sanhozeezee Samba Member
Joined: June 17, 2019 Posts: 171 Location: SF Bay Area
Posted: Sun Aug 04, 2019 11:28 pm Post subject: help with weird tapping sound on 1641 dp motor... |
so recently my 67 started to make this weird noise on the left (drivers) side. i adjusted the valves #1 exhaust valve seems to have stuck with about .004 clearance and won’t adjust no matter how far i back out the set screw. other than that the others were fine.
power seems all there just the tapping sound. any ideas what to check?
btw, here’s a video i found of another persons 67 dp motor that’s making the exact same sound.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon Aug 05, 2019 8:38 am Post subject: Re: help with weird tapping sound on 1641 dp motor... |
sanhozeezee wrote: |
i adjusted the valves #1 exhaust valve seems to have stuck with about .004 clearance and won’t adjust no matter how far i back out the set screw. other than that the others were fine. |
Would be much better for you to post a video of your engine. While the video the other person posted might sound like yours, to others your engine might have just a slight difference from that.
That does not make any sense. Would make sense if you were getting no gap. Time to pull the rocker assemblies to check how even the valve stems are to each other and inspect the push rods.
Do not pull the push rods out all at once and mix them up. Inspect one at a time, _________________ In Stereo, Where Available! |
Posted: Mon Aug 05, 2019 9:54 am Post subject: Re: help with weird tapping sound on 1641 dp motor... |
here's a video of my motor. it doesn't seem to sound as loud today but you can hear when i drop the camera near the left valve cover the tapping is more evident.
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Mon Aug 05, 2019 1:09 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
I agree .
many people like to adjust valves at TDC firing for each cylinder because there is less turning of the engine.
I like to adjust valves by looking which valve is open all the way. Then adjust the valve that's closed. eg. if #1 intake is open all the way, adjust #1 exhaust. If this is done correctly you are ensuring that the lifter is on the low point of the cam when adjusting, and you really only have to turn then engine over two full turns. Because when #1 exhaust is open, the exhaust that is directly across the engine will be closed, I hope that makes sense and doesn't confuse you.
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Mon Aug 05, 2019 6:40 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
Wow that's gnarly sounding. |
Posted: Mon Aug 05, 2019 6:46 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
Get the three plastic clips that snap into the holes on the rear of the fan shroud. The spark plug cables then clip into those plastic clips, to keep the cables from possibly getting melted on the hot heat riser pipes or chaffed laying around like that. Also you are wasting cooling air by having it leak back into the engine compartment.
Looks like you are also missing the heat riser tins. _________________ In Stereo, Where Available! |
Posted: Mon Aug 05, 2019 6:57 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
You are missing the left rear lower cylinder tin, that is important to keep the cooling air flowing over the rear lower of that cylinder. Having the rear tin hanging open like that on the left with the cylinder fins showing is a good way to cook the engine by letting air that has cooled the engine to get back into the engine compartment and thusly hotter air to being pumped back over the engine.
Do check if the right hand lower rear cylinder tin is missing! _________________ In Stereo, Where Available! |
Posted: Mon Aug 05, 2019 7:02 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
Get the stock metal fuel line that should be running from just in front engine tin (front as in closer to the front bumper) and all the way to the fuel pump. You want to keep the flexible fuel line to a minimum, and have less chance of a VW BBQ. Also most folks are not a big fan of the fuel filter in the engine compartment due to possibly causing a fire. Personally never have had a problem with it between the fuel pump and carb for several hundred thousand miles, but you do not want the filter to be rubbing against hard items..., _________________ In Stereo, Where Available! |
Posted: Mon Aug 05, 2019 7:21 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
Eric&Barb wrote: |
Get the stock metal fuel line that should be running from just in front engine tin (front as in closer to the front bumper) and all the way to the fuel pump. You want to keep the flexible fuel line to a minimum, and have less chance of a VW BBQ. Also most folks are not a big fan of the fuel filter in the engine compartment due to possibly causing a fire. Personally never have had a problem with it between the fuel pump and carb for several hundred thousand miles, but you do not want the filter to be rubbing against hard items..., |
yeah i'm working on getting the tins sorted. lot's of stuff on this thing that i need to work out. know anyone selling said pieces? |
Posted: Mon Aug 05, 2019 7:26 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
Classifieds on this very website is a great place to do a searches for parts for sale like "Engine Tin" or other stuff like that. Do avoid the West of Pacific reproduction stuff like the plague.
Hopefully you will be getting a stock air cleaner... _________________ In Stereo, Where Available! |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Tue Aug 06, 2019 1:36 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
Pull the valve cover and look for loose hardware. Your adjuster nuts could have backed off. The nuts that hold your rocker shaft could have backed off. Then like they mentioned above, check your timing. Oh and do the things E&B said, he comes off as twat, but he's gonna save you some money and a major head ache in the end. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Posted: Tue Aug 06, 2019 7:07 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
pulled the valve cover off and checked to see if any of the adjuster and/or rocker shaft nuts were loose and they're fine. timing is next and i may even try and re-adjust the valves using the "open-close" method. i also checked the exhaust gaskets on the left bank and there doesn't appear to be any evidence of any exhaust leakage.
i'm stumped |
BarryL Samba Member
Posted: Wed Aug 07, 2019 9:51 am Post subject: Re: help with weird tapping sound on 1641 dp motor... |
It could even be a binding wrist pin or sticking lifter. |
Posted: Wed Aug 07, 2019 9:54 am Post subject: Re: help with weird tapping sound on 1641 dp motor... |
BarryL wrote: |
Which could bend a push rod, so it would be seen if inspected... _________________ In Stereo, Where Available! |
Posted: Mon Aug 12, 2019 7:35 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
need to put this on hold while i update my brakes and suspension. 2 out of 4 drums had stuck cylinders and grounded down to the metal backings! 3 shocks were shot too making a wheezing sound on compression and the drivers front drum cylinder had zero fluid in the hose. i'm guessing it's clogged somewhere along the master to the brake line. getting real intimate with it now
waiting for parts and then will get back to this... |
Posted: Sat Oct 12, 2019 1:20 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
ok so finally getting back to this... so this morning i saw that one of the exhaust nuts had backed out! so much that could loosen even more with my hands
i tightened it along with the bottom nut and bingo bango motor is quiet again. going to wither double nut or lock washer the thing. anyone else experience this and what did you do to fix it? |
Posted: Sat Oct 12, 2019 2:14 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
Mayhaps you did not properly torque the nuts down in the first place? _________________ In Stereo, Where Available! |
turkis-deluxe Samba Security
Posted: Sat Oct 12, 2019 2:30 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
Yes actually had this happen one time before. Yes, mine were properly tightened. Weird coincidence that it happened soon after I installed a Wolfgang mid-tranny mount. Not sure if it's related or not or just bad timing. Tightened everything and has been good ever since! |
quartermilecamel Samba Member
Posted: Tue Oct 15, 2019 5:06 pm Post subject: Re: help with weird tapping sound on 1641 dp motor... |
I have had exhaust make all kinds of seudo valve train noise. My head exhaust nuts have been coming loose for years, even a couple of studs. Havnt bought copper nuts yet and should do so. Right after I solve the dreaded shrinking valve cover gasket then piss all your oil out while your driving issue. I do my adjustment for valves with the .006 is ok as long as a .007 doesnt fit. This is my first engine and it has so many issues its time for the do over. May you find your noises in short order, good luck _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
