Subaru mechanics in PNW that are willing to work on conversions?
Page: 1, 2, 3  Next
donnyk
donnyk is offline
PostPosted: Wed Aug 07, 2019 5:03 pm    Post subject: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
This feels like it shouldn't be a dumb question but after calling subaru shops it seems like one...
I'm just looking for a shop that will work on an engine specific issue (cam seal replacement) for my EJ25. I keep getting turned down. VW shops are expensive as hell and there's a long wait time. Do any of you guys in the Seattle area (who don't fix every problem on your own) have a subaru mechanic you'd recommend, or do you always bring it to a VW shop?
Apologies if I shouldn't even ask this here
* * * Moderator edit* * *
Shops that work on Subaru-converted Vanagons:
  • Small Car Performance - Fife, WA
  • PeaceVans - Seattle, WA
  • NorthWesty - Renton, WA
  • Eion's Automotive - Seattle, WA
  • All Wheel Drive Auto - Kirkland, WA
  • Drive Auto Sports - Woodinville, WA
  • T & R Automotive - Salem, OR
  • FW Motorsports - Rocklin, CA
  • Affordable German - Phoenix, AZ
  • Biel's Auto - Prescott, AZ
DirtyBlueVan
DirtyBlueVan is offline
PostPosted: Wed Aug 07, 2019 6:29 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
small car performance is in Tacoma
1989 Syncro Westfalia 2.5 smallcar subie
newerwesty1987
newerwesty1987 is offline
PostPosted: Wed Aug 07, 2019 6:55 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
Just go to a well rated (yelp) Japanese car shop. A lot of independents know more than the actual labeled shops do anyway and will surely be more open minded. I know of two near me that dont care about the swaps at all.
hogan029
hogan029 is offline
PostPosted: Wed Aug 07, 2019 7:09 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
If you need cam seals, it's a good time to "while you are in there"..food for thought.
wesitarz
wesitarz is offline
PostPosted: Fri Aug 09, 2019 7:28 am    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
Any independent mechanic who can do a Subaru timing belt should be able to do it. If you have a Smallcar engine carrier it involves unbuttoning the muffler, moustache bar and carrier to get at the full timing cover. Smallcar might be your best bet.
markswagen
markswagen is offline
PostPosted: Fri Aug 09, 2019 7:40 am    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
While I can't give you the name of a shop, you should be looking for someone who modifies Subaru's, race rally, what ever, someone who is used to modifying them, shouldn't have a problem with a conversion, peoplease who are only used to stock Subarus won't go near it because it's not stock.
619 201 0310
jimf909 Premium Member
jimf909 is offline
PostPosted: Fri Aug 09, 2019 7:48 am    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
I assume you called PeaceVans and Northwesty? I'm guessing they're the ones who are expensive and a month out.
Try Greg's Japanese auto.
Abscate wrote:
Current: 1990 Westy Camper - Bostig RG4, 2wd, manual trans w/Peloquin, NAHT high-top, Flash Silver, seam rust, bondo, etc., etc.
Corwyn Premium Member
Corwyn is offline
PostPosted: Fri Aug 09, 2019 9:47 am    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
X2.
Fife, Washington to be exact: https://smallcar.com/
'90 White Westy ("Whirlpool")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
RainierSyncro
RainierSyncro is offline
PostPosted: Fri Aug 09, 2019 2:51 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
If you stop at Small Car in Fife, hit Pick-Quick down the street for a burger.
11BC2
11BC2 is offline
PostPosted: Fri Aug 09, 2019 3:58 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
You could drive down to my Subaru shop in Rocklin, CA. We're swapped Vanagon friendly and there's a pretty decent brewpub 67m out our front door!
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Fri Aug 09, 2019 6:30 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
How come this question isn't brought up more when discussing swaps? I wouldn't touch a non-VW engine shoe-horned into a VW at my shop. And I assume the offbrand shop wouldn't mess with a bastardized VW in theirs. There's no profit in climbing the learning curve when there are other more relevant projects waiting. Simple maths.
