Type 4 engine vs Upgraded Type 1
Page: 1, 2, 3, 4, 5, 6  Next
SweetCars
SweetCars is offline
PostPosted: Sun Aug 11, 2019 7:24 am    Post subject: Type 4 engine vs Upgraded Type 1 Reply with quote
Hi everyone,
Reading lately on Type 4 engine and all the Pros and Cons.
They improved a lot of things compared to original Type 1 engine, aluminium case, beefer crank, better lubricating, better cooling.
I wonder now with the new aftermarket parts we have. For example Type 1 aluminum case, forged crank, full flowed case, external oil coolers, 8 dowel pins cranks..... would the Type 4 still be superior?
Or the type 4 is only superior Stock vs Stock?
Clatter
Clatter is offline
PostPosted: Sun Aug 11, 2019 10:01 am    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Oh, no... Not this one again.. Rolling Eyes
Bus Motor Build
Fastback Build
What's That Noise??
APPLEGREENVW
APPLEGREENVW is offline
PostPosted: Sun Aug 11, 2019 11:00 am    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=699456
Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan
SweetCars
PostPosted: Sun Aug 11, 2019 11:54 am    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Well thank you for the great info.
But what i was asking wasnt information on the type 4.
But with all the diferent technique and aftermarket parts available, not about HP but about reliability, the type 1 engine isnt equal reliable and string than the type 4?
External oil filter
Stronger crank
Aluminium case
Full flow
Arent those the corrections of the type 1 engine? Or even with those mods, the type 4 is greater?
SweetCars
PostPosted: Sun Aug 11, 2019 11:59 am    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Just go on your way. Dont understand the meaning of your comment. Thats maybe the way you got over 4000 post for commenting stupidity. You should be strongly bored.
H2OSB
H2OSB is offline
PostPosted: Sun Aug 11, 2019 1:02 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
No, it's just that this topic has been covered before...and people can get heated.
H2OSB
Some people should not work on engines or other machinery.
Sorry to say that you are one of them. Actually no offence intended. ~ boolean
Alstrup
Alstrup is offline
PostPosted: Sun Aug 11, 2019 3:49 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
He´s already hot Laughing Cool
Short version: Anything sub 2 liter isnt worth converting to type 4 for. Reason is that the cost involved is simply too high.
Harsh enviroment, a lot of high speed driving or high sustained loads say in a bus, YES then it can definitely be an advantage going type 4.
bugguy1967
bugguy1967 is offline
PostPosted: Sun Aug 11, 2019 6:23 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
In a T4
Crank still has no flexing issues
Valvetrain is still more stable
Heads still have more surface area
Pushrod alignment is still better
Crank/flywheel connection is stronger (argueable)
And they're not that expensive. They can be, but so can T1. A machinist could build a very strong T4 on a T1 budget.
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
H2OSB
H2OSB is offline
PostPosted: Sun Aug 11, 2019 6:30 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Not to mention the life span. A well cared for T4 will triple the life of a stock, also well cared for T1
H2OSB
nextgen
nextgen is offline
PostPosted: Sun Aug 11, 2019 7:35 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Wow you guys sound like me, hmmmm, about in 1992, when it was just me vs the T-1 forces.
The time has come when the virtues of the T-4 engine are no longer in doubt.
Carry on!! Ha !
site: www.nextgen-usa.com
email: [email protected]
[email protected]
The Type IV Upright Conversion Manual
jpaull
jpaull is offline
PostPosted: Sun Aug 11, 2019 8:31 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
In most ways the type 4 would still be more reliable. If your sole goal is reliability, and money is not the biggest factor, its really a great choice(better).
This is the performance section of thesamba. So this still needs to be said:
Type 1 fun is with all the choices. A guy can hot rod a type 1 so easy and with low out of pocket. (The small block chevy of VW's)
1. 8 different crank sizes for 250 each
2. 5 different H beam rod sizes for under 250 a set
3. 50 different performance Head options from 5 different manufactures all under $1,000. How many Type 4 performance head options under $1k?
