Adriel Rowley Samba Member
Joined: October 12, 2006 Posts: 4748 Location: Mesa, Arizona
Posted: Mon Nov 30, 2020 7:36 pm Post subject: Re: Dad's 1964 Ruby Red Beetle |
Ceckert64 wrote: |
The 64s have some one year only stuff and some oddities and mix of 63 and earlier styling with 65 up and its kinda a transition year. If it’s an August 63 production 64, they are practically the 63 body styling. Too much to list. I made a list when I made the 64 registry. |
I know the decklid is one year only as T handle with 1965 and later plate light. Ruby is February 1964.
Ceckert64 wrote: |
General overview? I have Type 1, 2, 3, and 4 parts and a decent amount of all and then I had/have parts from split window bug up to water cooled. I have a ton of T3 engine parts, enough for another complete running engine. I have a bunch of 64 parts for 64, one I finish, I can give you a end of restoration deal. I have a bunch of duplicate rubber pieces because I bought the same piece twice. I have literally everything, just random parts of rarely used pieces. I will get the pictures uploaded. |
Meh, I can't communicate, the word was a few examples to understand your prices.
Right now just interested in parts for Ruby, so we can wait until yours is done. This be better financial timing, right now with my situations it's tighter than a corset.
I have bins of Type 3 parts, most of it FI parts (ex. every time I found a MPS with a good diaphragm for a reasonable price I bought it). A lot of it is from a 1968 I parted out for an acquaintance which didn't get sold.
I will never own a Type 2 or Type 4. On Type 4, what about reaching out to Ray Greenwood? _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Dad's 1964 Beetle purchased September 1968.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9252810#9252810
1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation |
Posted: Wed Dec 09, 2020 7:37 pm Post subject: Re: Dad's 1964 Ruby Red Beetle |
Monday night released from the hospital, no home health, no occupational therapy, and no physical therapy. Welcome to Government insurance, where they do everything they can to eliminate costs by attempting to eliminate patients. With my brain-body disconnect, it is hard knowing what I can and can't do. I think I am fine, then all of a sudden I am short of breath and feel like my heart is going to explode.
I hate taking naps, makes me feel like I am being lazy and childish, yet I am trying to accept sometimes they are necessary. Had a long 45 minute nap, falling back asleep, so decided to see if could make it the 500 or so feet to the mail, neighbor wouldn't get it for me. After a lot of struggle, only made it about 50 feet. Well heck, I'm out here anyway let me have a look at the cooling system.
I am not finding anything remotely looking like the pictures of a 1964 and earlier setup. There are not even any places for anything to attach. So then is this a 1965 and later fan shroud?
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Wed Dec 09, 2020 7:47 pm Post subject: Re: Dad's 1964 Ruby Red Beetle |
if this helps, heres my pre 65 40hp shroud
_________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
AutoMechanic Samba Member
Joined: December 28, 2019 Posts: 483 Location: Roanoke Virginia
Posted: Wed Dec 09, 2020 8:47 pm Post subject: Re: Dad's 1964 Ruby Red Beetle |
Awesome project. |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Thu Dec 10, 2020 10:33 am Post subject: Re: Dad's 1964 Ruby Red Beetle |
vwuberalles wrote: |
Here's the backside of the 1300 from my 66 if it helps:
It does, appreciated. Seems to confirm a 1965 and later fan shroud, another one of Ruby's mysteries.
Now I am thinking just leave the tins alone during the Winter, haven't had any smell or rodent litter blow out, so the airpaths should be clear. Will put in a temporary seal around the engine. Then once have the bread for a 6 volt battery, not only do the conversion, also while the generator stand is off, pull the fan shroud and determine what parts are present and which parts will need to be sourced. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1957 Location: Manitowoc, WI
Posted: Thu Dec 10, 2020 10:49 am Post subject: Re: Dad's 1964 Ruby Red Beetle |
I believe you have the correct 64 fan shroud but you are missing the throttle ring. I don’t see the bolts for the 65+ thermostat flaps. Likely the throttle ring was taken off with the thermostat. At the bottoms edge of the shroud on the front side, if there are no bolts is a 64
The cooling/throttle ring is not part of the fan shroud. It actually does bolt or attach to it in any way. The control/throttle ring uses a one foot bolt that goes through one of the case bolt holes.
The 65 fan shrouds have internal cooling flaps that are inside the fan shroud attached to it with 8 screws visible from the outside. They are at the lower part of the shroud
Edit #2. I can also see that you don’t have any of the 65 plus linkages and screws. So you have a 62-64 shroud there. Still original! _________________ 1964 sunroof Beetle Restoration "Herbie"
1972 Sierra Yellow Tin Top Westfalia Camper
“Fitz” 1971 Westfalia Poptop |
Posted: Thu Dec 10, 2020 12:32 pm Post subject: Re: Dad's 1964 Ruby Red Beetle |
Ceckert64 wrote: |
Edit #2. I can also see that you don’t have any of the 65 plus linkages and screws. So you have a 62-64 shroud there. Still original! |
I am through and through a Type 3 person and trying to find Type 1 information for some reason feels harder to obtain. I'm thinking part of this is because when was learning Type 3s, I was part of a local community whereas out here, doesn't seem to be as prevalent (certainly the pandemic doesn't help).
So the control ring only sits on the the shroud held by the pressure from the pivot mechanism? How is cooling controlled?
