155/60r15 - what PSI?
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Center Pin
Center Pin is offline
PostPosted: Thu Aug 08, 2019 9:19 am    Post subject: 155/60r15 - what PSI? Reply with quote
On my 57 daily driver I just switched from 135r15s up front to 155/60r15s (wow what a difference). Set the pressure @ 18 psi, visually they look low on pressure, driving they feel too high. The tire are Achilles Atr-k Economist at $85 usd for the pair I couldn't pass them up.
For those running 155/60r15s what tire pressure have you found to be the sweet spot?
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Aug 09, 2019 12:22 pm    Post subject: Re: 155/60r15 - what PSI? Reply with quote
Me, I'd try dropping them to 16 or 17 and see what they feel like. I'd not go any lower than that though. Yes they may "look" underinflated, but with the more rigid structure of radials, they are inherently more rigid overall.
Andy T.
-Volunteer Post-Production Sound Editor for Starship Excelsior - A Star Trek Fan Production.
QRP
QRP is offline
PostPosted: Sat Aug 10, 2019 1:19 pm    Post subject: Re: 155/60r15 - what PSI? Reply with quote
60 profile tires usually have a stiffer side wall.
Just curious . . Are you running gas shocks in front or standard oil shocks?
Center Pin
PostPosted: Mon Aug 12, 2019 8:49 am    Post subject: Re: 155/60r15 - what PSI? Reply with quote
Running standard oil filled shocks, standard width adjustable beam, original rims, and a single set of caster shims.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
