xclemjustinx Samba Member
Posted: Sat Aug 10, 2019 9:05 pm Post subject: Clunking In rear goes away when brake applied? Help! |
Ok so here’s the deal. I am hearing a clunking sound in the rear drivers side of my van. Now I knowwwwwww there has been tons of threads about cv joints/ clunking/ noise. I feel this one is different though. This is my setup.
Burley rear disc conversion.
930 cv joints and upgrades axles (both sides)
Burley rear hub (both sides)
New hub bearings (both sides)
New stub axles and flanges
Fox 2.0 shock
Schwenk coils
Redline grease
All of these parts are only 3,000 miles old
So a couple of days ago I started to hear a clunking sound from what sounds like the drivers side.my first though is cv Joints. Checks my cv joints and they are good to go. When I turn the van right or left sharp, the noise is there but when I brake the noise is completely gone. Also the noise is intermittent. So far the cv joints look good. Tires are good and rotated. Rear disc brakes look good. Flanges and stub axles look good.
Any help on this I would greatly appreciate. |
E1 Samba Member
Joined: January 21, 2013 Posts: 6528 Location: Westfalia, Earth
Posted: Sat Aug 10, 2019 9:45 pm Post subject: Re: Clunking In rear goes away when brake applied? Help! |
Make sure the wheels aren't loose.
Seriously. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sat Aug 10, 2019 9:47 pm Post subject: Re: Clunking In rear goes away when brake applied? Help! |
Wheels are not loose. They are torqued to 90 ft lbs. |
E1 Samba Member
Posted: Sat Aug 10, 2019 10:56 pm Post subject: Re: Clunking In rear goes away when brake applied? Help! |
Torqued when the other work was done 3,000 miles ago? _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sun Aug 11, 2019 2:18 am Post subject: Re: Clunking In rear goes away when brake applied? Help! |
I'd check every bolt on both sides, caliper bolts, shock bolts, etc. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32574 Location: Reading Pennsylvania
jlrftype7 Samba Member
Posted: Sun Aug 11, 2019 5:33 am Post subject: Re: Clunking In rear goes away when brake applied? Help! |
I’m betting a shock bolt is loose... WAG on my part.....
With that much upgraded parts, it will be interesting to hear what they find the source was.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
jimf909 Samba Member
Posted: Sun Aug 11, 2019 8:26 am Post subject: Re: Clunking In rear goes away when brake applied? Help! |
Is the clunking sound consistent with mph? rpm? Or is it random? _________________ - Jim
Abscate wrote: |
Posted: Sun Aug 11, 2019 8:35 am Post subject: Re: Clunking In rear goes away when brake applied? Help! |
Every bolt is tight. The clunking sound is consistent with speed. As I go faster it increases. I have not tried to center the axle. I thought since the axles and cv joints were upgraded, this was not required. |
Posted: Sun Aug 11, 2019 10:49 am Post subject: Re: Clunking In rear goes away when brake applied? Help! |
I will try that. Thanks. |
Posted: Sun Aug 11, 2019 1:59 pm Post subject: Re: Clunking In rear goes away when brake applied? Help! |
Well I can’t even move the axles when the van is on the ground. |
Posted: Sun Aug 11, 2019 2:49 pm Post subject: Re: Clunking In rear goes away when brake applied? Help! |
I have the upgraded axle for the 930 joints. They do not have grooves in them. I’ll jack up the rear just a bit to take tension off and see if that works. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Sun Aug 11, 2019 9:56 pm Post subject: Re: Clunking In rear goes away when brake applied? Help! |
I suspect your brake shoes are rattling in the caliper, and when you press the brakes, they stabilize under pressure. The rotors typically have sligjht surface irregularities such as when a vehicle sits for a while there's an outline of the pads that quickly wears off, etc. This is a constant process and can cause the pads to wobble/rattle.
I don't know how you'd do this but driving without the pads, or manually pushing them far off the rotors on a straightaway where you won't press them for long enough to establish if this is it might work. Best. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Mon Aug 12, 2019 9:02 pm Post subject: Re: Clunking In rear goes away when brake applied? Help! |
What Doug said...
I had a similar experience in my right front. It was a loose pad in the caliper. _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