4. Straight cut gears, cams, intakes, rockers, valve covers to infinity.
5. If something does break, its super easy to take apart and relatively inexpensive to fix.
Then comes mechanical beauty...... once a type 4 is converted to go onto type 1, its pretty damn ugly. The wierd oil filler, exhaust morphing out the bottom of the heads Drool barf . Now if your into German look covered in carbon fiber trying to be a porsche then great.
Dyno'ing a VW Engine in my living room https://youtu.be/K_uuA9VwT0g
VW Case in Dishwasher https://youtu.be/fi-g00LzNm0
[email protected] MPH with mild commute to work engine https://youtu.be/fiRQBmgKknY
Onceler
Onceler is offline
PostPosted: Sun Aug 11, 2019 9:06 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
I couldn’t imagine trying to build a type IV for performance considering the relatively small market. Hell, even the far larger type 1 market is packed full of prima donnas.
1972 Karmann Ghia
-defund Facebook believer-
Wages made, all taxes paid
oprn
oprn is offline
PostPosted: Sun Aug 11, 2019 9:12 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Ahh! But... the type 4 engine comes stock with a good bit of performance already built in! We are already 1/2 way there before you guys have even started to hot rod yours! Wink
bugguy1967
PostPosted: Sun Aug 11, 2019 9:56 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
I agree with most of this. I like the look of the T4 now. You gotta acquire the taste, like India Pale Ales.
There are zero options for good heads under $1000, unless you can machine everything yourself.
Wreck
Wreck is offline
PostPosted: Mon Aug 12, 2019 1:03 am    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Then comes mechanical beauty...... once a type 4 is converted to go onto type 1, its pretty damn ugly. The wierd oil filler, exhaust morphing out the bottom of the heads Drool barf . Now if your into German look covered in carbon fiber trying to be a porsche then great.[/quote]
No ugly oil filler's here Very Happy Very Happy .
My take is horses for courses . if you have a bug/Ghia/Type3 are happy with stock to medium HP then the difference is not that great , reliability comes more down to the engine builder and tuner and how well the engine is serviced in it's life time .
If it's a heavy bus and is used as a daily driver in hotter climates then a type 4 wins because of the 30% bigger surface area of the heads and 94mm cylinders have bigger cooling fins . But again how well the engine is built and cooled plays a huge part in reliability and life span .
AA now make a bare casting of the 2lt Porsche 914 type 4 head just over $300USD .a stock head with 42mm 36mm valves flow around 180CFM at .500" , All depends on machining costs to get the heads fitted out . But I'm guessing in the State's that wouldn't be too much over the $1000 mark
jpaull
jpaull is offline
PostPosted: Mon Aug 12, 2019 7:28 am    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
The 2 pictures above show something that demonstrates a confidence in reliability over a duration of time. The AC compressor. Type 1's can do it, but its abit more realistic with a type 4.
nextgen
nextgen is offline
PostPosted: Mon Aug 12, 2019 10:25 am    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
I don't know about ugly. Most guys like the Cali Style using stock T-1 36 hp fanhousings because they look stock. Evening in states that will not pass a car with a non stock engine. They cannot tell by just looking.
A big percentage of my manuals sold are to Europe you fail inspection if not stock.
Many of my customers are Porsche 356 and 912 owners saving the original engine for when and if they sell the car. No body cutting, in and out like stock.
They daily drive and can have more power then stock. Hard to kill a T-4 in a light car.
I see the only real difference is the Gen/ Alt stand if you look hard.
[email protected]
APPLEGREENVW
PostPosted: Mon Aug 12, 2019 1:01 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
I don't see anything ugly this photo. Cool Drool
02/76 Beetle sedan
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Aug 12, 2019 1:06 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Looks OK to me....
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
jpaull
jpaull is offline
PostPosted: Mon Aug 12, 2019 3:20 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
That's the coolest one I've seen! The ugly ass oil filler is not in the picture, and still needs to be added though. For $600 in cooling for a type 4 conversion that's pretty darn clean.
Page 1 of 6
