Sparkplug question
jmacgreg
jmacgreg is offline
PostPosted: Mon Aug 12, 2019 11:14 am    Post subject: Sparkplug question Reply with quote
I am wondering if the plugs in my motor are the correct heat range. I bought this car (1966 Bug) with a professionally built motor a couple of years ago. The overall details of the motor are as follows:
2276cc capacity w/9.5:1 compression ratio
Heads: CB Performance 44/37.5 valves w/dual springs & ratio rockers
Cam: Engle FK8
Chromoly push rods
Dual 44mm Webers
Pertronix ignition in 009 distributor
Electronic fuel pump w/3lbs delivery pressure
The plugs that came in the motor are NGK D7EA. I was wondering if it would run better with a hotter heat range plug. The plugs do not look too bad (fouled) just a little dark. The motor stumbles a little bit until I do an Italian tune on it then it cleans up. It gets a little annoying in stop and go driving. I would ask the builder, but I've relocated.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Aug 12, 2019 11:30 am    Post subject: Re: Sparkplug question Reply with quote
I'm using NGK BPC5ES plugs in a 2180 with FK-8 and 9.5:1cr.
So my heat range is a 6 while yours is a 7 so you're is colder.
"5" is the stock heat range.
Glenn
Member #1009
#BlueSquare
HBRag
HBRag is offline
PostPosted: Mon Aug 12, 2019 6:08 pm    Post subject: Re: Sparkplug question Reply with quote
I'm running a D6EA on a similar engine and have no problems. The D7EA where marginal, as if I missed while tuning would foul. So I'd say go hotter if you tuning requires.
jmacgreg
jmacgreg is offline
PostPosted: Tue Aug 13, 2019 12:52 pm    Post subject: Re: Sparkplug question Reply with quote
Thanks for the replies. I'm going to give the D6EA's a try and see if that cleans up the stutter. If not, I'll probably fiddle with the jets a bit.
busey
busey is offline
PostPosted: Fri Jan 03, 2020 9:42 pm    Post subject: Re: Sparkplug question Reply with quote
any update?
No turning back now, "Its Blow thru or No thru" baby!
busey
busey is offline
PostPosted: Thu Jan 09, 2020 7:31 pm    Post subject: Re: Sparkplug question Reply with quote
Cam: Engle FK8
Chromoly push rods
Dual 44mm Webers
The plugs that came in the motor are NGK D7EA. I was wondering if it would run better with a hotter heat range plug. The plugs do not look too bad (fouled) just a little dark. The motor stumbles a little bit until I do an ITALIAN TUNEon it then it cleans up. It gets a little annoying in stop and go driving. I would ask the builder, but I've relocated.
Sorry for sounding like such a VW Novice, but what is an "Italian Tune"?? d'oh!
jeffrey8164 Premium Member
jeffrey8164 is offline
PostPosted: Thu Jan 09, 2020 8:44 pm    Post subject: Re: Sparkplug question Reply with quote
I think it means you stomp on it repeatedly until it complies.
Volkswagen!
(Compression 8.7:1)
busey
busey is offline
PostPosted: Thu Jan 09, 2020 10:58 pm    Post subject: Re: Sparkplug question Reply with quote
I LIKE IT!
