am Post subject: Re: Jimmy V’s 54 Oval Project |
sunroof wrote: |
Don |
Awesome! I will make a template out of hardboard and take it to the glass shop I subcontract out to. They ought to take care of me!
Amorphous Solid Is the term you want to use here. Cool thing! I had my first real interaction with this event when me and the wife, 2 years into marriage, bought a huge fixer upper. It was a 1908 2 story Craftsman, in a historic downtown area in Upland, CA. All of the sashes had lost their cords, so I opted to go through the whole house and record them all. I was also going to replace a pane of glass with a crack in it. I took the window down to the local glass shop and asked if they could cut me a piece of glass “like this one”?.?. The guy behind the counter, 60 some years old, opened up the classroom, right then and there, and gave me a full disquisition on glass properties, application and techniques for the installation of such! To keep it simple, it was the longest wait time EVER for a building material product. BUT, I have reflected several times upon that conversation and, maybe a decade ago, became fully appreciative of that lecture! Thanks glass man. I do not know his name.
So cool! One more. He showed me the change in thickness from the top of the glass, to the bottom of the glass, in my old window pane. I went back to the house and looked at each sash, so I could see the waves!
Thanks for the memory! I love learning! _________________ Jimbo
TDCTDI wrote: |