As I understand, I am missing the whole cooling setup? _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Thu Dec 10, 2020 5:46 pm Post subject: Re: Dad's 1964 Ruby Red Beetle |
Adriel Rowley wrote: |
Ceckert64 wrote: |
As I understand, I am missing the whole cooling setup? |
The thermostat has a long rod screwed into the top of it. The ring is bolted at the bottom to a shaft with a spring on it. T-stat rod is connected to the shaft with the spring on it. When the rod moves up, the shaft rotates and moves the ring away from the shroud. The rubber stop on the ring keeps it from going to far into the shroud and contacting the fan. _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
Posted: Thu Dec 10, 2020 6:32 pm Post subject: Re: Dad's 1964 Ruby Red Beetle |
Ceckert64 wrote: |
Ceckert64 wrote: |
I will never own a Type 2 or Type 4. On Type 4, what about reaching out to Ray Greenwood? |
I forgot to reply to this. I will have lots of random rubber seals left over for a 64. I have just a lot of random parts leftover. I honestly not %100 sure what I even have, just odds and ends. I do think I have a thermostat assembly/ throttle ring for warm up. I can cut a good deal on prices, but none of the parts are pretty or shiny they have seen the harsh roads of Michigan filled with salt and filled with potholes.
Same with T3, ever time I’m at the junkyard I try to get as many FI parts I can find.
For T4, they are engine parts for the engine I’m rebuilding from my bus and I pulled it from a 411.
When you have a list of parts you need, let me know, the parts I have are all over the board and I probably have it. _________________ 1964 sunroof Beetle Restoration "Herbie"
Posted: Thu Dec 10, 2020 9:41 pm Post subject: Re: Dad's 1964 Ruby Red Beetle |
TinCanFab wrote: |
Ceckert64 wrote: |
The thermostat has a long rod screwed into the top of it. The ring is bolted at the bottom to a shaft with a spring on it. T-stat rod is connected to the shaft with the spring on it. When the rod moves up, the shaft rotates and moves the ring away from the shroud. The rubber stop on the ring keeps it from going to far into the shroud and contacting the fan. |
Thank you for explaining. Interesting the further the ring moves away, the more airflow is allowed to pass. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Posted: Thu Dec 10, 2020 9:57 pm Post subject: Re: Dad's 1964 Ruby Red Beetle |
Ceckert64 wrote: |
Ceckert64 wrote: |
Ceckert64 wrote: |
When you have a list of parts you need, let me know, the parts I have are all over the board and I probably have it. |
As I said, no hurry, especially as I just got home Monday night from the hospital. Defiantly have pneumonia and have tested positive for COVID, said be at least a couple months recovery. Thing is I only went out a few times, wore a mask, constantly washed my hands, and sanitized my EDCs every time I came home, and still got it. So, all this about how it can be avoided is false, unless completely stay at home and no visitors. I believe it will be a long recovery, I am stuck using a damn four wheel walker, can't fix meals, and only do light work. However, I am blessed because I am not on oxygen, I can get out of bed, and most important, I am alive!
As for the cosmetic aesthetic of parts used on Ruby, I have always been function over form. When I rebuilt the Type 3 engine, I only cleaned the tins and shrouds. Same for when rebuilt the front and rear suspension, clean and rebuild. So, I am glad I can cross off finding the cooling system parts, that leaves an unobtanium windshield. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Posted: Fri Dec 11, 2020 10:14 am Post subject: Re: Dad's 1964 Ruby Red Beetle |
Damn, sounds sucky. God bless. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Fri Dec 11, 2020 10:15 am Post subject: Re: Dad's 1964 Ruby Red Beetle |
Ceckert64 wrote: |
That's fine, take as much time as you need. Dang, that sounds horrible. Recovering from surgery with Covid and pneumonia , sounds like your doing good considering the circumstances. Hopefully you can get better soon! Going at it with a positive attitude will help! |
I believe it could actually be worse, at least didn't get sick immediately after the surgery. Plus, a bacterial pneumonia so can take antibiotics to help be rid of it. And yes, I do try and stay positive, it isn't always easy, however, it is the best way to heal.
Ceckert64 wrote: |
I Might be replacing the windshield in my bug because it has a crack halfway down the middle on the outer layer of glass, but it is original. So If you are interested let me know |
Hey, better than nothing. When do you think you will decide? Happen to have a picture, just curious?
Ceckert64 wrote: |
Get better soon, Aiden |
Appreciated! _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Posted: Fri Dec 11, 2020 1:23 pm Post subject: Re: Dad's 1964 Ruby Red Beetle |
Ceckert64 wrote: |
I’m not sure if you can see the crack but there was a stone chip and as I pulled the last 3in to install it, it cracked |
What a bummer you were so close. That is to me minor, looks like most be behind the mirror, certainly far less than the one that's broken here. More important, would keep the water out. Again, appreciate the offer, please keep me updated. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
bad91teg Samba Member
Joined: February 13, 2007 Posts: 473 Location: florida
Posted: Sun Dec 13, 2020 8:49 am Post subject: Re: Dad's 1964 Ruby Red Beetle |
Zundfolge1432 wrote: |
Don’t throw nothing away till you are positive it ain’t needed. Most new parts are crap try to refurbish what you can. Fabulous story lotsa help here just ask I’d try some rubbing compound and then wax the paint to see what you have, you might be surprised |
this is some GREAT advice. sorry adriel I had to come back to the beginning of the thread . lol I kinda wanted to refresh my memory with the 64 . anyways keep moving on your dads bug. and have you compound and waxed the bug ? not sure if your planning on painting it or ? if your not painting it I say wax it up ! I bet it would put some wind in the sail lol .and it would be some good update pics for the thread . |
