Camber bolt adjustment...
GreggK
GreggK is offline
PostPosted: Fri Aug 09, 2019 6:41 pm    Post subject: Camber bolt adjustment... Reply with quote
Hello All,
I'm trying to find out if I'm getting the full adjustment out of the camber bolt on my 2wd. In the picture I have the bolt rotated all the way toward the outside of the wheel well. From the picture, can anyone tell me if for starters, I have the bolt and washer installed correct. I believe there is only one way to install it.
Then, by looking at the mark on the washer, does it look like that is as far as the bolt can rotate out or clockwise for the passenger side. Of course I have the UCA removed to see the bolt/washer clearly.
I'm having trouble getting my camber adjustment out of the negative. It seems if I was able to rotate that bolt another 1/4 turn I'd get what I need. Any help would be GREAT!
Here is another picture from the drivers side.
beach_creature
beach_creature is offline
PostPosted: Fri Aug 09, 2019 9:48 pm    Post subject: Re: Camber bolt adjustment... Reply with quote
I believe the propper orientation is to have the bolt vertical. Canít remember the orientation of the lobe. But itís in the Bentley if you have one.
84 Westy
1.9TD AAZ
5spd manual with Locking Peloquin TBD
BillM
BillM is offline
PostPosted: Sat Aug 10, 2019 6:18 am    Post subject: Re: Camber bolt adjustment... Reply with quote
Do you have Gowesty lift springs installed? If so make sure you have a couple hundred pounds up front before trying to align.
Bill M
87 Westy
wcdennis
wcdennis is offline
PostPosted: Sat Aug 10, 2019 7:13 am    Post subject: Re: Camber bolt adjustment... Reply with quote
Also, the castor adjustment needs to be in range to get the camber correct. Itís the first step in the alignment process.
GreggK
GreggK is offline
PostPosted: Sat Aug 10, 2019 12:03 pm    Post subject: Re: Camber bolt adjustment... Reply with quote
As I'm going through this process and studying my Bently I do see how the caster adjustment effects the camber. I had the entire front suspension removed and when I re-installed everything I didn't have any reference as where to put anything back. I felt I would leave it up to the alignment shop to figure that all out but when I got the call from them that they didn't have the time to do the adjustment on the my Burley UCA's because it might take multiple attempts, I explained to him that the arms were set to a ballpark major adjustment and the camber bolt would fine tune it. That must have went in one ear and out the other because when I picked up my van at the end of the day and I went over it again with him, he said he didn't realize the bolt was for adjustment and thought the heim joint was the sole adjustment. I also asked if once the caster was set would that help bring the camber closer but that went around in a circle too.
Anyway, I've gone over the whole story with Burley and he's guiding me in the right direction. I just spent a few hours on the van and things are looking promising. Thanks Burl and thanks to you guys who responded to my question as well. I haven't taken any true measurements yet but what I've done so far has things "looking" much better than before.
wcdennis
wcdennis is offline
PostPosted: Sat Aug 10, 2019 12:40 pm    Post subject: Re: Camber bolt adjustment... Reply with quote
What passes for an alignment in many shops seems to be only adjusting the Toe-in. No doubt they are stumped by 30+ year-old vehicles.
tjet Premium Member
tjet is offline
PostPosted: Sat Aug 10, 2019 1:10 pm    Post subject: Re: Camber bolt adjustment... Reply with quote
I take my van to a Porsche tuner shop for alignments. They have German car knowledge, and they also know how to read a Bentley.
GreggK wrote:
...Anyway, I've gone over the whole story with Burley and he's guiding me in the right direction. I just spent a few hours on the van and things are looking promising. Thanks Burl and thanks to you guys who responded to my question as well....
Are you using his arms?
When driving a VW Bus (or Vanagon), try to avoid the "H" conditions when possible:
Heat
Heavy
Headwind
Hills
Haste
Hangovers
GreggK
GreggK is offline
PostPosted: Sat Aug 10, 2019 3:57 pm    Post subject: Re: Camber bolt adjustment... Reply with quote
Yes. Burley arms installed.
jlrftype7
jlrftype7 is offline
PostPosted: Sun Aug 11, 2019 10:32 am    Post subject: Re: Camber bolt adjustment... Reply with quote
This IS a sad commentary on a shop that canít research the vehicle theyíre wanting to service..... Rolling Eyes
Sigh.....
'67 Type 3 Fastback, my 2nd car- also long gone
'69 Semi-Auto Stick Shift Beetle, my wife's first car= yep. still long gone....
Ď84 Tin Top - Hilga....Auto
GreggK
GreggK is offline
PostPosted: Mon Aug 12, 2019 10:50 am    Post subject: Re: Camber bolt adjustment... Reply with quote
Yes it is a big let down about the alignment shop. I brought my last van to him about 4 years ago when I first came back to PA. I did some front end work on it before driving it out to California, up to Oregon and then back here to PA. The van seemed to drive well and no odd tire wear so I figured he did something right. I've started studying the DIY alignment thread and reading what ever I can and try to see what I can come up with.
I've already adjusted the caster some and the camber is starting to look better. Going to have to find a gauge now for true readings.
