Deadchemist Samba Member
Joined: September 09, 2018 Posts: 15 Location: Hedmark
Posted: Tue Aug 13, 2019 1:58 am Post subject: T25 Syncro startup issues driving me bonkers! |
Hi guy's!
I have a 1988 2.1 Syncro that I'm having a couple of issues with. Every now and again the engine will just not fire! It cranks fine but will not fire for love nor money. After I'll give up trying and leave it for 10 mins it will come back to life and then run fine until it is left overnight (but not always, i left it two weeks last month on vacation and it fired first time) I believe the problem gets worse when its colder but perhaps that's just my imagination, but it always seems to fire when its warm outside.
Recently its been juddering and running abit rough at low revs in 4th hear.
The strange thing is how intermittent the issue is. Went to start it today and it fired first time no problem. Yet over the last week ive been battling almost every morning to get it fired. I tried some starter fluid but that made no difference, also checked rotary arm, dizzy cap, coil, leads, spark plugs, injectors and everything seems ok! Next task today is to check the hall sender. Had anyone got any other ideas??
Many thanks |
Waldi Samba Member
Joined: February 28, 2014 Posts: 1752 Location: Germany
Posted: Tue Aug 13, 2019 2:28 am Post subject: Re: T25 Syncro startup issues driving me bonkers! |
Sounds bat - problems.
Alot of wires to check. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Tue Aug 13, 2019 4:22 am Post subject: Re: T25 Syncro startup issues driving me bonkers! |
Have you checked the basics like cleaning every ground wire connection? _________________ This free advice is worth exactly what you paid for it.
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Tue Aug 13, 2019 5:16 am Post subject: Re: T25 Syncro startup issues driving me bonkers! |
Do you hear your fuel pump prime when you turn the key to the aux position? Get in the habit of listening for that first and see if perhaps you have a fuel pump issue, ie wiring, relay or pump itself. Then start going through your grounds etc... |
Posted: Tue Aug 13, 2019 5:31 am Post subject: Re: T25 Syncro startup issues driving me bonkers! |
I'm just testing the hall sender atm. Can anyone tell me where the earths are located in the syncro bay?
Fuel pump is priming! |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1028 Location: san diego
Posted: Tue Aug 13, 2019 6:55 am Post subject: Re: T25 Syncro startup issues driving me bonkers! |
Ground wires are on the cylinder head on cylinder 3 / 4 side, if you have AC under the compressor.
Follow down from under the coil, you will see them attach to the head. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Waldi Samba Member
Posted: Tue Aug 13, 2019 7:04 am Post subject: Re: T25 Syncro startup issues driving me bonkers! |
Some of them at the engine
Some at the chassis in engine room
Some left from fuse box in the front |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17114 Location: Retired South Florida
Posted: Tue Aug 13, 2019 7:06 am Post subject: Re: T25 Syncro startup issues driving me bonkers! |
The time to check it is when it’s not starting. Assuming good even compression, it’s a fuel or ignition problem. Nothing wrong with cleaning grounds, but you need to determine if it’s a fuel or ignition problem. For fuel you need a pressure gauge and a noid light for checking injector pulse. For checking the ignition circuit you need a volt ohm meter. When I say ignition, I’m talking spark not the actual switch. A timing light is the easiest quickest way to check for spark.
Once you figure out what is missing then you begin to troubleshoot the cause. Good luck. _________________ ☮️ |
Posted: Tue Aug 13, 2019 7:19 am Post subject: Re: T25 Syncro startup issues driving me bonkers! |
Thanks for the replies. I'll wait until it doesn't fire again and then go through the fuel and ignition. Ive cleaned the grounds and checked everything else i can think of so let's see how it goes. |