Casey--
Volkswagens powered by Volkswagen
'01 Weekender VR6 -->2.5 TDI Syncro?
Oly Bulli
'87 300TD OM606 7mm Myna pump and HX30
AZ Landshaper Premium Member
AZ Landshaper is offline
PostPosted: Fri Aug 09, 2019 7:16 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
I can under stand the zitguest but theres a lot of swaps out there and for anyone with a price strategy theres still a profit to be made. And apparently the market is ripe for a qualified shop to step up to the plate.
try Pacific import auto
Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug.
jimf909 is offline
PostPosted: Fri Aug 09, 2019 7:35 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
AZ Landshaper wrote:
I can under stand the zitguest...
Hmmm...
wesitarz
wesitarz is offline
PostPosted: Fri Aug 09, 2019 8:17 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
Simple math() Zeitgeist. A mechanic didn't do my swap. I did. A mechanic has not touched my Japanese swapped engine in 16 years and counting and I'm not a mechanic.Shoehorned? Hardly. The German 2.1 WBX was a POS.
Zeitgeist 13
PostPosted: Fri Aug 09, 2019 8:46 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
I did my own swap as well, but that's not what the OP was asking about.
Casey--
Oly Bulli
Abscate Premium Member
Abscate is offline
PostPosted: Sat Aug 10, 2019 3:05 am    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
Thatís evidence there is no money in working on these, isnít it! Oil changes, brake jobs , And timing belts are 10x more profitable than engine work. No surprises, no supply chain management, and itís in and out , like clockwork orange.
You can charge four hours labor on a Tb and do it in one. Kaching.
.ssS!
donnyk
donnyk is offline
PostPosted: Fri Aug 16, 2019 5:16 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
I agree this should be discussed more. I'd think a japanese/subaru shop would be happy to look at something different but what Zeitgeist said seems to be true as I called 8 shops and they just won't work on it.
I appreciate all your input but I'll choose between peacevans/northwesty/small car even though it's solely the subaru engine that needs work...
thank you 11bc2 for the invite but I'm trying to find a little bit of a closer place Very Happy
ledogboy
ledogboy is offline
PostPosted: Fri Aug 16, 2019 5:24 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
It isnít as though the average VW shop is going to be comfortable working on a 1.8t swap.
1986 Westy Weekender
Now a full camper
1.8t CCW Quattro Syncro
Some people call him Maurice...
levi
levi is offline
PostPosted: Fri Aug 16, 2019 6:34 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
Also, there IS a difference between black seals and brown seals.
It's been a lot of years since I pulled out the last subaru engine, so I don't remember which, but one of those will leak sooner than the other. Btdt.
Basically, whichever one is being sold by your local pep boys type shop is the wrong one.
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
pnwkayaker
pnwkayaker is offline
PostPosted: Fri Aug 16, 2019 7:33 pm    Post subject: Re: Subaru mechanics in PNW that are willing to work on conversions? Reply with quote
Both me and my wife drive Subaru cars and service them at All Wheel Drive Auto (http://allwheeldriveauto.com) in Kirkland. The other day it occurred to me to ask the main guy down there
- "So, this might sound weird, but do you guys service Subaru engines installed on non-Subaru cars?"
- "You mean, like a Vanagon?"
I almost fell to floor when he said that!
It turned out that they haven't worked on any converted van yet, but they've heard about it and are not opposed to the idea of working with them - in fact, they're intrigued by it. He also mentioned that their sister shop Drive Auto Sports (http://www.driveautosports.com) located in Woodinville might be even more suited to deal with with a Sub conversion, since they have no problems working with special cars.
So that's it - I haven't brought my Syncro to them yet, but I might do that to get a second opinion on a potential pressure leak on my EJ25 (they do a great job on our regular Subarus). I might probably start at All Wheel Drive Auto first to get an idea of how they deal with a Suby on a VW, and might ask Drive Auto Sports afterwards (somehow I imagine the Woodinville shop will be more expensive than the Kirkland shop).
87 Syncro Westy EJ25 ("Tardis")
Page: 1, 2, 3  Next
