ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Fri Jul 26, 2019 8:14 am Post subject: Kadron horsepower limit? |
As the title asks, anybody know much power Kadrons are capable of- with 28mm venturis? with 30 mm venturis? Thanks! Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
74 Thing Samba Member
Bugsy61 Samba Member
Joined: March 20, 2011 Posts: 256 Location: Peoria, Illinois
Posted: Fri Jul 26, 2019 1:24 pm Post subject: Re: Kadron horsepower limit? |
If you put enough cam in to make power, Kadrons don't idle very well. Not a problem for a race engine, not to good on the street. If you put a cam in that idles decent, won't make a whole lot of power. That is the problem with Kadrons. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7213 Location: Videbaek Denmark
Posted: Fri Jul 26, 2019 5:10 pm Post subject: Re: Kadron horsepower limit? |
Yes, Kads can support A LOT of power if you do it right. But as said, if you want a decent idle and lower rpm behaviure you need to chose the cam and set up very carefully.
Jeff @ Kaddieshack did a nice test and write up on the importance of stacks and air cleaner choice here: http://kaddieshack.com/aircleanerdyno.html
He used 44´s for that test.
The out of the box 40 mm Kads will support about 100 hp in a decent set up.
The limitations of the Kads is not the carburettor as such, its the manifolds. They are horrible for any serius performance. Back in 2014 I built a 2110 type 1 with a Web 218/119 cam, ported heads, 40 x 35 mm valves, 9-1, 1,25 rockers etc etc. I used 40 Kads with 34 mm venturies and modded for SVDA run by a Mallory Hyfire CDI. I took a set of stock manifolds and had a friend to weld a full 0,3" on to them, so I could make the manifold shape I wanted. I invested about a days worth of porting and modifying the manifolds. it runs stock type air cleaners, but I also cut up up a set of stacks and had them protrude a little over 1½" into the filter. I also lifted the carburettors ½" with an extension between the manifolds and the carbs. The end result was a Kadron fed engine that ran very reasonable at idle (975 rpm) and went like a bat out of you know where right off idle. The engine pulls a very solid 135 hp at 5500 rpm.
I´m sure they will support 140 hp with more cam and CR. But this is a street driven engine. |
