Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sun Jan 05, 2020 10:14 am Post subject: what length rods do i need? |
hello, off of experience could anyone tell me what the best push rod size for my engine combo. im trying not to have to buy a adjustable push rod tool.
1776,
-c35 cam
-elephant feet on scat solid shafts
-i havnt got my heads flycut yet but im aiming for around 8.5-1 cr.
yes, i know it will be hard to tell me without deck height and flycut measurements but will stock length ones work or should i return to this post once ive got the short block assembled?
thanks |
Ebel Samba Member
Posted: Sun Jan 05, 2020 10:30 am Post subject: Re: what length rods do i need? |
You can make an adjustable pushrod from an old stock one. Just need to cut the old one and tap it and add some threaded rod and a nut. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31376 Location: Hot Arizona
Posted: Sun Jan 05, 2020 12:47 pm Post subject: Re: what length rods do i need? |
Ebel wrote: |
That's what I did for my 1835cc engine in 1986, and it's still running. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mark tucker Samba Member
Posted: Sun Jan 05, 2020 12:54 pm Post subject: Re: what length rods do i need? |
dittox2. dont get ahead of your self, and do not guess at it or let somebody tell you what it needs with out knowing everything ans seeing it. |
Bama Dave Samba Member
Posted: Sun Jan 05, 2020 1:18 pm Post subject: Re: what length rods do i need? |
Best to spend the $24 than to guess. _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
First off, I know i made stupid decisions that led to my predicament, so while you are welcome to tell me that I am an idiot for doing the things I did, please know that I am already aware of this. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Sun Jan 05, 2020 3:00 pm Post subject: Re: what length rods do i need? |
Absolutely no way of knowing. You need the tool and a mag base dial indicator. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon Jan 06, 2020 8:00 am Post subject: Re: what length rods do i need? |
Chickensoup wrote: |
1776,
-c35 cam
thanks |
Unless you have something really out of whack, you should only need standard push rods. The best thing to do is assemble everything, stick a stock push rod in there and see if you can adjust the valves. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Posted: Mon Jan 06, 2020 10:24 am Post subject: Re: what length rods do i need? |
All good advice and it's what I expected to hear although now that you've mentioned the diy push rod tool, where can I find directions on how to make em?
Thanks |
slalombuggy Samba Member
Posted: Mon Jan 06, 2020 11:36 am Post subject: Re: what length rods do i need? |
Thanks |
Cut pushrod about 1 inch from one end, cut 1/2 inch off short piece, tap both ends. Insert 1.5 inches of threaded rod into long piece using loctite to secure it, spin on short end.
brad |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Mon Jan 06, 2020 2:01 pm Post subject: Re: what length rods do i need? |
slalombuggy wrote: |
Thanks |
brad |
Any lubrication issues by removing that oil passage in the stock pushrod? _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Mon Jan 06, 2020 2:05 pm Post subject: Re: what length rods do i need? |
kangaboy wrote: |
Thanks |
brad |
Any lubrication issues by removing that oil passage in the stock pushrod? |
The adjustable push rod is a tool to measure the length needed for custom push rods. It is not used in a running engine. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
